Go to Post Just because something has never been done, doesn't mean it's impossible. See: everything ever. - Taylor [more]
Unread 18-12-2011, 00:31
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Identify the Connectors
We're finishing up our prototype bot before Christmas but I have no idea where to get some of the connectors:
What do you call the cRIO Power Connector:
How about the Digital sidecar Power Connector:
Along with those two I need to get some Anderson connectors, where might these three be available?
Thanks,
- Alex
Unread 18-12-2011, 00:43
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Re: Identify the Connectors
2 pin is WAGO 734-102 http://www.andymark.com/product-p/am-0296.htm
4 pin is CTF040V8 http://www.andymark.com/product-p/am-0295.htm
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 18-12-2011, 00:46
lemiant's Avatar
the Dreamer
AKA: Alex
Thanks! Would those happen to be available at regular electronics shops?
Unread 18-12-2011, 00:52
College Mentor
AKA: Trent Borman
Unfortunately they are kind of specialty parts so not likely, you may be able to get them at digikey.
Unread 18-12-2011, 08:15
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
You can get all three at AndyMark http://www.andymark.com/category-s/384.htm
AM-0295, AM-0296, AM-0456
Unread 18-12-2011, 10:11
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
keep in mind that you will need 2 of the cRIO connectors... one for the power supply board, one for the cRIO.
Unread 18-12-2011, 12:20
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Also to note... the new Compact RIO (4-slot) has a different power connector. I'm not sure about the 2012 Power Distribution board. You may want to wait and find out, so you don't have to have 2 orders.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 18-12-2011, 13:59
Correct, 4-slot has a different connector(2 connections instead of 4). Ours came with the connector.
Unread 19-12-2011, 08:21
Alex,
It is unlikely that a local shop in Calgary might have these. A local supplier that sells Crio would but they may only deal with PO accompanied will call orders. First do a search and then make a call if there is a local supplier. AndyMark carries them because they are to find.
Unread 19-12-2011, 12:29
lemiant's Avatar
the Dreamer
AKA: Alex
Thanks for all the info. Could we use some kind of single pin connectors to duplicate the functionality of these connectors? It doesn't have to be pretty, we would just like to get this thing running before Christmas.
EDIT: I just went downstairs and broke open a PWM cable. It looks like the metal connector inside will work fine . Do all PWMs have the same metal connectors encased in the plastic, and will the wire be large enough gauge for powering these two pieces of electronics?
- Alex
Unread 19-12-2011, 13:02
...we would just like to get this thing running before Christmas.
What happened to the connector the cRIO came with?
Unread 19-12-2011, 13:14
lemiant's Avatar
the Dreamer
AKA: Alex
As a result of the "New cRIO's don't work 'til kickoff" situation, I borrowed this one from the other team in Calgary (Thanks Bishop Grandin, 1482!). What they did with the connector is anyone's guess.
Unread 19-12-2011, 14:11
Alex,
I don't think they are the same diameter as the PWM cables. As my daddy was fond of telling me...Use the right tool for the right job. Since everything in that little box depends on power why screw it up over the lack of the right connector.
Unread 12-01-2012, 17:35
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Does anyone know what the new 2 pin power connector on the CRIO II (4 slot) is/where to get a replacement?
Unread 12-01-2012, 17:51
It's available from AndyMark. http://www.andymark.com/product-p/am-2076.htm
