Go to Post If everyone else in the world is an idiot, you may need to recalibrate your idiotness scale. - GaryVoshol [more]
Unread 15-12-2011, 19:08
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Netbeans using wrong target IP?
So, the code builds, but when it runs, it gets an error at C:\Documents and settings\Sony\sunspotfrcsdk\ant\upgrade.xml:40. Along with that, I noticed that netbeans said that the target IP is 10.0.0.2, though it should be 10.35.97.2
Anyone have any similar errors or possible solutions?
Unread 15-12-2011, 19:11
Re: Netbeans using wrong target IP?
Set your team number in netbeans per the instructions.
Unread 15-12-2011, 20:32
Lead Programmer
AKA: Josh
That's part of the issue. I don't know how to change the target IP that netbeans is looking for, and I also don't know where I can find instructions.
The cRIO is set to 10.35.97.2 by the imaging tool, and the computer is set to 10.35.97.5
Unread 15-12-2011, 21:57
Getting Started With Java
Originally Posted by page 6
10. Select “Tools” menu, and choose the “Options” menu options, from the NetBeans menu bar.
11. Select the “Miscellaneous” tab. Then select the “FRC Configuration” tab and enter your team number into the text field. Then press OK.
Unread 16-12-2011, 10:44
Lead Programmer
AKA: Josh
So... I can't check a computer running windows right now, but the mac version (or mine at least) doesn't have an "Options" sub menu under tools, or anything for that matter. (I dislike macs, but school provides them to all students).
I'll check on a laptop running xp this afternoon though.
Unread 16-12-2011, 12:42
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
On Mac the IP can be changed by accessing preferences, which is in the NetBeans menu (found next to the apple).
Good luck,
Oliver
Unread 16-12-2011, 17:19
Lead Programmer
AKA: Josh
I got the code to download to the robot, but it didn't work quite right, and now when I try to download the fixed code, it gets stuck at
[cRIO] Welcome to LabVIEW Real-Time 8.6.1f3
[cRIO]
[cRIO] [Squak VM] Version:2011 FRC, Feb 18 2011, 15:57:21
[cRIO] FPGA Hardware GUID: 0x2eaa5e59cafla8a966853a011b61cc91
[cRIO] FPGA Software GUID: 0x2eaa5e59cafla8a966853a011b61cc91
[cRIO] Default IterativeRobot.disableInit() method... Overload me!
[cRIO] Default IterativeRobot.disableContinuous() method... Overload me!
[cRIO] Default IterativeRobot.disablePeriodic() method... Overload me!
It will get to that point and stop
Unread 17-12-2011, 01:05
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
That looks typical for the default code, without having been enabled by a ds.
What were you expecting?
Eric Haskins KC9JVH
Unread 17-12-2011, 09:55
Originally Posted by Mark McLeod View Post
I wonder why there are 2 versions on WPI.edu, both with the same revision number (Rev 0.83), but with different layouts:
http://first.wpi.edu/Images/CMS/Firs...edWithJava.pdf
http://first.wpi.edu/Images/CMS/Firs...va_for_FRC.pdf
Unread 17-12-2011, 10:19
I choose to link the one with the table of contents.
Although technically, I believe it to be the earlier of the two documents.
As I recall, they were actually issued in subsequent years, but the textual differences, although minor, should have occasioned a new rev. #
Somebody probably just forgot which was the latest original document.
Unread 22-12-2011, 15:08
Lead Programmer
AKA: Josh
It isn't from the default code. It's code that I wrote.
Unread 22-12-2011, 15:15
AKA: Eric Haskins
If you don't have any print statements in your code or haven't enabled it from the DS, that looks right. If it made it to that point, the code is downloaded and running correctly and no exceptions have occured.
Is the robot enabled from the DS? What do you expect to be printed or happen? We probably won't be able to help anymore without seeing your code.
Eric Haskins KC9JVH
Unread 22-12-2011, 15:30
Lead Programmer
AKA: Josh
I hope this satifies you.
/* Copyright (c) FIRST 2008. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Watchdog;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Solenoid;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class Team3597Robot extends IterativeRobot {
//Motors
RobotDrive drivetrain;
//Joysticks
Joystick xbox_controller;
Joystick Attack3;
//Buttons
static final int NUM_JOYSTICK_BUTTONS = 16;
boolean[] xbox_controllerButtonState = new boolean[(NUM_JOYSTICK_BUTTONS+1)];
boolean[] Attack3ButtonState = new boolean[(NUM_JOYSTICK_BUTTONS+1)];
//Solenoids/Pnuematics
static final int NUM_SOLENOIDS = 8;
Solenoid[] m_solenoids = new Solenoid[NUM_SOLENOIDS];
Compressor compressor = new Compressor(4,8);
int m_autoPeriodicLoops;
int m_disablePeriodicLoops;
int m_telopPeriodicLoops;
* This function is run when the robot is first started up and should be
* used for any initialization code.
public Team3597Robot(){
drivetrain = new RobotDrive (1,2,3,4);
drivetrain.setInvertedMotor(RobotDrive.MotorType.k FrontLeft, false);
drivetrain.setInvertedMotor(RobotDrive.MotorType.k FrontRight, true);
drivetrain.setInvertedMotor(RobotDrive.MotorType.k RearLeft, false);
drivetrain.setInvertedMotor(RobotDrive.MotorType.k RearRight, true);
xbox_controller = new Joystick(1);
Attack3 = new Joystick(2);
int buttonNum = 1;
for (buttonNum = 1; buttonNum <=NUM_JOYSTICK_BUTTONS; buttonNum++) {
xbox_controllerButtonState[buttonNum] = false;
Attack3ButtonState[buttonNum] = false;
int solenoidNum = 0;
for (solenoidNum = 0; solenoidNum < NUM_SOLENOIDS; solenoidNum++) {
m_solenoids[solenoidNum] = new Solenoid(solenoidNum+1);
m_autoPeriodicLoops = 0;
m_disablePeriodicLoops = 0;
m_telopPeriodicLoops = 0;
public void robotInit() {
* This function is called periodically during autonomous
public void autonomousPeriodic() {
Watchdog.getInstance().feed();
m_autoPeriodicLoops++;
* This function is called periodically during operator control
public void teleopPeriodic() {
m_telopPeriodicLoops++;
double moveValue = xbox_controller.getRawAxis(2);
double rotateValue = xbox_controller.getRawAxis(4);
double moveValue2 = Attack3.getRawAxis(2);
double moveValue3 = xbox_controller.getRawAxis(1);
// drivetrain.arcadeDrive(moveValue, rotateValue);
drivetrain.mecanumDrive_Polar(moveValue, moveValue3, rotateValue);
/*Button Mapping
X-Box Controller
Left Stick Forward/Backward- DriveTrain Move Forward/Backward
Right Stick Left/Right- DriveTrain Rotatate Left/Right
A- Send out Deployment A+B- Return Deployment
Attack3 Joystick
Up/Down- Claw Up/Down
2- Send out Deployment 2+6- Return Deployment
Output when run:
init:
init:
Deleting directory C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\build
Deleting directory C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\suite
Deleting directory C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\j2meclass es
clean:
Created dir: C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\build
Compiling 1 source file to C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\build
compile:
Created dir: C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\j2meclass es
preverify:
Created dir: C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\suite
Building jar: C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\suite\Rob otMecanum2_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
Romizer processed 111 classes and generated 4 files.
Expanding: C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\suite\Rob otMecanum2_1.0.0.jar into C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\suite
Moving 1 file to C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\suite
Deleting: C:\Documents and Settings\Sony\My Documents\NetBeansProjects\RobotMecanum2\image.sui te.api
Host OS: Windows XP 5.1, 5.1
Host JVM: Java HotSpot(TM) Client VM 20.2-b06
Target IP: 10.35.97.2
Network interfaces on host:
Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller - Packet Scheduler Miniport: address: 10.35.97.5 netmask: 255.0.0.0 <--- on robot's subnet
Connecting FTP @10.35.97.2
upgrade:
Sending local file image.suite
flashapp:
deploy:
init:
[cRIO] [OTA Server] ********* REBOOTING cRIO *********
[cRIO]
Waiting for cRIO to reboot (1s)
Waiting for cRIO to reboot (2s)
Waiting for cRIO to reboot (3s)
Waiting for cRIO to reboot (4s)
Waiting for cRIO to reboot (5s)
Waiting for cRIO to reboot (6s)
Waiting for cRIO to reboot (7s)
[cRIO]
[cRIO] -> * Loading StartupDlls: debug
[cRIO] Entering debug.o StartupLibraryInit
[cRIO] Debugging is up, target server mounted at /tsfs
[cRIO]
[cRIO]
[cRIO] VxWorks
[cRIO]
[cRIO] Copyright 1984-2006 Wind River Systems, Inc.
[cRIO]
[cRIO] CPU: MPC5200 -- Wind River Lite5200 BSP.
[cRIO] Runtime Name: VxWorks
[cRIO] Runtime Version: 6.3
[cRIO] BSP version: 2.0/10
[cRIO] Created: Jul 29 2009, 13:41:47
[cRIO] ED&R Policy Mode: Deployed
[cRIO] WDB Comm Type: WDB_COMM_END
[cRIO] WDB: Ready.
[cRIO]
[cRIO] Leaving debug.o StartupLibraryInit
[cRIO] * Loading StartupDlls: NiRioRpc
[cRIO] * Loading StartupDlls: niorbs
[cRIO] * Loading StartupDlls: NiViSrvr
[cRIO] * Loading StartupDlls: visa32
[cRIO] * Loading StartupDlls: nivissvc
[cRIO] task 0xed0c28 (PAL00fa1fe0) deleted: errno=0 (0) status=0 (0)
[cRIO] NI-RIO Server 3.2 started successfully.
[cRIO] task 0xc4c0c8 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
[cRIO] * Loading StartupDlls: nivision
[cRIO] * Loading StartupDlls: niserial
[cRIO] * Loading StartupDlls: FRC_FPGA
[cRIO] * Loading StartupDlls: FRC_NetworkCommunication
[cRIO] task 0x1af55f0 (t2) deleted: errno=0 (0) status=0 (0)
[cRIO] FRC_NetworkCommunication was compiled from SVN revision 2258
[cRIO]
[cRIO] NI-VISA Server 4.5 started successfully.
[cRIO] task 0xe4f3f0 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
[cRIO] FPGA Hardware GUID: 0x2EAA5E59CAF1A8A966853A011B61CC91
[cRIO] FPGA Software GUID: 0x2EAA5E59CAF1A8A966853A011B61CC91
[cRIO] FPGA Hardware Version: 2011
[cRIO] FPGA Software Version: 2011
[cRIO] FPGA Hardware Revision: 1.5.3
[cRIO] FPGA Software Revision: 1.5.3
[cRIO] * Loading StartupDlls: FRC_JavaVM
[cRIO]
[cRIO]
[cRIO] [OTA Server] Version: 2011 FRC, Jan 6 2011, 09:47:42
[cRIO]
[cRIO]
[cRIO]
[cRIO] [Squawk VM] Version: 2011 FRC, Feb 18 2011, 15:57:21
[cRIO] FPGA Hardware GUID: 0x2eaa5e59caf1a8a966853a011b61cc91
[cRIO] FPGA Software GUID: 0x2eaa5e59caf1a8a966853a011b61cc91
[cRIO] Default IterativeRobot.disabledInit() method... Overload me!
[cRIO] Default IterativeRobot.disabledContinuous() method... Overload me!
Unread 22-12-2011, 15:38
Lead Programmer
AKA: Josh
Also this error comes up after I reimaged it, and then it goes to the other one
init:
init:
clean:
compile:
preverify:
jar-app:
Intel(R) Wireless WiFi Link 4965AGN - Packet Scheduler Miniport: address: 169.244.215.246 netmask: 255.255.254.0
upgrade:
C:\Documents and Settings\Sony\sunspotfrcsdk\build.xml:95: The following error occurred while executing this line:
C:\Documents and Settings\Sony\sunspotfrcsdk\ant\deploy.xml:35:
java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream. java:168)
at java.io.BufferedInputStream.read1(BufferedInputStr eam.java:256)
at java.io.BufferedInputStream.read(BufferedInputStre am.java:317)
at java.io.BufferedInputStream.fill(BufferedInputStre am.java:218)
at java.io.BufferedInputStream.read(BufferedInputStre am.java:237)
at org.apache.commons.net.telnet.TelnetInputStream.__ read(TelnetInputStream.java:114)
at org.apache.commons.net.telnet.TelnetInputStream.ru n(TelnetInputStream.java:535)
at java.lang.Thread.run(Thread.java:662)
BUILD FAILED (total time: 9 seconds)
Unread 22-12-2011, 19:08
Lead Programmer
AKA: Josh
Got it working perfectly, but the cRIO got fried 10 minutes later while we were testing it. FML
