Go to Post communication at its best = quick, brief, clear - JaneYoung [more]
Unread 21-12-2011, 00:44
Arthur's Avatar
Arthur Arthur is offline
FRC #1625 (Winnovation)
Arthur is on a distinguished road
Team 1625 8 Wheel Drive Prototype
This is the 8 wheel prototype team 1625 has been working on for the past few weeks. One wheel is driven straight off of the gearbox, and chains run from the sprockets on that axle to the other wheel assemblies on that side, as pictured above. The wheel assemblies are half inch steel axles with two 21 tooth sprockets welded to them and a 3" colson pressed on the end. They slide through two bearings in the frame tube and have a snap ring on the back side. The chains are currently just tensioned by the proper center to center distance, but on the next iteration we plan to use bigger wheels to allow for ground clearance with idler sprocket tensioners. There is also an extended section of the gearbox shaft to allow for easy encoder mounting.
Specifications:
3/16" Center Wheel Drop
13.5 Feet Per Second Calculated Speed
Single Speed Gearbox
41 Pounds With Electronics
3" by 7/8" Colson Wheels
Unread 21-12-2011, 01:59
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
Re: Team 1625 8 Wheel Drive Prototype
I like it! Simple and clean looking! Those 3 inch colsons look awesome pressed on with the gears!
-Dave
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
Unread 21-12-2011, 05:34
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Elegant. I imagine it handles well.
How did you cross-brace the frame?
Richard Wallace
since 2003
Unread 21-12-2011, 06:32
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Those chains look too close to the ground for comfort. But cool bot anyway!
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 21-12-2011, 07:06
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
I agree, especially since only two wheels are truly driven. Having 75% of the drive train without direct connection to the transmission would make me a bit queasy, but then again, I'm not Winnovative.
I love those gearboxes.
Hi!
Unread 21-12-2011, 07:59
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I really like what you guys did with the one piece axle/colson hub/sprocket. How much does the entire shaft assembly weigh without the wheel?
-Dustin Benedict
Unread 21-12-2011, 09:06
Brandon Holley's Avatar
Very nice.
What is the final ratio to the wheels? (nvmd somehow missed your little follow up underneath the pictures)
I cant quite tell from the picture, #25 or #35 chain? Follow up question- tensioning?
Looks slick!
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 21-12-2011, 09:26
I feel like we talked to Aren and Foss about the single piece assembly a few weeks ago
Unread 21-12-2011, 16:54
Dillon Carey's Avatar
Dillon Carey Dillon Carey is offline
6wd swerve, it has been done
AKA: TinyHippo
Dillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond repute
It's obviously the two pieces of plywood that are zip tied on.
"More power 'till it breaks or you win."
- Keith Carey
Unread 21-12-2011, 18:07
Katie_UPS's Avatar
Katie_UPS Katie_UPS is offline
AKA: Katie Widen
Katie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond repute
Originally Posted by Brandon Holley View Post
Very nice.
Between seeing a lot of 35 lately and knowing typical winnovation, I'm 99% sure its #25.
As for tensioning,
Its pretty easy to miss the text under the pretty pictures.
Unread 22-12-2011, 18:47
Lightfoot26's Avatar
Lightfoot26 Lightfoot26 is offline
Just Out For A Rip, Bud...
AKA: Seth Lightfoot
Lightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really nice
That wiring sure is a thing of beauty.... lololololol
Winnovation Team 1625 (2010-??)
  • Electrical/Programming Captain (2011-2013)
  • Auxiliary Driver (2012-2013)
  • Team Captain (2013)
  • Alumni (Graduated May 2013)
  • Electrical and Programming Mentor (2014-??)
Unread 22-12-2011, 18:52
Ninja_Bait's Avatar
AKA: Jake Potter
It looks like it would be a bit of a pain to service, with all the wires going in and out of holes and tubes and things. It looks nice, but it seems like too much trouble for not enough gain.
Unread 22-12-2011, 19:00
AKA: Seth Lightfoot
on the contrary my dear friend, you have yet to see the bottom, plus I had labeled them all ect. ect. it was a very meticulous process... PLUS do it right the first time... you won't have to service it
Unread 26-12-2011, 11:58
Arthur's Avatar
The frame is cross braced by two welded 2X1 tubes. They're about 6 inches in from either side, but we probably plan on changing that depending upon the game.
Thanks! We thought that would be a nice way to make it simpler all around. According to the CAD, the it weighs about .3 pounds.
Looks slick!
-Brando
Thank you! We used #25 chain, and it seems to work out well. The middle chain runs are a little bit less tensioned than we would like, but we plan on fixing that when we add the bigger wheels. Even though it is a little bit loose it still has never fallen off.
Unread 27-12-2011, 04:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
2001-2004: Team 100
2006-Present: Team 254
