Go to Post Oh, please, please, GDC! Give us a corn game! - Richard Wallace [more]
Unread 22-12-2011, 04:30
13or13 13or13 is offline
FRC #2213
13or13 is an unknown quantity at this point
motoring the wheels
Hi.
Our robot has 6 wheels on it, but we dont know how to motor the wheels.
Should we motor the middle and the back wheels, both attached to the same motor, and the front wheel is connected to the middle wheel.
The other option is to motor only the middle wheel, while the back wheel and the front wheel are free.
For both things we have good and bad thoughts, and we have no idea which one we should choose.
Unread 22-12-2011, 04:35
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: motoring the wheels
If you motor the middle and the back you'll actually produce a different torque when rocked one way over the other.
Unread 22-12-2011, 04:57
jasonbrooks's Avatar
jasonbrooks jasonbrooks is offline
Team Captain
FTC #3540 (Roboboogie)
jasonbrooks is an unknown quantity at this point
If you do the back and middle, then use chains and create a chain drive. Alternatively, you can use a belt drive. Take a look at this ChiefDelphi white page: http://www.chiefdelphi.com/media/papers/2216.
Chain drives usually work well.
Unread 22-12-2011, 10:15
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I would say most teams probably do a chain drive of some sort.
Generally speaking, you probably want all of your wheels powered in some way - it really helps if you're being pushed, or are off balanced when climbing a ramp, or a dozen other situations that can lift one or more wheels off the ground.
Here's our setup for 6-wheel drive in the past (we've used it 3/5 years since the team started. The other two we used a 4 wheel design for Lunacy and Mecanum drive for Breakaway):
- Motors/gearboxes are placed on the rail near the middle wheel
- chains go from the gearbox to the middle wheel to power it
- two more sets of chain go from the middle wheel to the front and back wheels
This way, every chain wraps halfway around each sprocket, which helps prevent jumping your chain off the sprocket.
We've never direct-driven a wheel (where the output shaft from the motor is used as the axle for the wheel) - we feel that the failure modes for that are a little too risky, compared to running a short chain between the motor and the wheel.
Unread 22-12-2011, 10:18
spacepenguine spacepenguine is offline
AKA: Ian Hartwig
spacepenguine is an unknown quantity at this point
Our standard 6 wheel base has all 6 wheels powered. As long as you drop the center wheel, you shouldn't have a problem with turning and it will react nearly the same whether it's rocked forwards or backwards as long as the weight is distributed evenly. We also direct drive our middle wheels off of the gearbox shaft and then use belts to drive the back/front wheels. That way if all the belts break, we'll still be moving because the middle wheel should always be on the ground.
Alternatively, you can change the center of rotation on a tank drive by driving say the back 4 wheels and putting omnis on the front. This would be good if you had a rear mounted tower and wanted to rotate around the base of the tower, for instance.
2008-2011: #226 - The Hammerheads
Unread 22-12-2011, 11:31
Since this was the only post that actually answered what the OP was asking, I'll tack on a few pictures to help.
For the OP:
This is a direct drive, meaning the center wheel is mounted on the output shaft of the gearbox. The center wheels have double sprockets which then chain to the outside wheels. http://www.chiefdelphi.com/media/photos/32160
This is a 6wd made using the kit gearbox without direct driving the wheel off of the gearbox's output shaft. http://www.chiefdelphi.com/media/photos/34531
The output shaft of the gearbox has a double sprocket on it. Like this http://www.andymark.com/product-p/am-0421.htm
So, one of the sprockets chains to the back wheel and one chains to the center wheel. The center wheel has a sprocket on both sides. The center wheel is then chained to the front wheel which has another sprocket on it.
Here's another example: http://www.andymark.com/product-p/am-0959.htm If this had another sprocket on the center wheel and a sprocket on the front wheels, those could be chained together to create a proper 6 wheel drive.
Another example http://www.chiefdelphi.com/media/photos/29579
Hope that answers your question without any confusion.
Unread 22-12-2011, 13:16
EricH EricH is online now
330 tends to mount their gearboxes aft of center, then do a chain run to the center and another to the back wheel. Then another chain is run from the center to the front. This is best seen in http://www.chiefdelphi.com/media/img...05e54dc2_l.jpg, which is of our 2007 practice robot. (Also used in 2005 and I think 2008.)
We've also put it above the center wheel and run one chain to the center and back wheels and another to the center and front wheels on our 2006 robot: http://www.chiefdelphi.com/media/img...00d247fd_l.jpg
Unread 22-12-2011, 15:19
Found some pictures of our method, on a couple of different robots.
Last year:
http://www.chiefdelphi.com/media/photos/36210
http://www.chiefdelphi.com/media/photos/36211
2008:
http://www.chiefdelphi.com/media/photos/30269
http://www.chiefdelphi.com/media/photos/30266
Unread 26-12-2011, 11:41
FRC #2213
whoops, I guess I didn't explained my self good enough.
the options we are considering are either use chains that connect the back wheel to the motor, another chain that connects the middle and the motor, and a third one that connects the middle wheel to the front wheel.
the other option is to connect only the middle wheels to the motor, while the rest are free.
Unread 26-12-2011, 11:57
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
It's almost always a good idea to power all your wheels. Leaving unpowered wheels reduces your tractive force, since not all of the robot's weight is supported by powered wheels. It can cause problems with climbing, if your powered wheels get lifted off the ground. The same thing can happen during a pushing match. If an opponent even momentarily lifts you off your powered wheels, they will be able to carry you around the field on your free wheels with practically no effort.
This thread has some good ideas for how to do an all-wheel-drive setup like this in a six wheel drive.
Unread 26-12-2011, 12:12
Yes, use the first option. The second option has no benefits.
Unread 26-12-2011, 14:34
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
My team used a six wheel drive this season, and we motored the wheels that way. Worked perfectly.
Unread 31-12-2011, 14:38
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
reported.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
