Go to Post Unfortunately, you cannot always tell when some things are jokes on forums, because we only can rely on text and a limited number of smilies. - artdutra04 [more]
Unread 19-12-2011, 15:11
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: pic: Sheet Metal Chassis Prototype
Originally Posted by Chris is me View Post
How does the gear ratio look?
I too am wondering the same thing. It looks like a CIMple Box with that direct drives 8" wheels (custom hex output shaft?). If this is in fact the case, this robot likely will not have enough torque to initiate movement of a 150 pound robot (battery and bumpers included), or you will not be able to reach a max speed given the length of the field. Correct me if I'm wrong.
Edit: I realized that the Toughbox mini has a very similar look to the CIMple box, in which case the gearing (depending on which gears you chose) is probably reasonable for a FIRST robot. I'm still curious what the ratio is, and what speeds you expect.
