Go to Post I don't need sleep, just more Mountain Dew. Oh, and a muffin. - hallk [more]
Unread 23-12-2011, 12:46
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Motor Quiz
The whole concept using "significant figures" this way, although still taught in high schools, is deeply flawed.
Are you saying that there's more than 4 significant digits in the 'best' answer?
I'm curious why you say it's flawed--besides the fact it confused me every time I tried to use it!
Me too, because I'm not sure in which way you find flaw.
The statement I use is "Just because your calculator shows 8 digits doesn't mean they are all important".
On the other hand, it is very important to know just how many digits you really have to work with, and a good idea of physical reality to check for reasonableness.
Unread 23-12-2011, 12:52
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Motor Quiz
Originally Posted by xSAWxBLADEx View Post
yep never did like quizes, multiple guess tests are better.
In real life, there are no multiple choice questions.
Usually....
Unread 23-12-2011, 13:58
Re: Motor Quiz
It's also at least touched on at the college level. I'm curious why you say it's flawed--besides the fact it confused me every time I tried to use it! (I typically hold about a 2-3 decimal digit precision in the final answer, but I'll often go to 4-5 decimal digits or more during calculations.)
Several parallel thoughts come to mind:
1) for a detailed (and humorous) treatment, see this link.
2) rounding the answer to 11 volts as suggested here gives a profoundly wrong answer*. At 11 volts, the torque at 3700 rpm is 75.5 oz-in
3) with modern computers and calculators, there is no reason to drop any digits of precision during intermediate calculations. carry all the precision through, then round the final answer. the number of digits to keep is not a simple matter of looking number of digits in the datum with the least digits. in the specific case of this problem, tenths of a volt is a reasonable (and necessary) precision to get a reasonably correct answer:
61 oz-in @ 3710 rpm requires 10.52 volts
59 oz-in @ 3690 rpm requires 10.40 volts
... so if you want to round to 10.5 volts that would be reasonable, but not 11 volts*
*we are talking about correct answers to the problem as stated. I know that manufacturing tolerances of the motor could cause wide variation.
Unread 23-12-2011, 13:59
Re: Motor Quiz
No. But I am saying using only 2 digits (11 volts), as suggested, is not a correct answer.
More detail posted here.
Agreed. But a student should learn how to use the calculator in such a way that all those digits get used through the intermediate calculations.
I agree completely.
Unread 23-12-2011, 15:44
Aren Siekmeier's Avatar
on walkabout
Re: Motor Quiz
I agree that the whole "sig figs" deal is flawed. I had a science teacher in high school who extolled it, and perhaps it was his inability to do basic algebra that led me to skepticism of that as well. My beef with it is that it is so dependent on the base in which you are representing the numbers. If you're going to worry about such things, actually do the stats with how the initial standard deviations or uncertainties propagate through the calculations. If you don't care that much, just round your final answer at the end to something that's not way than you care about, but still gives detail relevant to the problem and its context. My answer 10.43 was perhaps too many digits: 10.4V would perhaps have been more appropriate given how much control we actually have over (and how much we actually about) the voltages in question. But it doesn't really matter that much. And as Ether has pointed out, 11V is just plain wrong. And one should never round in the intermediate steps. The best way to go about these calculations is to solve for the answer symbolically and then just plug in your parameters, since the general solution in infinitely more useful and this avoids any intermediate rounding errors. I do a lot of calculations in excel and keep all the digits (the first 30 some anyway) around. However, when reporting these intermediate values, I will often round to keep it uncluttered.
Also (to sanddrag mostly), my method of solving was based on the fact that stall torque and free speed scaled with voltage, so I whipped a quick mathematical model that did just that. Your (sanddrag's) approach went through the physics of it from the start, which is equally valid (in fact, that's where we get the linear dependence of stall torque and free speed on voltage, as well the linear performance curve between them).
Unread 23-12-2011, 16:53
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
Re: Motor Quiz
To use the phrase "deeply flawed" suggests that you have difficulty with the meanings of the ideas behind precision and accuracy.
Suggesting that because it is "still taught in high schools" and thus maybe has little relevance, is possibly offensive.
Just try a small exercise:
Imagine that the motor may rotate 3701 revolutions in a single minute. Not an unreasonable possibility. Or even that the 60 oz-in is actually 60.01 oz-in. Recalculate your answers.
Every digit that you include beyond four becomes irrelevant, it is just calculator detritus.
IMHO, sometimes people use excessive digits in their calculations of answers like curse words, to emphasize their supposed superiority where it is not necessary.
The precision of the measurement determines the accuracy of the result.
Unread 23-12-2011, 18:32
Re: Motor Quiz
Those are desired values, not measured values, and should not be considered when doing significant figures. It's assumed that Ether wants those values as close as possible.
Where significant figures should be applied is on the input values (In Aren's calculations the Free speed, Stall torque, and Spec voltage). All were given to at least 3 significant figures (It should be safe to assume that Spec Voltage wasn't 12v +/- 0.5, but rather +/-0.05 or even better).
Unread 24-12-2011, 08:15
MooreteP's Avatar
Zen Archer
AKA: Senor Mas
Re: Motor Quiz
And as the motor heats up near the end of a match?
Ohm's law breaks down, and nature takes her tax.
