Go to Post Thanks and don't stay up all night waiting for Lavery Claus! - Beth Sweet [more]
Unread 17-12-2011, 16:20
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Physics Quiz 4
F2 >= 5N and some change.
Spoiler for Work:
sqrt(6^2 + F2^2) >= 10 * 0.8
or
6^2 + F2^2 >= 64
or
F2^2 >= 28
or
GitHub
Unread 17-12-2011, 16:42
Re: Physics Quiz 4
Make the following changes to the original problem:
- The static coefficient of friction in the "Y" direction (the direction of the yellow arrow) is mu_y = 0.8
- The static coefficient of friction in the "X" direction (the direction of the blue arrow) is mu_x = 0.2
- The static coefficient of friction varies linearly with theta from mu=0.2 in the "X" direction to mu=0.8 in the "Y" direction as theta goes from zero (X direction) to pi/2 (Y direction).
Now find the value of Fx at which the block begins to slide.
Last edited by Ether : 17-12-2011 at 17:35. Reason: added link back to original problem.
Unread 17-12-2011, 18:06
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Physics Quiz 4
Spoiler for :
theta=arctan(6/f2)
mu=n(theta)+.2
.8=n(pi/2)+.2
.6=n(pi/2)
1.2=n(pi)
1.2/pi=n
mu=(1.2/pi)theta+.2
mu=(1.2arctan(6/f2))/pi+.2
f2^2+36=(10(mu))^2
Sqrt[f2^2+36]=10(mu)
Sqrt[f2^2+36]/10=mu
Spoiler for :
Sqtr[f2^2+36]/10=(1.2arctan(6/f2))/pi+.2
Sqrt[f2^2+36]pi=12arctan(6/f2)+2pi
Sqrt[f2^2+36]-12arctan(6/f2)=2pi
that's ugly
Wolfram Alpha couldn't make it look any better, but it gives us an approximation for f2 of about
Spoiler for :
10.8N
Unread 17-12-2011, 18:54
Re: Physics Quiz 4
Originally Posted by PAR_WIG1350 View Post
You were doing great until you dropped the factor of "pi" on the left hand side in the very last equation. The numerical answer you got should have been a red flag that something was wrong.
Fix that, get a new numerical value for F2, then ask yourself "what happens when F2 = 2 Newtons?"
Unread 17-12-2011, 19:27
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Re: Physics Quiz 4
F = sqrt(36 + F2^2)
F = 10*(.2 + .6 (theta/(pi/2)))
theta = arctan(6/F2)
F = 10*(.2 + .6 (2arctan(6/F2)/pi))
sqrt(36 + F2^2) = 2 + 6 (2arctan(6/F2)/pi)
F2 ~= 2.491 N
I'm confused; does this mean that it takes MORE sideways force to move the block than it would if there was no vertical force? For example, wouldn't the block move if F1 = 0N and F2 = 2N?
Unread 17-12-2011, 20:28
Re: Physics Quiz 4
Originally Posted by John View Post
F = sqrt(36 + F2^2)
F2 ~= 2.491 N
Excellent.
Excellent. You have asked the $64K question.
If you assume that the coefficient in any given direction is not increased by force components not in that direction, then the answer is that the block will start to slip when F2=2 Newtons. See attached "solution.pdf".
However, these 2 assumptions:
1: linear change in mu for angles between 0 and pi/2, and
2: mu is not increased by force components not in direction being considered
are I think open questions.
In FRC, there are wheels which are said to have different mu in the forward and sideways directions. I have looked but never seen any test data to show what happens when force is applied at a variety of angles between 0 and pi/2.
Unread 18-12-2011, 16:07
Re: Physics Quiz 4
... I have looked but never seen any test data to show what happens when force is applied at a variety of angles between 0 and pi/2.
See attachments.
Plotting the "linear" model of μ vs θ in polar coordinates suggests it may not be a good model.
Perhaps an elliptical interpolation between μx and μy would be a better model. See attachments.
I haven't done the math yet, but I think the elliptical model will solve the "2 Newton paradox" discussed earlier in this thread.
Name:	mu elliptical.gif
ID:	11211  Click image for larger version
Name:	''linear'' interp.gif
ID:	11216  Click image for larger version
Name:	''linear'' & elliptical.gif
ID:	11217  Click image for larger version
Name:	mu elliptical eqn.gif
Unread 18-12-2011, 19:41
Re: Physics Quiz 4
Solution is 1.3 Newtons using the elliptical interpolation. See attachments.
Name:	elliptical solution graph.gif
ID:	11219  Click image for larger version
Name:	elliptical solution b.gif
Unread 19-12-2011, 13:01
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Physics Quiz 4
Very interesting thread. Here is some neat related tire info:
http://www.insideracingtechnology.com/tirebkexerpt2.htm
This would make an excellent science fair project.
Unread 17-12-2011, 22:23
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Physics Quiz 4
Its better that I make that mistake here than on the AP exam
Originally Posted by theprgramerdude View Post
Top view with respect to what, though? The table, or the plane the forces are acting on? The ambiguity of the question leaves it perfectly open to interpretation that the table is flush with any of the six faces of the block. Assumptions are useful in solving situations like this, but they can also lead to highly erroneous answers if they are wrong.
The plane on which the forces are acting and the table are the same plane, the normal force is perpendicular to that plane, the direction of gravity, irl, is down with respect to an observer in the same gravitational field as the object in question. since we are looking from the top, down can be assumed to be away from us.
