Go to Post I've come to the conclusion that the only way Pat's awesomeness can be explained is.... Pat Fairbank is a cookie. - Jonathan Norris [more]
Unread 16-12-2002, 17:19
DaveG702's Avatar
DaveG702 DaveG702 is offline
#0702 (Bagel Bytes)
DaveG702 is an unknown quantity at this point
gearbox for atwood motors
Can somebody please let me know where to get a gearbox for the Atwood motors? (The large black ones that were new last year)
Unread 16-12-2002, 18:09
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
what kind of gear box do you want.....i know team 716 has thier dual with drill motor in the white pages. and i have my teams dual with drill motor and some sketches of ideas or whatnot. just check white pages and you'll find a lot
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 17-12-2002, 08:43
The most interesting post on the subject last year was the first : it was just a mounting for the cluster gear, so it would mesh with the motor shaft. From there, you make up your own procedure.
Probably the most complicated "Atwood" gearing was our system, in which a a larger hole and a keyway were EDM'd into the gear, and the gear was placed on a splined bushing a la change gears in a lathe, and the other gear on the bushing meshed with the main gear in the transmission.
Unread 17-12-2002, 10:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Sounds interesting. We were planning something of the sort for this year provided we get the Chias again. Is there a pic of this you can post or provide a link to?
Window motors / F-P gearbox Steve Motors 0 15-01-2003 07:57
Gearbox Dimensions for the Chiaphua Motors Larry Barello General Forum 8 16-01-2002 11:01
