Go to Post rumors only beget more rumors - JakeGallagher [more]
Unread 23-12-2011, 14:06
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
pic: WCP: AL Gears?
Unread 23-12-2011, 14:07
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: pic: WCP: AL Gears?
Do you anticipate being able to support the potential demand?
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 23-12-2011, 14:22
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Will you be selling pre-lightened versions of the gears? (Aluminum is light; holes are lighter!)
Just curious: are they 7075-T6, -T7 or something else?
Is there much wear of the dog mating surfaces after several hundred hard (e.g. pneumatic) shifts? I'm curious if it rounds off the edges on the aluminum dog gears. (Even if it does, it will likely be no trouble at all for most customers.)
Unread 23-12-2011, 15:05
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Oh boy, I've been waiting for COTS dog gear replacements...
Time to get that 3/8" hex broach.
GitHub
Unread 23-12-2011, 15:23
Aren Siekmeier's Avatar
on walkabout
These look awesome! Do I see correctly that these include the little nub around the hole to keep them away from bearings? The size selection will be nice too. I'm guessing mostly 3/8" hex on most of these? Are 35/45/48/60 only available with the dog cutout, or can they have keyed hole (hex or otherwise) as well? Can't wait to see these available!
Unread 23-12-2011, 15:33
Chris is me's Avatar
AKA: Pinecone
The gears should / will come pre-broached.
Unread 23-12-2011, 16:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The wear is insignificant, if not unnoticeable.
We shift with a 7075 dog on 4140/1144 steel gears with no wear whatsoever on the dog itself.
In 07 we had a 7075 dog on hard anodized 7075 gears and saw no wear on either the dog or dog gear.
2001-2004: Team 100
2006-Present: Team 254
Unread 23-12-2011, 16:28
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Only took you 3 years, RC.
I kid, I kid. <3
-Dustin Benedict
Unread 23-12-2011, 17:41
Engineering Mentor
FRC #0254
Edit: Regarding gear tooth wear, I would rephrase this and say the wear is likely noticable, but is negligible for the relatively short life that these robots have. Steel gears also wear, but since they are rarely coated, the amount of wear you notice during the year is likely minimal since it is hard to distinguish the worm material from the surrounding material. With a hard anodize, you will likely notice "more" wear due to the differences in color of the coating and the raw aluminum.
If others did/do notice what they would consider excessive wear, I would also ask that they objectively determine if it is causing any excessive backlash, efficiency changes, or is causing further wear more rapidly.
RC, a question for you. Are these gears cut with a modified addendum and dedendum to account for the build-up of the type III anodize?
-Travis Covington
Unread 23-12-2011, 18:05
R.C.'s Avatar
Travis, Tbh,
I feel a lot better after talking to AM, I have everything ready to go in order to ship these guys and I believe I have made enough for this year. First year in, so I don't know how much demand there truly will be. But provisions have been made to make more gears during season if needed.
The place I work at has an SL-30 lathe with a bar feed that normally runs lights out, as long as the OD is under 3" I can have blanks ready next day for the hob guy/shipped over night via Ontrac.
Tristan, at first I really wanted to sell super pocketed gears, but the cost was too high for me when I had them made at work or any place around here. In the next year or two I am looking to do these inhouse and have them offered to FIRST teams, most likely the bigger gears such as the 40/45/48/50/60T pocketed.
All the gears are 7075-T6 and Cory/Travis are correct. The coating 1323/973 used last year wasn't that good, but the new coating is significantly better. It is similar to AM's 50T and when we used his 50T this year and last year for some high speed applications, that coating was very very good.
All gears have a nub that are plan bore. Gears will come in 3/8 or 1/2 Hex with a small protrusion. There are other dog "gears" planned, 40/50/55, this also depends on demand. The 45/60 dog gears allow for some very nice ratios for 4/6 inch wheels.
Current Lineup:
14T - CIM pinion - 3/8 Hex
15T - 3/8 Hex
28T - 3/8 Hex
30T - 3/8 Hex
35T - Dog Gear
45T - 3/8 Hex - 1/2 Hex - Dog Gear
48T - 1/2 Hex - Dog Gear
56T - 1/2 Hex (Cimple Box Gear)
60T - 3/8 Hex - 1/2 Hex - Dog Gear
Travis,
I believe either you or Adam brought this up when we made our season gears last year. We did not do that last season, but this year after talking to the Ano/Gear place we have.
-The ano place, Nituff says ano should be .001 penetration and .001 build up. Normal range of build up is .0008 to .0012 according to the rep.
-The gear guy is compensating for that, I got a shop tour and talked to them about our application. They said they would cut a few gears, get them ano'd in house and then make sure it passes their QC, which is quite nice.
-RC
R.C.
MadTown Robotics Team 1323
Unread 23-12-2011, 18:12
Engineering Mentor
FRC #0254
Cool. Thanks for the info. Sounds like something we might have to consider this year.
-Travis Covington
Unread 23-12-2011, 18:22
thefro526's Avatar
Mentor for Hire.
Just to expand on something RC said, and please forgive me if I'm overstepping in what I say but, there are a few gear ratios that will be available through WCP that aren't currently available through any other FRC supplier. Direct driving 4" wheels should become a trivial task with these gears - and will be possible with a 2-stage reduction vs. the current 3-stage reductions that many teams using COTS parts have to deal with.
Also, I'm not sure if RC has brought this up but, many of these gears will be drop in replacements for AM gears, so if you find yourself in need of an extra pound or two in the last week of build, keep WCP in mind.
-Dustin Benedict
Unread 23-12-2011, 20:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Any idea what pricing is looking like?
Unread 24-12-2011, 09:00
JesseK's Avatar
FRC #1885 (ILITE)
That's understood, but it's for cluster gears sizes other than what they've listed. For example, if I wanted to go down from 48T to 45T on the large dog gear in the super shifter without changing plates, I'd need to go up from 15T to 18T on the corresponding cluster gear. This is just an example; really in the off season I'll probably play with some different ratios altogether.
GitHub
Unread 24-12-2011, 12:58
Andrew Lawrence
Posts: n/a
THANK YOU!
