Go to Post how can anyone Not Notice An entierly Pink Team? - Tytus Gerrish [more]
  #61   Spotlight this post!
Unread 18-12-2011, 00:22
AdamHeard's Avatar
Lead Mentor
Re: pic: Team 3647 West Coast Drive
Originally Posted by Mk.32 View Post
Well taking the feed back from above, here is take 2.
Literally a bearing block. With a pocket cut into the rail that allows it to slide about .25inch for tensioning. And two 1/8 plates that hold it in place.
Can we see it without the frame?
I personally prefer to tap the block and have each flange on held separately, but that's obviously up to each team to decide.
  #62   Spotlight this post!
Unread 18-12-2011, 00:50
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Here it is without the frame.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
  #63   Spotlight this post!
Unread 18-12-2011, 12:05
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Is the block+plates design better than just the plates at holding the bearing axes collinear just because of the added material constraining the bolts, or is there a more complicated explanation?
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
  #64   Spotlight this post!
Unread 18-12-2011, 12:20
Chris is me's Avatar
AKA: Pinecone
Both bearings are partially pressed into the same piece of material.
  #65   Spotlight this post!
Unread 18-12-2011, 13:51
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
The bearings are pressed into the same bore, so they are definitely coaxial.
I think that if the slots are cut in the frame rail that the plates become superfluous. Mk. 32, you may consider using flanged or heavy hex bolts and/or washers and omitting the side plates.
  #66   Spotlight this post!
Unread 18-12-2011, 19:29
Basel A's Avatar
AKA: @BaselThe2nd
Ah, I see. Makes sense. Thank you.
-Paul Copioli
  #67   Spotlight this post!
Unread 18-12-2011, 19:48
AdamHeard's Avatar
Lead Mentor
It really is a lot cleaner with the faceplates.
  #68   Spotlight this post!
Unread 19-12-2011, 09:07
Brandon Holley's Avatar
I think you've found a good solution there. Keep up the good work.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #69   Spotlight this post!
Unread 19-12-2011, 11:04
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
A few years ago, I had something like this bearing block fabricated for 931, courtesy of Jabba. He started with round bar stock.
Richard Wallace
since 2003
  #70   Spotlight this post!
Unread 19-12-2011, 11:25
Was that done on a manual mill?
That looks great and easy to make! Looks like you could do the bore on a manual lathe with a DRO and then the rest on a mill with DRO.
  #71   Spotlight this post!
Unread 19-12-2011, 11:41
AKA: Pinecone
Even a drill press with a DRO if you want. You don't need a mill with DRO to face the top and bottom flat.
Or maybe center punch holes using a template and then drill that way. Precision isn't terribly vital for this kind of part.
  #72   Spotlight this post!
Unread 19-12-2011, 12:45
Flats were made using a manual mill. But the first steps were cutting blanks from the round stock (band saw) and then facing and boring them so the bearings fit square (manual lathe).
And Chris is right, there are other ways to get the same result.
Richard Wallace
since 2003
  #73   Spotlight this post!
Unread 19-12-2011, 14:05
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
Threads like this are one of the reasons I love this website so much.
The idea that a guy can post his designs on a website and people from across the world can pick apart his design and give their input on how to improve it, while the OP willingly changes his design accordingly is pretty darn awesome.
I hope this design sees a lot of success. It definitely has the potential.
  #74   Spotlight this post!
Unread 19-12-2011, 14:22
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
McMaster # 9056K11 (or similar from a less expensive supplier) might be a good start for Richard's design.
Without a DRO, how would one check the bored diameter? Is the only way to start/stop the lathe constantly?
GitHub
  #75   Spotlight this post!
Unread 19-12-2011, 14:25
AKA: Pinecone
I would presume you'd drill the hole undersize and ream it.
