Go to Post Be thankful for what you have, not frustrated with it because it doesn't exactly suit your needs. - sanddrag [more]
Unread 19-12-2011, 20:25
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Re: Center Drop on 6WD 1/8 or 1/16
Some of the things to consider are:
-Rubber material and how much it will compress.
-Type of wheel. Might not need drop if using omnis at one of the ends.
-Distance between centers of the wheels. The further out the more difference there is in the "rocking" of the robot. (As pointed out, less rocky as you spread out the wheel base)
-Frame deflections, if any. Not much of a problem if your have a nice and rigid frame.
From my experience I suggest you go with 1/8" drop on the center wheel. I have also used 3/16" in the past. I don't think 1/16" is enough in my opinion, and depending on your specific set up, you might encounter difficulty turning.
Keep in mind that the center drop mainly affects how much your robot rocks back and forth. While driving, depending on your mass distribution, you will always be riding on the front or back 4 wheels.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Last edited by David Guzman : 19-12-2011 at 22:07. Reason: Clarification, thank you Ninja_Bait.
