Go to Post Programmer says autonomous will work 100% perfectly...Great way to clear the room of all mechanicals and all but the boldest electricals - EricH [more]
Unread 23-12-2011, 17:54
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
6WD Concept
Hello Chief Delphi,
Recently, I looked at this kit in AndyMark and wondered, "So, my team has all these parts already, what are this design's pros/cons?"
This is the configuration:
Omni wheel; standard wheel; standard wheel
More specific questions are:
This kit has the center wheel lowered by about 1/10 of an inch, would it be possible to eliminate the difference and still turn easily?
If the wheel axles were all in the same plane, the center of rotation would not rock/shift like a standard kitbot, right?
It would be possible to adapt a kitbot to use this concept, right?
Should I power all wheels?
Thanks in advance,
Daniel
Unread 23-12-2011, 18:42
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
Re: 6WD Concept
This was the format of our drivetrain in logomotion (though we did not use this kit ) It was by far the best drivetrain we have made, and it was arguably better than most 6wd robots without omni's. We DID NOT drop the center due to the fact that omnis have a slightly smaller diameter. You definitely should power all wheels in this case, even without a drop it is necessary. I do not think that It would be possible with a kit Cbase, as the center wheel is dropped. Just my 2 cents
2011 Record (11-3-0)
Unread 23-12-2011, 20:52
Re: 6WD Concept
What size (4/6/8 and metal vs. plastic) were your omni's?
Unread 23-12-2011, 23:45
Re: 6WD Concept
We used 8" omni's in the front and 8" plactions for center and rear.
Unread 29-12-2011, 00:15
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Re: 6WD Concept
You could use the Cbase, but you'd have to drill a new hole for the center axel. Just move it about an inch or so forward or backward, and keep it the same height as the outer two.
"It's NOT Just A Robot Thing!"
Unread 29-12-2011, 00:26
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: 6WD Concept
We built our 06 and 07 robots like that using the kit frame with 4 kit wheels and omnis on the front. They were both very good drivetrains.
2016 Central Illinois Winner. Curie Division finalist
Unread 29-12-2011, 03:01
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: 6WD Concept
^Reported
Unread 29-12-2011, 03:37
Joining the 900 Meme Team
FRC #0079
Re: 6WD Concept
Not having any of the parts handy... Would this difference happen to be able to be removed by flipping the CBase upside down? Just an idea that might help save some machining.
Unread 29-12-2011, 03:38
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: 6WD Concept
Or because the C-Base has the holes for 8 wheels that are level.
Set the center four wheels traction and the outer wheels omins.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 30-12-2011, 14:29
Re: 6WD Concept
I don't have the omni wheels on me right now, but if their diameter is smaller than the kit wheels/other wheels we would use, then this is an very attractive idea.
Otherwise we could use a Rotozip/mill to elongate the center hole until it is even with the other two holes. All we'd have to do then is drop in the dead axle. (optional) Axle mounts would fit inside the Cbase, and could be printed in shop.
Unread 02-01-2012, 14:27
CNettles11's Avatar
CNettles11 CNettles11 is offline
AKA: Chris Nettles
FRC #3502 (Octo-Pi-Rates)
CNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the rough
Re: 6WD Concept
If you wanted to/wouldn't mind raising or lowering the chassis, you could bolt up a few pillow blocks and have the ability to switch between dead or live axle with the same setup.
