Go to Post I, as a programmer, always strive to have the entire robot operate with as little driver input as possible. Those pesky humans.... - dellagd [more]
Unread 21-12-2011, 13:22
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
Non joystick control?
is it possible to use keyboard to drive? We have some parts but no joystick at the moment.
Unread 21-12-2011, 13:32
Re: Non joystick control?
Can't use a keyboard, but you could use most USB game controllers if you have one from home you could borrow.
It's possible to rig up custom controls through the Cypress board, but doubtfully worth the trouble.
Autonomous could be run without joysticks, but not controlled by a driver.
Unread 21-12-2011, 14:55
Aren Siekmeier's Avatar
on walkabout
Has anyone ever played around enough to see (or just knows) if the driver station/FMS framework could support sending keyboard info/events to the robot, such as by modifying (or writing a new one from scratch) the driver station runtime? I assume that as soon as the driver station software is modified its no longer legal, but just curious.
Unread 21-12-2011, 15:15
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
The drive station isn't open source. I think there have been some open source, team generated duplicates of it that could accomplish that, but it would be easier to write the code on the dashboard to use a free port to send the data.
Unread 21-12-2011, 23:34
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
The new SmartDashboard will support extensions. As long as it does not break any explicit rules (none that I know of), it will be possible to create a custom widget which reads keyboard values and sends it back to the robot using the new NetworkTable protocol. All in all, that means approximately 20 lines of code (besides the boiler-plate class definition), and a few on the robot depending on what control you want.
Unread 22-12-2011, 00:54
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Originally Posted by RyanCahoon View Post
This software that allows mapping of keystrokes to a virtual joystick device.
Works great with modular USB numpads.
--Ryan
FRC 766, 2015-, Mentor
Last edited by RyanCahoon : 22-12-2011 at 01:05. Reason: Removed AutoHotkey link. I think it might only work for Joystick->keyboard, not the other way
Unread 22-12-2011, 23:44
on walkabout
--Ryan
That's a neat way to do it. Unfortunately, that particular one is an unsigned driver or some such thing so 64 bit Windows is unhappy with it. On further Googling I found this which appears to have the same functionality and at the very least installs successfully on 64 bit Windows. No guarantees about it working yet, as I don't have a robot or any games to test it on.
