Go to Post Andy, you have daughters, would you buy them a Dave doll? - MissInformation [more]
Unread 16-12-2002, 14:17
Ken Loyd Ken Loyd is offline
Who is John Galt?
FRC #0039 (The 39th Aerosquadron)
Ken Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to behold
For the final week of the building season I would add:
a cot
a pillow
a blanket
mass quanities of Mountain Dew
Ken Loyd
Team 64
Unread 18-01-2004, 11:26
white_ChocOlat8's Avatar
white_ChocOlat8 white_ChocOlat8 is offline
AKA: white chocolate
FRC #1902 (Team EMOTICONS)
Team Role: Marketing
white_ChocOlat8 can only hope to improve
Send a message via AIM to white_ChocOlat8
Re: Tools for Rookie Team?
a cot
a pillow
a blanket
Ken Loyd
Team 64
lol nice
Unread 18-01-2004, 13:40
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
For drill bits I would recomend titinium bits. They are more expensive, but you don't need to sharpen them much and they look pretty and shinny, which is oviously very important.
I would also recomend a flash light. For some reason when working under our robot last year, I couldn't see a thing.
Unread 18-01-2004, 13:55
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Emery cloth- I thnk that is what it is called. Sandpaper for metal.
Tap Set- Useful for creating threads in holes
I have also heard my advisor mention something about a step drill bit. I forget what it is used for.
Unread 18-01-2004, 14:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Step drills are actually pretty useful. You see them used all the time on "American Chopper"
Unread 18-01-2004, 16:15
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
After reading this thread I thought of three more things to have that I haven't seen mentioned. A deburrer for removing burrs off of machined parts especially since some burrs can be so sharp you can cut yourself and not know it right away. Second a helicoil set for stripped treads. It basically consists of the helicoils (which are "springs" you insert into the stripped hole and the "spring" becomes the new thread), a drill bit which opens the hole up to the helicoil size, and the installation tool for the helicoils. This will save you when you strip a hole and you don't have time or ability to remachine a part like at competition and believe me it WILL happen sooner or later. It's also a good idea to use them in the begining on all plastic parts (delrin, polycarbonate, plexi-glass, HPDE, ect.) that require a tapped hole. Just keep in mind you will need different size helicoils for each of the different threads that are used and they don't repair stripped screws but then again a screw is easy to replace compared to a part. Our team only has them kept in our toolbox in 1/4" (or 5mm) and under since your most likely to strip smaller holes. It's also not recommended to use Loctite with them. And now finally third, counter sinks for counter sinking flat head screws and can also be used for deburring holes.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 18-01-2004, 21:09
laditek laditek is offline
laditek is an unknown quantity at this point
Yes Adam, a step drill bit for making holes larger to lighten the bot in crunch time. I believe it was 50 1" holes equal a pound.
Unread 21-01-2004, 09:15
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
As far as tools to bring to the competition, check out page 6 of Section 10 of the manual.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
