Go to Post Silly FIRST mentor -- actually spending brain power caring about a sporting event occuring during build season! - Aidan F. Browne [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 21-12-2011, 17:49
Komodo's Avatar
Komodo Komodo is offline
AKA: Moshe Weinfeld
FTC #3123 (Spontaneous Combustion)
Komodo is an unknown quantity at this point
[FTC]: Axle Set Collars (Vex, Master-Carr)
I have a few questions concerning the usage of axle set collars.
Our design is a scissor lift and calls for a large amount of shaft collars to hold the cross members in place. (Somewhere around 216)
The first question is may we use vex set shaft collars? It isn't the right size for
the Tetrix axles, but if we bore out the center to accommodate a Tetrix axle, would this be legal? I've been seeing that vex fasteners are permitted, so would a modified shaft collar be considered a fastener?
The second question is if we do order set screw shaft collars from a supplier such as McMaster-Carr, what Bore would we need? I'm guessing at 1/8".
Answers would be much appreciated.
Unread 21-12-2011, 18:36
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Re: [FTC]: Axle Set Collars (Vex, Master-Carr)
The Tetrix axles are of 4.7 mm diameter. That's pretty close to 3/16" or 5mm. I'm not sure which will work best.
Strictly, the only shaft collars you may legally use (unless there's been a Q&A revision that I've missed) are those sold by Pitsco. Shaft collars are NOT a fastener and substitutes aren't allowed.
Practically, nobody will be able to tell the difference.
Let your conscience (or, perhaps, your wallet) be your guide.
--Madison--
...down at the Ozdust!
Unread 22-12-2011, 00:39
kz2zx kz2zx is offline
Ruthlessly Insufficient
FTC #5246
kz2zx will become famous soon enough
Rulebook says 'absolutely no VEX parts' or words to that effect...
If you're like us, we're using Tetrix parts drilled out to our shaft sizes (1/4", 3/8") and possibly having to drill/tap setscrew holes in 'repurposed' parts such as hub spacers.
But, we didn't choose a scissor design (more like a extending boom), so our needs are simpler.
Unread 22-12-2011, 17:16
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
alternate thought that may not work,
Can you thread the ends of your shafts and use common locking nuts which are the cheapest option? If threading the shafts is not an option, could you switch to all-thread rod. Do you run up against the limits of allowed materials?
I don't have those limits committed to memory.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 23-12-2011, 03:57
Komodo's Avatar
AKA: Moshe Weinfeld
Thank you for the responses, and I appreciate the idea Andrew but I believe the nuts would become loosened easily over time, unless you think we could use loctite to keep them on. What type of tool exactly would we use to thread the ends of the shafts?
Also, I found these on McMaster-Carr, could I use this part or some other part similar to its purpose?
http://www.mcmaster.com/#plastic-axle-caps/=fhga65
Unread 23-12-2011, 09:43
A tap and die set cuts threads. You would need to use two lock nuts per shaft end to lock in place. I still have not checked the linear feet of all thread is allowed but cutting thread on shaft has no restrictions.
APS
Founder FRC 499
Unread 23-12-2011, 09:45
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
We participate in BEST robotics which provides a specific supply of materials in the KOP. We use modified 1/4-20 nuts as shaft collars.
We drill out the threads of the nut with a 17/64 or 9/32 drill bit. We then drill a tap hole in the side of the nut for an 8-32 bolt. You might be able to manufacture you own this way rather buying.
You could try the same technique with a small nut with a smaller bolt as the set screw.
Good luck.
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 23-12-2011, 10:27
Moshe,
You really need to read through R5c of the robot rules section. Shaft collars are not fasteners and so do not fall under the unrestricted use of fasteners section of this rule. I find nothing in the rules that would allow you to use anything other than the Tetrix shaft collars. 216? Really?
Unread 23-12-2011, 10:42
normalmutant's Avatar
normalmutant normalmutant is offline
AKA: Nathan
FTC #3539 (Say Watt?)
normalmutant has a spectacular aura aboutnormalmutant has a spectacular aura about
We use threaded rod instead of axles to hold together the cross members. I think it ended up being less expensive, actually.
SAY-WATT.ORG
Unread 23-12-2011, 14:42
Komodo's Avatar
AKA: Moshe Weinfeld
Once again, thanks for the quick responses, except Al's which has a patronizing tone to his comment. And yes, I have read rule R5c but did not know whether the item "set screw shaft collar" would qualify as a fastener because it technically fastens onto axles.
I think we might try going all threaded or try to thread the end of the axles.
Andrew, why would we need two nuts per side to lock it in place? Could we use just one and use loctite to keep it on?
Unread 23-12-2011, 15:20
Moshe,
Sorry you took it that way, I did not intend it as anything but help. I am speaking from the standpoint of an FTC inspector.
From R5c 18. All mechanical fasteners (nuts, bolts, screws, etc.) of any length, any thread type, up to 0.375” (0.9525cm) diameter. The intent of this rule is to allow teams to use fasteners from any supplier that are substantially the same as TETRIX fasteners.
In the context of this wording, shaft collars are not considered fasteners(nuts, bolts, screws, etc.). I am merely trying to save you from facing this dilemma when you compete.
You may try asking on the Q&A. If they rule it as a fastener then you can proceed. The Q&A has ruled that threaded rod is a fastener.
R5c 17. Unlimited length Threaded Rod (also known as All‐Thread) not to exceed 0.375” (0.9525cm)
diameter (e.g. McMaster Carr Part #94435A317).
Unread 23-12-2011, 23:31
FTC #5246
Al,
All GDC and Inspector responses come off as condescending, it's just the nature of the position, I think
Komodo,
You can use unlimited length threaded rod in your robot this year. You can use an unlimited number of nuts.
Andrew's response is slightly confusing. You can use lock nuts, or you can use two hex nuts tightened one against the other to lock both in place on the threaded-rod. Lock nuts come in different styles - the 'Kep nut' style that's in the kit has a built-in form of a lockwasher (that star-shaped thing attached); locking-thread or acorn-nut where the thread depth constricts and the nut jams onto the thread as it were; or the nylon-insert kind that has (oddly-enough) a nylon insert to keep the thread from vibrating/backing.
You are ALSO allowed loctite.
For the use you're describing, I'd use 1/4-20 nuts from McMaster by the hundreds... I'd also invest in a 1/4-20 NC die, a pair of vice-grips, and a 1" 6-point deepwell socket (when handheld, beats a die handle hollow for speed) to 'chase' the threads after you cut the rod. It'll help a LOT if you can dip the end of the allthread in a 1/4" deep capful of motor oil (used is fine).
I'd also use a fiberblade to cut that many rods. Get a 10" one and mount it in a tablesaw is how I'd do that, and use the fence for length.
I like the solution from Coach Norm, too, but for your application, it may just be a whole lot faster to use two nuts per side and tighten them against each other to lock them.
HTH!
