Go to Post How do you earn yourself 500 PM's, 200 e-mails, 100 replies to a post, and an instant 5 to 6 bars in rep? If your name is Grant Imahara, make yourself known to the Chief Delphi community. - Andy Grady [more]
Unread 22-12-2011, 23:44
Motor Quiz
What voltage would be required to operate a CIM at 60 oz-in at 3700 rpm?
Unread 22-12-2011, 23:46
xSAWxBLADEx's Avatar
xSAWxBLADEx xSAWxBLADEx is offline
DaBears til 13 turned Free Agent 14
AKA: Michael Hawley
no team (Free Agent)
Team Role: Scout
xSAWxBLADEx will become famous soon enoughxSAWxBLADEx will become famous soon enough
Send a message via MSN to xSAWxBLADEx
Re: Motor Quiz
9 volts
2006-Palmetto Regional Champions with 11 and 1251 (MORT, TIGERS, BEARS, O MY!)
2007-Pittsburgh Regional Champions with 123 and 337 / Detroit Regional Champions with 123 and 903
2009-Traverse City District Competition Champions with 85 and 2645 / Traverse City District Competition Chairman's Award / Michigan State Championship Finalists with 1918 and 904 / Championship Finalist with 217 and 68
2013-Grand Blanc District Competition Champions with 33 and 1718
Unread 22-12-2011, 23:53
Re: Motor Quiz
Originally Posted by xSAWxBLADEx View Post
9 volts
Wild guess?
Unread 22-12-2011, 23:57
Aren Siekmeier's Avatar
on walkabout
Re: Motor Quiz
Spoiler for Work:
60 oz-in (or 0.42 Nm) is about 1/6 (0.17) of stall torque for a CIM (2.43 Nm), at which a DC motor runs at about 5/6 of free speed. 3700 rpm is 0.83 (5/6) of 4473 rpm, the free speed at our mystery voltage. Free speed scales with voltage, so if a CIM's free speed is 5310 rpm at 12V, the mystery voltage is 12V*4473/5310 =
10.1 V
Unread 23-12-2011, 00:01
AKA: Michael Hawley
Team Role: Scout
Re: Motor Quiz
Wild guess?
yep never did like quizes, multiple guess tests are better.
Unread 23-12-2011, 00:15
Re: Motor Quiz
Originally Posted by compwiztobe View Post
10.1 V
At 10.1 volts the free speed is (10.1/12)*5310 = 4469 rpm
The stall torque is (10.1/12)*343.4 = 289 oz-in.
So at 3700 rpm the torque would be 49.7 oz-in, not 60 oz-in.
Unread 23-12-2011, 00:40
on walkabout
Re: Motor Quiz
I see, so stall torque also scales in the same way. A convenient way to can all this then would be with giving the speed vs. torque curve as speed/free speed + torque/stall torque = voltage/spec voltage.
For another shot then:
Spoiler for Let's try that again:
Free speed = 5310rpm
Stall torque = 2.43Nm
Spec voltage = 12V
Speed = 3700rpm
Load = 60oz-in = 0.42 Nm
So voltage = 12 * (3700/5310 + 0.42/2.43) =
10.43V
Unread 23-12-2011, 00:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Motor Quiz
10.5 Volts, give or take.
I arrived at my answer by a very different (and probably incorrect) method from the poster above. I figured motor constants for RPM/Volt and Oz-In/Amp, found how much current it would take to hold 60 oz-in at stall, considered the resistance of the motor's windings, then figured out how many volts it would need to hold 60 oz-in at stall, then I figured how many volts it would need to spin 3700 RPM at no load, then added those two voltages to arrive at my answer. I did have some rounding error, but perhaps my method is entirely flawed and just happened to be close by coincidence? I am on holiday here....
EDIT: Revising my answer with less rounding, I get 10.458 Volts by the above method.
I'm confused by the above poster's method of adding ratios of speed and torque. Why does that work?
Unread 23-12-2011, 01:03
Re: Motor Quiz
My work:
CIM Motor Constants
442.5 RPM/Volt
2.581954 oz-in / A
Resistance of motor windings is 0.0902255639 Ohms by Ohm's Law
Thus:
60 oz-in requires 23.238214 A to stall, from a 2.09668 V source
Also, it takes 8.3615819 V to spin 3700 RPM under no load
Add the voltages to arrive at 10.458 V needed to spin 60 oz-in load at 3700 RPM
Check: At this voltage:
Free speed is 4627.65 RPM
Stall Torque is 299.2731 oz-in
Operating parameters are at:
20.0486% of stall
79.9514% of free speed = 3699.87 RPM
Less than 0.4% Calculation error.
Can someone tell me if this is the proper way to do this, or if my hairbrained idea just happened upon a lucky coincidence?
Unread 23-12-2011, 06:29
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
Re: Motor Quiz
Come on engineers, significant figures.
2 digits of data yielding 8 digits of precision?
Use 10.5 or 11 volts and call it a day.
Unread 23-12-2011, 10:07
Re: Motor Quiz
See attached speed vs torque drawing.
E is the desired operating point with speed C and torque D
Line AB is the 12V speed vs torque curve (given)
If we can find G, then the "mystery" voltage is 12*(G/A).
Proceed as follows:
From similar triangles, (G-C)/D = A/B
Multiply both sides by D/A to get (G-C)/A = D/B
Expand the left side to get G/A - C/A = D/B
Move C/A to the other side to get G/A = C/A + D/B
So V = 12*(G/A) = 12*(C/A + D/B) which is what Aren did.
Of course, this ignores the 2.7 amp free current. What role should that play in this analysis?
Unread 23-12-2011, 10:19
Re: Motor Quiz
The whole concept using "significant figures" this way, although still taught in high schools, is deeply flawed.
Unread 23-12-2011, 11:25
Re: Motor Quiz
The above method is arithmetically identical to what Aren did:
current to hold "D" oz-in at stall = (D/B)*Istall
volts to hold "D" oz-in at stall = (D/B)*Istall*R = (D/B)*Istall*(12/Istall) = 12*(D/B)
volts to free-spin at "C" rpm = 12*(C/A)
adding these 2 gives:
"mystery volts" = 12*(C/A+D/B)
Unread 23-12-2011, 12:07
Re: Motor Quiz
It's also at least touched on at the college level. I'm curious why you say it's flawed--besides the fact it confused me every time I tried to use it! (I typically hold about a 2-3 decimal digit precision in the final answer, but I'll often go to 4-5 decimal digits or more during calculations.)
Unread 23-12-2011, 12:17
Re: Motor Quiz
Yes, I know my significant figures and decimal places are a complete mess. I was rushing. I too would like to hear Ether's explanation of the flaws in the significant figure method taught in schools.
The 2.7A free-running current I believe plays a role in determining the motor's torque constant. Rather than being 343.4 Oz-In / 133A it would be 343.4 oz-in / (133-2.7 A)
I'm actually rather surprised I did this correctly, albeit in a somewhat roundabout method. This was fun.
