Go to Post "Find a problem? Think of the three I's: Invent and Innovate to Improve!" - yash101 [more]
Unread 20-12-2011, 13:32
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
pic: I was bored... so I designed this.
Unread 20-12-2011, 13:33
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: I was bored... so I designed this.
Any particular reason you are cantilevering the wheels on the swerve modules? Any time a bevel gear is involved, you generally want to be as structurally rigid as possible.
Other than that, looks like a great design and a fantastic render.
Unread 20-12-2011, 14:58
FRC #1836 (MilkenKnights)
Amazing design and nice render. Also, the cantilevered wheel is so that the drivetrain can perform like wcd and swerve.
Unread 20-12-2011, 15:06
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Careful ... WCD takes advantage of cantilevered design by pushing the wheels out as wide as possible; it's so far that it's not possible to put pieces of the frame outside of the wheel base unless the frame is above the top of the wheels. Doing so greatly aids in stability and turning. By design, setting the wheel base width as wide as the frame is not possible with coaxial swerve. Thus, the only benefit of this design is easy swap of the wheels (and potentially reduced manufacturing time) -- which, IMO, doesn't outweigh the benefits of a boxed swerve module.
Very sweet render nonetheless.
GitHub
Unread 20-12-2011, 15:18
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
This point would only hold true if the wheel was further out in the chassis. As it sits right now, the wheel appears to be centered with the axis of rotation of the module. Odds are, the wheel was either cantilevered for weight or aesthetic purposes.
-Dustin Benedict
Unread 20-12-2011, 15:44
Chris is me's Avatar
AKA: Pinecone
I don't want to "slam" anyone who works this hard, so please don't take this the wrong way, but I think this system has a few problems.
First, your modules. Yes, cantilevered wheels offer easier access, but they are not the end-all be-all most important drivetrain feature in FRC. The reason my team cantilevers wheels is mainly for simplicity and weight. Cantilevering wheels in a swerve drive saves negligible weight (maybe a half pound?) and makes the whole wheel and module significantly worse supported.
In 2008, team 148 built modules much like yours, but with a fully supported wheel. Even then, the modules wore through bevel gears, I'm assuming due to the modules twisting causing excessive tip loading. You'll notice teams like 1625 and 1640, two popular coaxial swerve teams, go to great lengths to make their bevel gear setup rigid. 1625 used a "puzzle piece" method of connecting 1/4" plates while 1640 uses gussets to connect a piece of U-shaped extrusion together.
It also looks like your module support is a bit lacking. It looks like you have a single thrust bearing mounted to a piece of 1/8" metal plate supporting all of the forces on the module. That's a pretty extreme cantilever. A lot of teams use a lower support for at least extreme loading, or they support their modules in multiple places / over a wide area. Think carefully how you want to do this.
Swerve drives are tricky - that's why even well funded teams with many engineers don't get them right.
Unread 20-12-2011, 16:57
Garret's Avatar
AKA: Garret Smalley
Thanks for all the complements about the render and design.
I cantilevered the module just for fun and aesthetics of the module.
I have attached a section view of the module (not mounted to frame and without bolts). There may be support issues still but I did try to take into account as many of the load issues as possible.
(the image is a little squashed so it looks a little off)
About the module itself:
The main body of the module is machined out of a 3" long piece 5"x3"x1/2" Aluminum Angle. The top of the main body of the module is adapted from my teams current swerve drive module design. Also I did not want to cantilever the bevel gear so I went ahead and supported the bevel gear shaft on both ends. (This module was designed just for fun really so there may be issues I am unaware of). I welcome any advice and comments about the design.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 20-12-2011, 19:29
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Just out of curiosity, what are the benefits of 6 wheel swerve over 4 wheel swerve?
Unread 20-12-2011, 19:35
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
The benefit of a six wheel swerve over a 4 wheel swerve is that the six wheel can act like a standard 6WD.
Unread 20-12-2011, 19:45
Aren_Hill's Avatar
Build Nifty Things
that's only really an advantage compared to swerves that can't independently steer each wheel
A guy who likes robots.
Unread 20-12-2011, 19:59
Was 1625s 6 wheel swerve coaxle?
Unread 20-12-2011, 20:01
craigboez's Avatar
Mechanical Engineer
I don't understand. Why would you go to the trouble of building an extremely complicated drive so it can approximate the functionality of a very simple drive?
Aren_Hill's Avatar
Build Nifty Things
I'll let the search function handle that question
Unread 20-12-2011, 20:07
Found it.
Unread 20-12-2011, 22:32
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Because it gives you swerve capabilities, but without the downsides of a 4wd. One of the significant downsides to a typical coaxial 4wd swerve is that it cannot turn on it's center very well (skid steer), for the same reasons that a 4wd has a harder time turning around it's center than a 6wd (if this concept is unfamiliar to you, there are many threads on CD that discuss the physics behind this, go look them up).
There are two main solutions to this: 1) do a module style (non-coaxial) swerve or an independently driven (ala Emperor Swerve by 973) which allows the wheels to always turn such that they are not skidding when making a center turn or 2) make your code so that you don't make turns like that most of the time (as 40 used to do, with quadra-steer).
If you add the extra set of dropped center wheels, you get all the benefits of a swerve drive, but you still have the non-swerve driving characteristics of a 6wd.
