Go to Post Just that the robot battery wont catch fire if you drop it the wrong way. Those LiPos pack quite a punch. - dellagd [more]
Unread 27-12-2011, 14:14
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
pic: Visible AM Shifter
Unread 27-12-2011, 14:16
GRT808's Avatar
GRT808 GRT808 is offline
AKA: Grant
FRC #3008 (Kalani Falcons)
GRT808 is just really niceGRT808 is just really niceGRT808 is just really niceGRT808 is just really nice
Re: pic: Visible AM Shifter
:O This is a beautiful render. I use Creo Elements as well but I haven't played too much with the advanced rendering as it takes quite a while.
What did you do to get it to look like this?
Did you select materials for the color?
What setting did you use for the render? Maximum?
How did you CAD the chain? Did you download it from somewhere?
Unread 27-12-2011, 14:26
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
That is one beautiful render, great work
Now my question is can you do that in Solidworks ^^ or am I going to need to install CERO...
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 27-12-2011, 15:40
I used machined steel for the gears, blue tinted glass for the plates, black glossy plastic for the encoder, some parts were chrome. I use white glossy plastic for the walls, celing and floor. They have lots of material choices that look good. (One thing I found was that too much shiny stuff doesn't work - I tried chrome plating on everything once and it just didn't look good.)
Getting the lighting to look good is probably the trickiest part. Run some draft renders to get it close but you'll probably have to do a few high quality renders to get what you want.
I haven't use Solidworks so I can't comment on it's rendering capabilities. However, it is easy to import step files into Creo to try rendering. I've heard that PTC is going to release the next version to FIRST soon so you may want to wait for that.
I built the chain model myself - it was a bit of manual work. PTC has a UDF for chains available but I haven't tried it yet.
EDIT: Also, the gear teeth were modelled using the spreadsheet I posted a few months back. (I discovered a minor bug that keeps it from working correctly - everyone who downloaded it must have been too polite to complain.)
Unread 27-12-2011, 16:00
jhouser's Avatar
jhouser jhouser is offline
MCAD $@#$@#$@#$@#$@#., Pelco
FRC #1671 (Team 1671)
jhouser will become famous soon enough
Awesome work Tom!!
Josh Houser
Mentor, Team 1671
MCAD Tools Administrator, Pelco
Clovis, CA
Unread 29-12-2011, 05:10
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'll continue refer to it as ProE until people stop knowing what I'm talking about.
Unread 29-12-2011, 06:28
It is a bit of strange deal. PTC spent 20 years or so building the Pro/E brand name and then changed it twice (first Creo Elements/Pro and then Creo Parametric.)
