Go to Post Haha, I applaud your efforts to read into the actions of the GDC, but I feel like trying to do so is like shooting at a target, in the dark, at a mile away, with a sawed off shotgun. - ttldomination [more]
Unread 20-12-2011, 18:05
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
Robot getting disabled?
I just managed to deploy the code to the cRIO. For some reason, my sample code doesn't seems to be firing.
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the SimpleRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class RobotTemplate extends SimpleRobot {
     * This function is called once each time the robot enters autonomous mode.
    public void autonomous() {
        RobotDrive drive = new RobotDrive(1, 2);
        for (int i=0; i<4; i++){
            System.out.println("Running drive " + i);
            drive.drive(0.5, 0);
            Timer.delay(2);
     * This function is called once each time the robot enters operator control.
    public void operatorControl() {
Here's the last 2 entry in the log:
[cRIO] Default robotInit() method running, consider providing your own
[cRIO] Default disabled() method running, consider providing your own
Also BTW how do I compile on linux and deploy on windows? (I'm fine with ant)
Unread 20-12-2011, 18:51
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Robot getting disabled?
I don't see what the problem is - you didn't define the methods robotInit() or disabled(), so the default ones are used, which just print the messages you're seeing. From what I'm seeing, the robot shouldn't do anything until autonomous is enabled, and then it drive forward at half power for 8 seconds.
As for compiling on linux and deploying on windows, I believe that deploying simply entails FTPing onto the robot (which is simpler than it sounds, you just use windows explorer) and putting the correct file in the correct place. So, once you figure out the correct file, you can just copy that from linux to windows.
Unread 20-12-2011, 19:01
How would I enable autonomous mode?
Unread 20-12-2011, 20:03
WizenedEE's Avatar
AKA: Adam
Once the code is loaded onto the robot, you start up the driver station, press the autonomous switch, then press enable.
Check out here for more info about how to "do" the control system. The "installing the driver station software on a non-classmate" may be helpful if you don't have it. This may also be helpful.
Unread 25-12-2011, 02:49
Kevin Wang's Avatar
Kevin Wang Kevin Wang is offline
Software Engineer, Webmaster
FRC #0694 (StuyPulse)
Kevin Wang is an unknown quantity at this point
As a side note, I recommend making drive an instance variable so that it can be accessed from other methods as well.
Unread 26-12-2011, 23:25
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
we usually use iterative mode, but isnt there supposed to be a main method that calls the mode? Making a guess here, being that its been a while since ive looked at simplerobot
