Go to Post I can't think of anything [I]better[/I] to do. - Mr. Van [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
  #316   Spotlight this post!
Unread 12-12-2011, 17:15
Miksoko's Avatar
Miksoko Miksoko is offline
AKA: Soren
FRC #2115 (M^3- Red Dwarf)
Team Role: Student
Miksoko is an unknown quantity at this point
Re: First Official 2012 Game Hint
What if there is a tunnel?
There are a lot of amber lights and a lot of photoswitches- which monitor light in a given spot. This would work most accurately in a full dark situtation which is not possible in a game setting. To get full dark, I propose that as a speculation, they have a tunnel, and blind operations.
  #317   Spotlight this post!
Unread 14-12-2011, 15:09
UBY UBY is offline
FRC #2455
UBY is an unknown quantity at this point
what will the very high speed counter be used for? I was wondering if there would be tennis balls, racketballs, golf balls?
  #318   Spotlight this post!
Unread 14-12-2011, 17:15
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
The Amber lights are found on all of the competition fields, under the stack lights at the Alliance Stations. There are 6 Per Field. That is 12 for the two new fields.
Also, the photoswitches are used for detecting proximity, and or line following. They are not analog parts, so they are not useful for detecting light levels. How they work is they send out an IR beam, and when they get a reflection that is above a set threshold amount, they turn on.
And if we had a tunnel long enough for it to be dark, how would the field get reset, how would the spectators see, and the operators operate?
  #319   Spotlight this post!
Unread 14-12-2011, 17:16
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Small balls are a possibility, but also consider the safety aspect of any game piece... a golf ball that gets shot out into the crowd (or at a ref!) could injure someone. If you've ever played tennis or racquetball, you know those can sting pretty good too, when hit hard!
Foam balls - like those used in many Nerf toys - can be launched pretty quickly, yet won't hurt much if a shot goes wrong. But those are probably too easily obtained and frequently stocked to be used as a FIRST game piece
  #320   Spotlight this post!
AKA: Pierce Jensen
QBY, please read the posts before. This has been discussed heavily before your post.
  #321   Spotlight this post!
Unread 15-12-2011, 11:58
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
What says they have to be shot though? What if they are going to be fed into a bucket of some sort instead of a goal on a wall.
  #322   Spotlight this post!
Unread 15-12-2011, 12:22
Even if they are going into a bucket, don't you think that some team is going to have the bright idea that shooting them in from half a field away will allow them to score more points (as they won't have to drive right up to the bucket)?
I've been hit with the game pieces (intentionally or accidentally) for every game for the past 5 years. None of them have really posed an injury threat if something went wrong - the closest we got was with the track balls, and being as large as they were it was pretty difficult to get them enough speed to be really dangerous (which still didn't stop some team from trying in their effort to score quickly and efficiently!).
  #323   Spotlight this post!
Unread 15-12-2011, 12:47
Flywheel Police
Rules could be made to stop this, my point is I wouldn't count out any game piece.
  #324   Spotlight this post!
Unread 15-12-2011, 13:10
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
FTC currently encourages students to lift bowling balls way up high. There are many ways in which safety can be instituted in an exciting way.
Recall the initial velocity rules from 2006.
<S02> Muzzle Velocity - No ROBOT may throw a ball with an exit velocity of greater than 12 m/s (26.8 mph).
As a reference, a ball traveling at this velocity when leaving the ROBOT at an angle of 30º from horizontal with no spin will travel approximately 35 feet. A robot that violates this rule will be considered unsafe per <S01>.
Hi!
  #325   Spotlight this post!
Unread 16-12-2011, 13:32
AKA: Pierce Jensen
And Remember, they had numerous palates of plexiglass, which could be used to enclose the entire field, protecting spectators and drivers alike...
  #326   Spotlight this post!
Unread 16-12-2011, 21:12
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
No it doesn't, it doesn't specifically discourage it either, but the goal into which the bowling ball is scored is only 8 inches above the playing field and there is a ramp leading up to it. Furthermore, the bowling ball only weighs six pounds, so it would hurt, but anything that could make it do more than that would likely be declared a safety hazard and would have to be disabled in order to pass inspection.
Just a word of caution, Plexiglass is acrylic, which shatters on impact; The palates had polycarbonate, which doesn't shatter under normal conditions and bends to absorb impacts rather than failing completely. I don't recommend using plexiglass on or near the robots for anything, but polycarbonate is a good material for FRC when it is properly used.
  #327   Spotlight this post!
Unread 16-12-2011, 22:56
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
thats a bit ironic... what i wonder is how they get away with using plexiglass for the guard panels at hockey rinks... pucks can fly at pretty quick speeds, esp in a pro game and it bounces of one of the goal posts (net supports)... must be a puck thing.
speaking of which, what about puck like hockey game? that my require high speed sensors...
  #328   Spotlight this post!
Unread 17-12-2011, 10:14
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Because they do use polycarbonate but the sportscasters call it plexiglass because it's easier to say.
  #329   Spotlight this post!
Unread 17-12-2011, 20:13
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
plexiglass is easier to say than polycarbonate. Hockey would be a cool game to play but the only problem is that it would be tough for every team to have a rink to practice on.
Team 696 2010-2013 Student
2014 2x Industrial Design Award Winners CVR and LAR
2013 Inland Empire Finalists -696 Circuitbreakers, 3476 Code Orange, and 4140 Wired
  #330   Spotlight this post!
Unread 17-12-2011, 20:15
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Regolith anyone?
