Go to Post We need to grow smart not grow fast. - Andrew Schreiber [more]
Unread 20-12-2011, 13:38
Physics Quiz 5
See attached PDF "Problem Statement".
Page 1 is a diagram.
Page 2 has the assumptions and problem statement.
Unread 20-12-2011, 17:00
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Physics Quiz 5
I'm having trouble visualizing the wheel orientation.
Unread 20-12-2011, 17:26
Re: Physics Quiz 5
It's a standard-wheel vehicle. The wheels are not steerable. All four wheels are oriented "forward" (the front of the vehicle is labeled in the diagram).
Unread 20-12-2011, 17:59
Re: Physics Quiz 5
No, not quite that easy. But not too much harder. The vehicle is in static equilibrium. The wheels are not accelerating. Therefore, the net torque on each wheel (in the plane of the wheel) must be zero. Your solution does not satisfy this physical requirement.
Originally Posted by quinxorin View Post
It can't be this easy.
A)
Fy=Fx=(T*sqrt(2))/(2r)
and
F=T/r
B)
T=μNr
Work:
Part A:
T=Fr
(F is the same as force applied by vehicle)
T/r=F
Because the wheels are in a square, theta (here "x") is 45degrees:
Fy=Fx=Fcos45=Fsin45=F(sqrt(2)/2)
Part B:
F=μN
T=FR
T=μNr
Unread 20-12-2011, 18:23
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Physics Quiz 5
It would appear that friction is trying to crush your robot into a diamond!
Unread 20-12-2011, 19:36
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Physics Quiz 5
I know I'm doing something wrong.
1. The wheel applies a force of Tau/R in the y direction. There is no motion in the wheel so Fy must equal Tau/R.
2. There is no motion of the robot, so there must be a torque to resist that generated by Fy, namely that generated by Fx. Fx and Fy are at the same distance from the CoM and at opposite angles to the moment arm, so they must be equal in magnitude.
3. F is the magnitude of Fy added to Fx: Tau*sqrt(2)/R
4. To rotate, Fy must exceed Fx. This yields a net torque in the clockwise direction, which is what I assume is the goal.
5. Fy>Fx
6. Tau/R>muN
7. Tau>muNR
I have a problem with my answer for B because I feel like Tau/R should not exceed the maximum static friction, because then there would be a lot of wheel spin, which doesn't click for me. I also realize it's what quinxorin already posted. I just don't know how to do it otherwise.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 20-12-2011, 19:45
Re: Physics Quiz 5
See notes in red below:
1. The wheel applies a force of Tau/R in the y direction. the component of the floor's reaction force on the wheel in the Y direction is tau/r There is no motion in the wheel so Fy must equal Tau/R. correct
2. There is no motion of the robot, so there must be a torque to resist that generated by Fy, namely that generated by Fx. Fx and Fy are at the same distance from the CoM and at opposite angles to the moment arm, so they must be equal in magnitude. correct
3. F is the magnitude of Fy added to Fx: I assume you mean vector addition. Tau*sqrt(2)/R correct
Here's where you go off the rails:
5. Fy>Fx
6. Tau/R>muN
7. Tau>muNR
Unread 20-12-2011, 19:47
Ninja_Bait's Avatar
AKA: Jake Potter
Re: Physics Quiz 5
Yeah, that's what I figured. :\
Let me try again:
At equilibrium, F=muN
Tau*sqrt(2)/R=muN
Tau=muNR/sqrt(2)
If Tau is any greater, it will overcome F?
Last edited by Ninja_Bait : 20-12-2011 at 19:52. Reason: I think I figured it out.
Unread 20-12-2011, 20:12
Re: Physics Quiz 5
Notes in red below:
Let me try again:
At equilibrium, at the "edge" of equilibrium, just before things break loose F=muN correct
Tau*sqrt(2)/R=muN correct
Tau=muNR/sqrt(2) correct
If Tau is any greater, it will overcome F? correct!
Unread 20-12-2011, 20:14
Ninja_Bait's Avatar
AKA: Jake Potter
Re: Physics Quiz 5
YAY! I can do physics!
Unread 20-12-2011, 22:27
Re: Physics Quiz 5
solution attached
