Go to Post The extra button could also just be a spare, but that's far less interesting than other possibilities, so let's keep speculating. - Caleb Sykes [more]
Go Back   Chief Delphi > Technical > CAD
Unread 29-12-2011, 00:18
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Smile Lightening Gearboxes?
Hello Forum,
I have a question today regarding the lightening of gears in our gearboxes. Currently, our homemade, dual-shifting gearbox weighs in at around 3.5 - 4 lbs before any lightening. I know that, on our gears, there is a lot of weight we could shave off by milling into the sides.
However, what engineering principles/equations/testing can be done to optimize weight without affecting the strength/performance of our gears.
The Gearbox is fully designed in Solidworks, however I do not know how/if I could use SimulationXpress FEA modeling to complete this task.
Thanks everybody in advance!
Unread 29-12-2011, 02:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Lightening Gearboxes?
Certain geometry can be difficult to model with equations, and to be honest I've been out of it too long and my skills are rusty there. For this short-life less-than-critical application, you may design just based on others' experiences and trial and error. You could plop it into some FEA package but any professor skilled in such things will tell you the results are garbage unless you really know what you're doing, and even then it's only an estimate.
Depending on the application, based on my first-hand knowledge of 968's 2007 transmission analysis, I'd say with steel gears you're good to take them all the way down to 1/16" web thickness with holes even, and you can probably take them to 1/16" remaining beneath the dedendum circle, and maybe 3/32 around the hub bore/keyway. And it's nice to do the pocketing with a ball endmill to leave a radius where he pocket meets the tooth area or hub.
