Go to Post I wouldn't want to face THAT bad boy in competition... - Iain McLeod [more]
Unread 21-12-2011, 09:40
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: pic: I was bored... so I designed this.
Just to add a quick point onto Evan's post: A 6WD swerve, in theory should also handle climbing objects a little better, depending on the object and the implementation of the swerve. A 4WD swerve would require quite a bit of ground clearance at the center, which may or may not be advantageous. A 6WD swerve would need ground clearance similar to a conventional 6WD. (For more clarification, look at some of the 4WD robots from 2010 vs the 6WD robots and you'll see what I mean.)
-Dustin Benedict
Unread 21-12-2011, 13:43
FRC #1836 (MilkenKnights)
Also, the other solution is to drive each side independently, and then turn corners together.
Unread 21-12-2011, 15:22
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
The title of this thread is "I was bored... so I designed this."
How much time did you spend on the design? I see a number of these every year and figure that there are hours and hours spent.
Thanks!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 24-12-2011, 17:29
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Sorry for the late response I have been busy the past few days. I spent about 4 nights working on this design. I designed this in 4 stages, I started with the module design, then I designed the mounting set-up, then the frame, and then finishing the assembly. Each stage was about a day of design.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 27-12-2011, 04:57
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
removed reported spam image
2001-2004: Team 100
2006-Present: Team 254
Unread 27-12-2011, 09:06
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
That design will eat bevels for breakfast. Nom Nom Nom teeth.
Since it's non-coaxial, when the module turns the drive will turn against it.
That said, VERY nice work, and just a gorgeous design.
The cantilever is not so much of a design problem - you're not going to be facing massive forces on the bushings. I don't see the bushings taking that much of a beating. You may want to consider beefing up the module itself though. It looks thin.
Team 501 Academic Advisor, Systems Build Mentor
Unread 27-12-2011, 10:01
Big Ideas Big Ideas is offline
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
It's good to see some exploration of bearing options but the application of the thrust/needle rollers on the wheel drive shaft is problematic.
1) The keyway would not be compatible with the needle bearings.
2) The counter thrust for the thrust bearing at the wheel would be by the needle bearing housing or the frame member, which is not good. A preloaded pair of angular contact bearings would be better. There is no particular side thrust to keep the thrust bearing loaded.
3) The gear separating force from the tooth meshing + the torque from the robot weight will be bending the vertical plate. It may be better to continue the removable vertical plate down the the lower shaft, so that the wheel shaft is not cantilevered.
4) Why is the wheel contact patch offset from the pivot axis? My understanding is that you want to avoid the turning force from a wheel drag moment seen at the pivot. This moment could cause twisting, scuffing, excessive drive resistance and problems with rigging to drive straight.
5) Note that I am not itemizing the many things I like about the module design.
Unread 27-12-2011, 16:20
Garret's Avatar
AKA: Garret Smalley
2)The counter thrust for the thrust bearing at the wheel would be by the needle bearing housing or the frame member, which is not good. A preloaded pair of angular contact bearings would be better. There is no particular side thrust to keep the thrust bearing loaded.
I did not realize that, but now that I think about that it makes sense. I will change that, I was working on a version that used an angular contact bearing. I have not worked with them before so I wasn't sure how to approach them.
I had a version of this that has that plate extended down to the wheel shaft. On the newest version I have completely removed the cantilever (replaced the modules with our current modules)
That is a problem I have fixed that in the newest version.
Thanks for the comments, they have been very helpful.
Here is the newest version so far.
7 Years of FRC
