Go to Post Obama's got to stop saying all of these FIRST like statements and should just give us money and show up at Championship. - Chris is me [more]
Unread 19-12-2011, 14:03
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
pic: Sheet Metal Chassis Prototype
Unread 19-12-2011, 14:06
Re: pic: Sheet Metal Chassis Prototype
Is your gearbox plate integrated into the frame?
If so, nice stuff. You've got a great start here, better than most.
Start out by extending your flanges a little further at the end pieces
Unread 19-12-2011, 14:07
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
Any particular reasons why you don't want to use rivets? I'm just curious.
Unread 19-12-2011, 14:10
FRC #1836 (MilkenKnights)
Really nice job. I'm also wondering why you decided against rivets, and against dropping the center wheel.
Unread 19-12-2011, 14:25
Chris is me's Avatar
AKA: Pinecone
Regardless of the reasons, this is an excellent chassis given those constraints. Nice job. How does the gear ratio look?
Unread 19-12-2011, 15:11
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
I too am wondering the same thing. It looks like a CIMple Box with that direct drives 8" wheels (custom hex output shaft?). If this is in fact the case, this robot likely will not have enough torque to initiate movement of a 150 pound robot (battery and bumpers included), or you will not be able to reach a max speed given the length of the field. Correct me if I'm wrong.
Edit: I realized that the Toughbox mini has a very similar look to the CIMple box, in which case the gearing (depending on which gears you chose) is probably reasonable for a FIRST robot. I'm still curious what the ratio is, and what speeds you expect.
Unread 19-12-2011, 15:23
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Increase the flanges on the front and back to add more metal. Consider bending another return flange. Select the aluminum type: 1100, 3003, 6061-T0-T6 or 5052-H32 then check you minimum bend radius with the people who are going to bend your parts.
Needs a integrated belly pan to stiffen the chassis. Add some joggles on the length to make it stiff. Consider a separate electronics panel so you can preassemble your electronics
Don't forget the mounting points for the manipulator.
Needs quick release bumper brackets and battery box
Add clearance through holes to tigthen the CIM on the transmission.
Loctite your nuts before competition.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 19-12-2011, 19:07
Thanks for the feedback!
the gearbox is a toughbox mini with a 10.7:1 ratio built into the 1/8"" aluminum, this is a bit more reduction than we had last year and it worked great! by great, I mean we though it was the 2nd best drivetrain on the field! (2nd to 141 who had some crazy hyperspace swerve drive which after looking at for about 10 minutes, I still couldn't comprehend! I will now work on the modifications making this a more feasible, and realistic design! For the belly-pan, would there be anything wrong with using 1/2" Birch Plywood? It would be lightened and might end up lighter than aluminum, I will find out!
2011 Record (11-3-0)
Unread 19-12-2011, 19:30
also, how much larger should the flanges on the ends be, currently they are 3/4", wound 1" be acceptable?
Unread 19-12-2011, 20:24
Make the flanges on the front/back of the bot 1.5 - 2" long, and then take the edge and bend a 1/2" flange down from that.
Take another set of the plates that you are using to strengthen the drivetrain tube and put them on the bottom. This will help a lot with strength.
Birch will be fine. You can attach electronics to it quite nicely with some industrial grade double stick tape. The birch will keep your frame square and help prevent the front from bending in when you hit things.
Unread 19-12-2011, 20:38
Aidan S.'s Avatar
Aidan S. Aidan S. is offline
2013 World Champions!
FRC #0610 (The Coyotes)
Aidan S. is just really niceAidan S. is just really niceAidan S. is just really niceAidan S. is just really nice
I would suggest using 1/8th inch lexan for the belly pan. It's lighter than wood and more flexible, so it has less of a chance of cracking if you get hit really hard or flip over (I hope that won't happen ). Also, you can easily attach your components with zip ties (or screws, if you like). We went with 1/8th inch lexan last year, and were very satisfied with the results.
2013 Galileo Division & World Champions with 1241 and 1477 #TheTheoryOfTexanCoyotes
2012 - ????: Mentor, Team 610 2009 - 2012: Student, Team 610
2013 - ????: Strategy Adviser, Team 1310
Thanks to all the great alliance partners through the years: 67, 188 x4, 191 x2, 488, 469, 578, 842, 862, 1212, 1241, 1305, 1310 x2, 1325, 1334, 1511, 1535, 1477, 1559 x2, 2122, 2168, 3161, 3360, 3396, 3476, 3609, 3756, 4124
Unread 19-12-2011, 20:42
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Originally Posted by Hawkeye610 View Post
It's lighter than wood and more flexible, so it has less of a chance of cracking if you get hit really hard or flip over.
I believe the point IS rigidity. Without the rigid base would this still work as well? Was your bot a sheet metal bot?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 19-12-2011, 20:58
Aidan S.'s Avatar
No, our robot was not sheet metal, but since every almost every FIRST game required some sort of manipulator to be built on top of the drivetrain, those structures would act as a sort of crossbar than reinforced the drivetrain anyways. Since the lexan would save weight, crossbars could be installed on the drivetrain beforehand anyways, and it would still weigh less than with a wooden bellypan.
Unread 19-12-2011, 21:23
Ninja_Bait's Avatar
AKA: Jake Potter
Silly me, we were next to each other in the Galileo pits. I should have remembered.
However, I think that the crossbeams tend to be a nuisance that can actually warp the frame instead of strengthening it, so be careful about that. This'll also depend on the game and the OP's design style. If you plan to design the manipulator beforehand (which you should), you can plan for rigidity from your crossbeams. If you plan to use the infamous rule of fudge and just do it on the spot, you should have a rigid base to build on.
Unread 19-12-2011, 22:17
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
we just built a prototype chassis for offseason (yes it was sheet-metal). And we used lexan in the middle for the electrical board. Lexan is a great way to strengthen the chassis (even though i dont think we needed it). I would recommend rivets, as we just used them for the first time and they seem to be very strong.
Why are you using an omni wheel? Is the center wheel lowered? How thick are the spaces between the lightening holes?
Cool Chassis though
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
