Go to Post Drive yourself, ride Amtrak or Greyhound bus, or bend space-time to the point of singularity and you'll just poof into existence in Atlanta. - artdutra04 [more]
Unread 24-12-2011, 19:28
blackrocks0 blackrocks0 is offline
AKA: Chaitanya Chittineni
FRC #2264 (Inceptus)
blackrocks0 is an unknown quantity at this point
Team 2264 t-shirt cannon
We decided to do make a t-shirt cannon. I made this thread for advice on building one, anything helps!
-CC
Unread 24-12-2011, 19:39
VKP's Avatar
VKP VKP is offline
VKP
AKA: Vivek Paramasivam
FRC #1899 (Saints Robotics)
VKP is an unknown quantity at this point
Re: Team 2264 t-shirt cannon
I would take a good look at team 254's T-shirt cannon, Shockwave:
http://team254.com/shockwave/
Most T-shirt cannons aren't this advanced (or beautiful ) but it's worth looking into their process.
Vivek
Treasurer, Senior Build Officer, Saints Robotics 1899
Seattle Olympic Regional Chairman's Award 2011
Seattle Olympic Regional Winner 2011 (Thanks 2990 & 3393)
Seattle Olympic Regional Best Website Award 2011
Unread 24-12-2011, 19:47
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
If you do a quick forum search you will find some good info, a lot of teams seem to be building canons...
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 26-12-2011, 19:03
I have looked at the threads, but many point to 254's cannon. The main issue we have with their design is we cannot find what solenoid they're using (it's out of date?) and you cannot adjust distance with it.
-Also, t-shirt cannons are a great way to promote sponsors (more money for your team) and your team.
Unread 26-12-2011, 21:06
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
To adjust for distance you simply change the pressure that you charge the system to. more pressure=more distance (in theory, at least).
Unread 26-12-2011, 22:24
I was specifically talking about the 254 cannon, they had one fast acting solenoid (no change of pressure in a pre-fire tank). I also haven't understood what pressure they keep their scuba tank at (150 psi or the 3300 psi the tank is rated for?).
Unread 27-12-2011, 00:12
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
They keep their tanks at 3000psi, they're always charged. The solenoid they use is very expensive, I can't remember where they got it. It is adjustable, although even on the shortest distance setting it goes VERY far.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 27-12-2011, 00:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
That is not correct. This would be EXTREMELY dangerous, as the solenoid is only rated to 150 PSI (I believe).
We have one tank at ~3000 psi and the "accumulator" tank at ~150 PSI.
We can sort of adjust distance by changing the time the solenoid is open for.
We got the valve from MAC. I would say that this isn't such a specialized application that the exact valve we used needs to be used.
I would encourage teams wanting to create something similar to research what's out there. We picked the valve we used for a number of reasons, safety being the primary concern. Even if the exact part number does not exist anymore there are countless functionally identical valves out there.
2001-2004: Team 100
2006-Present: Team 254
Unread 27-12-2011, 01:08
Marc S.'s Avatar
AKA: Adversity
Sorry, my mistake.
Unread 27-12-2011, 12:38
maxwellt's Avatar
maxwellt maxwellt is offline
what time is it? 540!!!
AKA: Tim Maxwell
FRC #0540 (Talon 540)
maxwellt is an unknown quantity at this point
Thumbs up Re: Team 2264 t-shirt cannon
hey check oyt team 540's t-shirt bot. here is the link.
http://www.team540.com/cms/index.php...obots&Itemid=7
winning does not= trophies
winning = learning
FRC team 540's 2011 moto
Unread 28-12-2011, 00:26
How do you manage pressure between tanks (how do you keep one tank at 150 psi?), pressure regulators are pretty expensive when you deal with ~3000 psi.
How many shots can you get off with one tank at 150psi?
Unread 28-12-2011, 03:04
GRT808's Avatar
GRT808 GRT808 is offline
AKA: Grant
FRC #3008 (Kalani Falcons)
GRT808 is just really niceGRT808 is just really niceGRT808 is just really niceGRT808 is just really nice
We based our t-shirt cannon off of 254s layout. What we used and thought was safest was the K value that connects to the 3000psi SCUBA tank and then the 150psi SCUBA regulator which is not very expensive.
The accumulating tank at 150psi for us is enough to shoot one t-shirt about two hundred feet.
Our team's page with info about the T-Shirt Cannon. Hope to get an engineering journal of it within the month.
http://kalanirobotics.com/team3008/R...velopment.html
and a video of ours
http://www.youtube.com/watch?v=Vdh5rjAcDMI
Good luck!
