Go to Post I will be here until the end of time working my butt off to inspire and enable the ever changing group of students that pass through our doors. - RoboChair [more]
Unread 24-12-2011, 13:47
Re: pic: WCP: AL Gears?
Originally Posted by sanddrag View Post
Any idea what pricing is looking like?
All prices are listed on the WCP website, which should be live a few days after Christmas (RC needs a break! This kids been working hard)
Other products include bearings, roller chain, and wheel hubs. Stay tuned!
Unread 24-12-2011, 18:26
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Wheres this said website?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 24-12-2011, 18:32
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Alex,
I have the site pretty much setup and viewable, I am just:
-Integrating a few things
-Testing stuff out
-Making sure people can't buy stuff till I have it able to ship
-Making a few tweaks.
I'll be posting it up soon for viewers.
-RC
R.C.
MadTown Robotics Team 1323
Unread 24-12-2011, 18:46
FRC #1405
Originally Posted by R.C. View Post
Alex,
-Testing stuff out
-RC
Yah, sounds good.
We just launched our new site and currently in the updating process as well.
I just sent you a pm to see if we can work some business to business stuff.
Unread 24-12-2011, 22:55
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
-The ano place, Nituff says ano should be .001 penetration and .001 build up. Normal range of build up is .0008 to .0012 according to the rep.
-The gear guy is compensating for that, I got a shop tour and talked to them about our application. They said they would cut a few gears, get them ano'd in house and then make sure it passes their QC, which is quite nice.
-RC
Does this mean that when the gears are finished and anodized, they will be the same dimensions as a "standard" gear? Would you still recommend taking the theoretical center-to-center distance ((N1 + N2 )/ 40) and adding .003"?
Unread 25-12-2011, 04:06
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Do we have any numbers on the weight saving with the alum gears over the AM ones? For say a SS or TB.
A pound or two would be very nice.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 25-12-2011, 04:15
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Aluminum is 35% of the weight of an equivalent volume of steel.
In 2007 we saved roughly two pounds per transmission over the use of steel gears. We also used delrin sideplates, piston mounts, and shift shaft-piston bearing blocks so the savings due to aluminum are probably a little less.
2001-2004: Team 100
2006-Present: Team 254
Unread 25-12-2011, 04:21
Mk.32's Avatar
AKA: Mark
How well did the delrin sideplates work out?
Unread 25-12-2011, 04:29
Cory's Avatar
AKA: Cory McBride
We used them in 2007 and 2008 and determined that there's really no reason to use them. It made more sense for us to use aluminum and pocket out the majority of the plate. The weight is comparable and the plate is much stiffer.
2001-2004: Team 100
Unread 26-12-2011, 01:18
R.C.'s Avatar
All gears will be the same dimensions as a "standard" FRC style gear.
We have used AM's 50T aluminum gear in the past with .003 spacing with Zero issues. We've also done some steel/aluminum gearboxes with .002/.001/.000 spacing. All of the above have worked pretty well.
Some older posts about gear spacing:
http://www.chiefdelphi.com/forums/sh...2&postcount=11
http://www.chiefdelphi.com/forums/sh...7&postcount=21
http://www.chiefdelphi.com/forums/sh...0&postcount=11
The recommended .003 should work great for FRC uses.
-RC
R.C.
Unread 26-12-2011, 10:13
DonRotolo's Avatar
Back to humble
FRC #0832
Here is an other example of a recommended 0.003" gear clearance:
My ancient Atlas 618 lathe uses changeable gears to set the ratio between the spindle and the lead screw, allowing one to cut several different pitch threads. The owner's manual (from the 1940s) explains that we should use a piece of paper as a clearance gauge between the gears when setting their position: Put the paper where the gears mesh and tighten, then pull the paper out, resulting in correct clearance.
Unread 13-01-2012, 16:16
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Did this die on the vine?
--Madison--
...down at the Ozdust!
Unread 13-01-2012, 16:24
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Not dead at all...
I'll let RC answer further but theyre on the way
Mentor 2415
Unread 13-01-2012, 16:36
R.C.'s Avatar
Madison,
I apologize for the delay, But it did not die.
On the thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=99327
I mentioned everything but gears will be available today and gears will be available next week.
I am receiving about 1200/2000+ gears today or tomorrow sometime and teams can start placing order for gears next week. I wanted to wait till I had the gears in stock, quality checked and made sure I wasn't sending out *garbage* to teams.
I will have Colson hubs available to order today along with bearings/chain.
I know my team: 1323 along with a few other teams are waiting for these.
Site Link: http://wcproducts.net/
-RC
R.C.
Unread 13-01-2012, 18:16
Saw a pic of the Colson hubs....look pretty baller.
