Go to Post a robot is never finished... It can always be redone and improved. - EricVicenti [more]
Unread 22-12-2011, 07:06
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Re: #35 Chain Misalignment
It depends on how far apart the two sprockets are. If the two sprockets are pretty far spread out then you shouldn't have any issues. However miss alignment also causes inefficiency.
Since you are at the CAD stage of design, I suggest you try to make the two sprockets line up. This will increase the efficiency of your system.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 22-12-2011, 07:14
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
By lining up the sprockets, my wheels are misaligned and we don't have the materials to make spacers for the wheel bolts. If the wheels aren't aligned on the same plane, will it cause handling issues?
Unread 22-12-2011, 07:40
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
It may make turning a bit more inefficient, but it shouldn't cause much of a problem (probably less than having the chains misaligned).
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 22-12-2011, 07:54
Awesome. The inner rims of all 6 wheels are aligned, but the plaction wheel, being slightly thicker than the 2008 FIRST wheels make the centres misaligned. Otherwise, it's coming together nicely.
Unread 22-12-2011, 08:26
Jared Russell's Avatar
Taking a year (mostly) off
I would rather have 5mm misaligned wheels than 5mm misaligned chain.
Unread 22-12-2011, 09:39
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
It's not uncommon to see teams misaligned wheels to keep chain properly aligned. It can make your drive quirky, but it's not really the end of the world if you get appropriate practice in.
On the subject of spacers, you don't necessarily have to make them. We've used ~1/4" spacers made for #10 screws on AM wheels before without any problems. You should be able to get them from your local hardware store, or at least something close enough to work.
-Dustin Benedict
Unread 22-12-2011, 10:16
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
We've run misaligned wheels in several robots with no adverse effects that I've ever noticed.
Unread 22-12-2011, 19:16
CNettles11's Avatar
CNettles11 CNettles11 is offline
AKA: Chris Nettles
FRC #3502 (Octo-Pi-Rates)
CNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the rough
There's no way that you could stack washers under either the driver sprocket or the driven sprocket to align them? It's not pretty but it works.
