Go to Post Throughout the "FIRST" experience we're all taught that if we try hard we'll achieve some level of success down the road; it hits everyone differently. - nlknauss [more]
Unread 15-12-2002, 23:35
aZnXsa1Nt aZnXsa1Nt is offline
aZnXsa1Nt is an unknown quantity at this point
Tools for Rookie Team?
Hey, this is Mark from the rookie Mission San Jose Robotics Team 1045.
We are currently in the process of obtaining tools and parts, and I was wondering if anyone could provide a comprehensive list of tools that are usually used in the process of constructing the robot. I would greatly appreciate any assistance on this topic. Thanks.
"you cannot bend the spoon- that is impossible. instead, try to understand the truth: there is no spoon."
Unread 15-12-2002, 23:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'll be able to help you with this in a few days. I'm really busy right now. Send me a PM if you want me to make up a list for you.
Unread 16-12-2002, 02:11
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
just a thought, but wouldn't this post go better in the Q&A section? And PMing a list to one individual is hardly helpful to the community. I'm sure there's tons of teams that need to know this kind of thing.
Unread 16-12-2002, 08:07
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Here ya go
Here is a list of tools to have for building a FIRST robot:
Minimum needed:
Wrenches: socket, allen, open-ended
Pliars: needle-nosed, adjustible, and vice-grips
Screwdrivers: Philips (large & small), regular (large & small)
Hacksaw
File (flat and rat-tail)
Side cutters (small and large)
Tin snips
Wire stripper
Wire crimper
Center punch or punch set
Hammer
Drill bits
Taps
Tap handle
Ruler
Calipers
Tape measure
Cable ties
Electrical tape
Duct tape (even though you can't use it on the robot, you will still need this)
Corded power drill
Cordless drill
Dremel w/ accessories
Soldering iron
Voltmeter
Level
Square (for getting right angles)
Vice
Other stuff that makes things easier:
Label maker
Sheet metal break
Sheet metal shear
Grinder
Sander (disk and belt)
Lathe
Mill
Drill Press
Welder (able to weld aluminum and/or steel)
Band saw (the bigger the better)
Chop saw (horizontal band saw)
Also... there are other things to consider when you are going to a competition. I attached an Excel file which lists that stuff.
There may be more to this list... please add to it if you see fit, of course.
Andy B.
File Type: xls list of stuff to take to competition.xls (23.5 KB, 113 views)
Unread 16-12-2002, 08:18
Perhaps a Q&A question, but...
beside the screwdrivers necessary for whatever type you choose, and drill bits and drivers, and a huge hammer for when frustration gets high :-), you might get by with these -
.carpenters square - things positioned well, work better
.measuring tape
.six-in electronic caliper
.scribe for marking and...
.black magic marker or machinist ink to lay out before cutting
.vice, *securely* mounted, bigger than 4"
.hacksaw with lots of new blades.
.files
,set of Allen Keys for existing setscrews
.V-block for drilling radially into round things
.weight scale - to check before the end of week 3
.wrench set - open ended types work fine on pneumatics and on nuts if you don't have a ...
.set of nut drivers
.locking jaw pliers in several sizes
.clamps - several sets of several sizes
.wire cutter-crimper (have come in past kits) - the importance of a good crimping cannot be over-emphasized. For stripping, a utility knife is quite often as useful as automatic strippers. AVOID the stamped/riveted cutter-stripper-crimper sold in kits with crimp-on connectors - 'useless' doesn't begin to describe a slightly used pair.
.hand held drill - we have several cordless ones (all at the *same* voltage - we have 12 V, which means we can test a motor with the drill batteries if needed)
very useful advances are :
drill press - (preferably with a vice, and a cross vice is even better)
band saw - with a "rip fence" and a miter guide
handy, but not essential for rookie teams, items include
lathe
mill
These need someone who's used them before to be *safe*, let alone useful. They are expensive, and if the team owns them, they need storage.
A telephone directory, tabbed with pages of suppliers of services (as mentioned elsewhere, now would be a good time to talk to them, see who can work with you, who might sponsor you ...)
Using the aluminum extrusion for framing saves time and machining (we've used Bosch, others use different manufacturers). It comes with maker-specific corner fasteners and t-nuts for fastening to the sides of the extrusion, Make sure you always have the tightening tools. Always Think Triangles, and don't be afraid to put some of your screws right into the centre part of the extrusion axially and radially to act as pins (no sideways movement.
Decide on a single size screw for fastening non-extrusion metal - we used #8 - so there is only one screwdriver size (especially important if you use a socket head (Robertson (the square one) is our favourite, but there's Allen and Torx). Use slot or Phillips if you want scratches and damage around the screws (why does Bob Villa get paid to advertise screw removers for Sears, and they only show slot and Phillips being mangled enough to
require the removers ?)
Naturally, every piece of supplied equipment needs a different size nut or screw, but keep it to a minimum, and paint the fasteners which are not your chosen size, and the tools too, so that between two bouts thoughtfully scheduled two minutes apart, you won't waste time finding the right one for the job.
Forget not the importance of lockwashers on nearly every screw, and be tempted not by permanent Lock-Tite, lest ye find ye must disassemble, yea that ye must *constantly* disassemble, a certain connection that was supposed to be final.
Number Two Tool is a space of your own to meet in, to build in, and to test in. Also needed is access to a space with a level hard floor, with height enough to raise the robot, and to allow lobbing of projectiles (a gymnasium is excellent).
Number One tool is money. Getting there isn't half the fun, but it's at least as expensive as staying there. Money for "Additional Hardware" is essential. And buy extra material for construction; someone will make a mistake, or some one will decide on a different vision halfway through the build phase ...
This is not as complete as it might be, but it could be a start. There are probably any number of White Papers on the subject - explore Chief Delphi's board and use it as a library.
HYHelps
Unread 16-12-2002, 14:17
Ken Loyd Ken Loyd is offline
Who is John Galt?
FRC #0039 (The 39th Aerosquadron)
Ken Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to behold
For the final week of the building season I would add:
a cot
a pillow
a blanket
mass quanities of Mountain Dew
Ken Loyd
Team 64
Unread 18-01-2004, 11:26
white_ChocOlat8's Avatar
white_ChocOlat8 white_ChocOlat8 is offline
AKA: white chocolate
FRC #1902 (Team EMOTICONS)
Team Role: Marketing
white_ChocOlat8 can only hope to improve
Send a message via AIM to white_ChocOlat8
Re: Tools for Rookie Team?
a cot
a pillow
a blanket
Ken Loyd
Team 64
lol nice
Unread 18-01-2004, 13:40
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
For drill bits I would recomend titinium bits. They are more expensive, but you don't need to sharpen them much and they look pretty and shinny, which is oviously very important.
I would also recomend a flash light. For some reason when working under our robot last year, I couldn't see a thing.
Unread 18-01-2004, 13:55
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Emery cloth- I thnk that is what it is called. Sandpaper for metal.
Tap Set- Useful for creating threads in holes
I have also heard my advisor mention something about a step drill bit. I forget what it is used for.
Unread 18-01-2004, 14:00
Step drills are actually pretty useful. You see them used all the time on "American Chopper"
Unread 18-01-2004, 16:15
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
After reading this thread I thought of three more things to have that I haven't seen mentioned. A deburrer for removing burrs off of machined parts especially since some burrs can be so sharp you can cut yourself and not know it right away. Second a helicoil set for stripped treads. It basically consists of the helicoils (which are "springs" you insert into the stripped hole and the "spring" becomes the new thread), a drill bit which opens the hole up to the helicoil size, and the installation tool for the helicoils. This will save you when you strip a hole and you don't have time or ability to remachine a part like at competition and believe me it WILL happen sooner or later. It's also a good idea to use them in the begining on all plastic parts (delrin, polycarbonate, plexi-glass, HPDE, ect.) that require a tapped hole. Just keep in mind you will need different size helicoils for each of the different threads that are used and they don't repair stripped screws but then again a screw is easy to replace compared to a part. Our team only has them kept in our toolbox in 1/4" (or 5mm) and under since your most likely to strip smaller holes. It's also not recommended to use Loctite with them. And now finally third, counter sinks for counter sinking flat head screws and can also be used for deburring holes.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 18-01-2004, 21:09
laditek laditek is offline
laditek is an unknown quantity at this point
Yes Adam, a step drill bit for making holes larger to lighten the bot in crunch time. I believe it was 50 1" holes equal a pound.
Unread 21-01-2004, 09:15
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
As far as tools to bring to the competition, check out page 6 of Section 10 of the manual.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 16-12-2002, 16:06
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
SCALE
A good scale is essential. During build we get estimates for system weight, weigh the actual hardware for subsystems before installation, track projected vs actual weight continuosly, and then weigh the final product.
Typically our estimated weight is 0.5-1 lb off the actual weight. It really is hard to estimate the wires, as they are cut to length on installation and once installed we don't want to take them out.
The easiest way to reduce weight is to keep it off in the first place.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 16-12-2002, 16:26
D.J. Fluck
Posts: n/a
An extensive Med Kit is a very helpful tool for the accident prone victims of your team
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
