| Thread Tools |
Rating:
Display Modes |
#76
Re: pic: Team 3647 West Coast Drive
I like to take a 'skin' cut, measure the ID I just machined, subtract from the ID want to reach, and count turns/notches on the drive handles. Edit: Chris' suggestion is also a good one. Assuming you're going to make many holes that size it is definitely worth investing in a reamer. Last edited by JamesCH95 : 19-12-2011 at 15:03. |
#77
Boring part by part is possible, but an FRC team who plans to start making custom parts should purchase the specific undersize reamer for the bearing. We really only use two size bearings on 95% of 973's robots, so it was a great investment (same for broaches, etc...). |
#78
Jesse is right, there are cheaper sources. I change my password more frequently now, to make it more difficult for Jabba to place unauthorized McMaster orders. He prefers them because they deliver his material next day. ![]() |
#79
For the press fit bearings, should the hole be something like .001 inch undersized? Or the same as the bearing diameter?
We have an HAAS CNC we can use, I am not sure if we have any reamers so I planed to just bore them out with a 1/2 milling bit. |
#80
The fastest way will definitely be to get close and then ream. It will probably give you decently repeatable results as well. We are fortunate enough to have a set of bore micrometeres at our disposal. They are extremely nice, and extremely expensive. We only allow experienced machinists to handle them and use them. They do make checking bore sizes a breeze though, and in our experience, are extremely eaccurate. -Brando |
#81
is there any way of doing it with the wheels being off centered?
#82
If you mean that your wheels don't have the axles in the center, well, that ought to provide some comedy to anybody watching you bounce around a lot. |
#83
