Go to Post FIRST is like we have traveled to the future, and we dont like what we saw when we got there. So we came back and now we are attempting to alter the future - KenWittlief [more]
Unread 19-12-2011, 19:30
HammadB's Avatar
HammadB HammadB is offline
FRC #0295 (Renevatio)
HammadB will become famous soon enough
Center Drop on 6WD 1/8 or 1/16
What goes into to determining what amount of center drop to have on a 6WD. What factors should you consider?
Unread 19-12-2011, 20:25
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Re: Center Drop on 6WD 1/8 or 1/16
Some of the things to consider are:
-Rubber material and how much it will compress.
-Type of wheel. Might not need drop if using omnis at one of the ends.
-Distance between centers of the wheels. The further out the more difference there is in the "rocking" of the robot. (As pointed out, less rocky as you spread out the wheel base)
-Frame deflections, if any. Not much of a problem if your have a nice and rigid frame.
From my experience I suggest you go with 1/8" drop on the center wheel. I have also used 3/16" in the past. I don't think 1/16" is enough in my opinion, and depending on your specific set up, you might encounter difficulty turning.
Keep in mind that the center drop mainly affects how much your robot rocks back and forth. While driving, depending on your mass distribution, you will always be riding on the front or back 4 wheels.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Last edited by David Guzman : 19-12-2011 at 22:07. Reason: Clarification, thank you Ninja_Bait.
Unread 19-12-2011, 20:34
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Correction: You'll rock more when the edge wheels are closer to the center; just do some geometry to see why.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 19-12-2011, 23:55
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
In a prototype of ours, we tried 1/16 drop with roughtop tread on a 6WD with 4" wheels and there was too much resistance when turning. 1/8 works pretty well in our experience.
Unread 20-12-2011, 00:52
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
1/16" is not going to work at all unless we have a game like 09 again.
2001-2004: Team 100
2006-Present: Team 254
Unread 20-12-2011, 00:55
Aren Siekmeier's Avatar
on walkabout
What type of wheels did you use?
We have done 1/8" drop with 6 plaction wheels. We had no difficulty turning, but the rock was certainly noticeable. Depending on what else the robot is doing this may or may not be a problem.
Unread 20-12-2011, 00:57
HammadB's Avatar
I should have been more specific, , I meant any drop really, and what considerations should be taken in determining the magnitude of the drop
on walkabout
In which case there's no reason to drop the wheels at all... Sounds like 1/16" is just too little. I assume this is with the rubber tread you guys usually use.
Unread 20-12-2011, 01:05
AdamHeard's Avatar
Lead Mentor
Why not drop for an 09 style game?
Unread 20-12-2011, 01:51
on walkabout
I guess it's something I never even really thought about, it seemed obvious. My thinking was that because the wheels that year slid sideways with no issues there was no reason to restrict your contact to four wheels. Upon actually thinking about it makes sense that you might want to still put all of your limited normal force on those wheels to make turning more effective...
And upon looking at some of the 6 wheeled robots that year particularly for that detail I see that indeed teams (including you guys... ) used a drop (or a raised outside wheel).
Unread 20-12-2011, 02:14
Gray Adams's Avatar
We used AM 4" performance (with rough top). There's noticeable tread wear on the outer wheels as compared to the center wheels as well from the excessive dragging.
Side note: The Andy Mark CAD for the wheels shows less material around the center than the actual wheel has. Not a huge problem, but it did cause some surprises when we got our hands on the wheels.
Unread 20-12-2011, 02:15
Our wheels wore down in 2009 until there wasn't a drop any more.
Unread 21-12-2011, 21:16
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
A better question would be, why drop? Dropping's downside is the naturally rocking, and there wouldn't be much of an upside due to the naturally low friction. If the rocking potentially messes with the ball sucker mechanism and costs you quite a few points, would it be worth the... whatever the gain is?
Attending: MN Duluth Regional
Unread 22-12-2011, 02:18
AdamHeard's Avatar
Lead Mentor
The improved turning of course (and the rock caused zero detriment to our intake).
Low friction doesn't change the dynamics of how a drivetrain turns much (as the friction is still the same in the x-y axis more or less). A wider base still turns better than a narrow base.
