Go to Post Part of FRC is to introduce you to how engineering is in real life: you can't use a redo card if you're landing something on the moon. - The other Gabe [more]
Unread 24-12-2011, 17:52
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: pic: Other Swerve Drive I designed while being bored
Originally Posted by Garret View Post
Thanks for the compliments.
With Battery and electronics this model weighs 70.5 lbs. This picture makes it look as if it has a lot more frame members than it really does. The frame itself weighs 7 lbs and is made of welded 1x1x1/16" Aluminum tube. All of the other parts including the modules are bolt on.
We already had these modules machined (they are the same as our 4 wheel swerve) which is why I used them in this model.
1/16th? to hold up that whole thing? I know of weight reasons why you would use 1/16th but isn't this system taking allot of stress? I wouldn't even use 1/16th on a simple 6wd... just my opinion.
