Go to Post We always have a party on Friday. It's called scouting. - Meredith Novak [more]
Unread 17-12-2011, 15:40
Physics Quiz 4
Figure1 is a top view of a block sitting on a table.
The block weighs 10 Newtons.
The coefficient of static friction between the block and the table is 0.8 (the same in all directions).
A force F1 = 6 Newtons is applied to the block (yellow arrow).
A force F2 (blue arrow) is then slowly applied in the direction shown. At what magnitude of F2 does the block begin to slide?
Unread 17-12-2011, 15:49
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: Physics Quiz 4
2*SQRT(7) Newtons
-Borna Emami
Team 0x27
Unread 17-12-2011, 15:57
Re: Physics Quiz 4
Originally Posted by BornaE View Post
2*SQRT(7) Newtons
For the benefit of students reading this thread, would you please show your work?
Thank you.
Unread 17-12-2011, 16:20
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Physics Quiz 4
F2 >= 5N and some change.
Spoiler for Work:
sqrt(6^2 + F2^2) >= 10 * 0.8
or
6^2 + F2^2 >= 64
or
F2^2 >= 28
or
GitHub
Unread 17-12-2011, 16:42
Re: Physics Quiz 4
Make the following changes to the original problem:
- The static coefficient of friction in the "Y" direction (the direction of the yellow arrow) is mu_y = 0.8
- The static coefficient of friction in the "X" direction (the direction of the blue arrow) is mu_x = 0.2
- The static coefficient of friction varies linearly with theta from mu=0.2 in the "X" direction to mu=0.8 in the "Y" direction as theta goes from zero (X direction) to pi/2 (Y direction).
Now find the value of Fx at which the block begins to slide.
Last edited by Ether : 17-12-2011 at 17:35. Reason: added link back to original problem.
Unread 17-12-2011, 18:06
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Physics Quiz 4
Spoiler for :
theta=arctan(6/f2)
mu=n(theta)+.2
.8=n(pi/2)+.2
.6=n(pi/2)
1.2=n(pi)
1.2/pi=n
mu=(1.2/pi)theta+.2
mu=(1.2arctan(6/f2))/pi+.2
f2^2+36=(10(mu))^2
Sqrt[f2^2+36]=10(mu)
Sqrt[f2^2+36]/10=mu
Spoiler for :
Sqtr[f2^2+36]/10=(1.2arctan(6/f2))/pi+.2
Sqrt[f2^2+36]pi=12arctan(6/f2)+2pi
Sqrt[f2^2+36]-12arctan(6/f2)=2pi
that's ugly
Wolfram Alpha couldn't make it look any better, but it gives us an approximation for f2 of about
Spoiler for :
10.8N
Unread 17-12-2011, 18:54
Re: Physics Quiz 4
Originally Posted by PAR_WIG1350 View Post
You were doing great until you dropped the factor of "pi" on the left hand side in the very last equation. The numerical answer you got should have been a red flag that something was wrong.
Fix that, get a new numerical value for F2, then ask yourself "what happens when F2 = 2 Newtons?"
Unread 17-12-2011, 19:24
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: Physics Quiz 4
Can you list the plane on which the block rests, as well as the direction of the gravitational force?
Attending: MN Duluth Regional
Unread 17-12-2011, 19:27
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Re: Physics Quiz 4
F = sqrt(36 + F2^2)
F = 10*(.2 + .6 (theta/(pi/2)))
theta = arctan(6/F2)
F = 10*(.2 + .6 (2arctan(6/F2)/pi))
sqrt(36 + F2^2) = 2 + 6 (2arctan(6/F2)/pi)
F2 ~= 2.491 N
I'm confused; does this mean that it takes MORE sideways force to move the block than it would if there was no vertical force? For example, wouldn't the block move if F1 = 0N and F2 = 2N?
Unread 17-12-2011, 19:29
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Physics Quiz 4
Its not needed to be specified. It has already been given sort of. If the block is sitting on a table, we assume the plane is parallel to the ground and perpendicular to the gravitational force. Remember, it is a top view of the block.
Jason
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 17-12-2011, 20:28
Re: Physics Quiz 4
Originally Posted by John View Post
F = sqrt(36 + F2^2)
F2 ~= 2.491 N
Excellent.
Excellent. You have asked the $64K question.
If you assume that the coefficient in any given direction is not increased by force components not in that direction, then the answer is that the block will start to slip when F2=2 Newtons. See attached "solution.pdf".
However, these 2 assumptions:
1: linear change in mu for angles between 0 and pi/2, and
2: mu is not increased by force components not in direction being considered
are I think open questions.
In FRC, there are wheels which are said to have different mu in the forward and sideways directions. I have looked but never seen any test data to show what happens when force is applied at a variety of angles between 0 and pi/2.
Unread 17-12-2011, 21:45
WPI Freshman
AKA: Alex
Re: Physics Quiz 4
Jason
Top view with respect to what, though? The table, or the plane the forces are acting on? The ambiguity of the question leaves it perfectly open to interpretation that the table is flush with any of the six faces of the block. Assumptions are useful in solving situations like this, but they can also lead to highly erroneous answers if they are wrong.
Unread 17-12-2011, 22:23
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Physics Quiz 4
Its better that I make that mistake here than on the AP exam
The plane on which the forces are acting and the table are the same plane, the normal force is perpendicular to that plane, the direction of gravity, irl, is down with respect to an observer in the same gravitational field as the object in question. since we are looking from the top, down can be assumed to be away from us.
Unread 18-12-2011, 02:18
Molten's Avatar
AKA: Jason
Re: Physics Quiz 4
Agreed. Try solving such problems without making assumptions though. I've never had a professor explicitly spell out every detail of a problem. They always leave it up to the student to make a few assumptions. In a real world example, you never know all the details. Just learn what you can and do your best from there.
Jason
Unread 18-12-2011, 08:34
JesseK's Avatar
FRC #1885 (ILITE)
Re: Physics Quiz 4
Jason
Furthermore, in the 'real world', half the time we don't know what assumptions we're even making, yet somehow the work has to get done.
GitHub
