Go to Post In the end, you get out of FIRST what you put in. - BlueLipstick [more]
Unread 29-12-2011, 21:06
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Disadvantages of swerve/crab
Originally Posted by Chris is me View Post
How many of you guys have built and tested a swerve and compared it to a six wheel?
2079 has kind of done this. We didn't really test any quantitative data, but we have run both in comparison during driver tryouts. The general sentiment from our drivers was that swerve is not as intuitive to drive (it does depend on the programming, but the programming is something that is really hard to get right).
And just from experience of doing both, 2079's 2nd gen swerve broke with much higher frequency than our 1st gen 6WD. Swerve requires a lot more fine tuning before you get it "right".
All 6 wheel drives have a zero turn radius (or at least most). Only well designed swerve drives can do this.
Both designs are good if implemented well, swerve just seems to require more effort to make it work well.
Unread 29-12-2011, 21:54
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
I'd say one big disadvantage is that it isn't very practical to implement a two speed drivetrain with swerve. You'd need to pick one multi purpose speed and gear for that, making your robot prone to being pushed around by a 2-speed 6WD bot.
Unread 29-12-2011, 22:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Well, if we're ignoring the weight and manufacturing factors as instructed in the first post...
Unread 29-12-2011, 23:00
What is impractical about making a multi-speed swerve?
Unread 29-12-2011, 23:15
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
They eat a larger chunk of the weight budget than a normal tank drive.
Only effective if you have a good driver who can capitalize on the directional freedom that a swerve offers.
Unread 30-12-2011, 00:22
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
The extra driver practice it takes to be able to master a swerve and be able to use all its features, though personally I have never done it so I can't speak from experience.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 30-12-2011, 00:35
Aren_Hill's Avatar
Build Nifty Things
The largest disadvantage I see to a swerve (once constructed and programmed) is it takes more driver practice to get to the same level as a 6wd, and then eventually surpass. Most silly humans get a little overwhelmed by the ability to go anywhere and spin any way.
sincerely,
someone with actual swerve credentials, who's spent the last few days driving around a unicorn swerve
A guy who likes robots.
Unread 30-12-2011, 00:39
AdamHeard's Avatar
Lead Mentor
Originally Posted by davidthefat View Post
Complexity of the hardware.
Which is nothing compared to complexity of software/control philosophy.
Unread 30-12-2011, 00:44
Originally Posted by Leeland1126 View Post
Apologies, I'm being quite unclear about these things right now.
By "Standard swerve", I'm not referring to anything particular about the Swerve itself. I'm referring more to a Swerve from a team who hasn't really mastered the Swerve yet (i.e. 16, 111, 118, etc.). Those teams have worked up good implementations to Swerve, and have made steps in overcoming the common short comings that go with it.
Again, I apologies. I'm being very unclear.
No need for apologies, I was just wondering what people consider a standard swerve to entail.
Originally Posted by thefro526 View Post
Also, it's worth mentioning that a team could build a 'fast' (Relative term), 'powerful' (Relative term), swerve using proven COTS components from AM and Team221 LLC - they've done the hard mechanical work for a team looking for swerve performance without swerve machining resources.
Just an anecdote of caution:
Using the 221 modules in 2010 was pretty cool; we learned a lot about the mechanics of a swerve. But with only a week to figure out how to program the swerve - our team just made an idiotic decision to go with this drive over our 8wd design, even after we were told we wouldn't get our modules until after week 3. This stupid decision was made because students and mentors got entranced by the "coolness factor" of swerve. It had no place in the 2010 game. Even with a full practice swerve to play with and program, we had only just started to figure out the best controls for the swerve WHILE in Atlanta that year. It is a HUGE learning curve for even the best programmers. (we had students and programming mentors working on it). All I'm trying to say is that even with the mechanics pretty much figured out for us through COTS parts, the programming and sensory involved took a long long time to figure out. It is hard to express my abhorrence for the decision making that went on that year.
Unread 30-12-2011, 00:48
Aren_Hill's Avatar
Build Nifty Things
Ignoring the original posters statement?
Originally Posted by MICHAELABICK View Post
Simply, there is none. An independent coaxial swerve, programmed perfectly, will be the best drive out there. The one performance disadvantage, is that if one module brakes, your whole drive system is down
Oh really? lost a drive chain on an 8motor swerve to one of the modules recently and kept on driving just fine, barely noticed...
One of the largest Pro's to swerve is almost never having to get into pushing contest you don't want to, in many cases rendering 2 speeds not necessary. (keep in mind i had a 2 speed swerve in 08, using COTS AM gen2's....so the 2 speed part really didn't require much work on my end)
I've got a few concepts that could hit < 35lbs for complete chassis with completely independent module power and steering, so weights only really an issue if you aren't trying hard enough
Please only post things when you KNOW them, preferably from experience, or as some have done, put a proper disclaimer
Unread 30-12-2011, 01:32
craigboez's Avatar
Mechanical Engineer
Should have clarified, it is impractical if you're using 4 wheel swerve with one CIM at each wheel. If you're using a central "power plant" then it becomes much more practical.
Unread 30-12-2011, 01:53
Chris is me's Avatar
AKA: Pinecone
973 just posted a neat little CAD model of an 8 motor independent shifting swerve...
Unread 30-12-2011, 01:54
AdamHeard's Avatar
Lead Mentor
Yup.
Any team with a manual mill and a waterjet/laser sponsor could make such a thing as well.
Most teams are capable of getting such sponsors and machines.
Unread 30-12-2011, 02:00
craigboez's Avatar
Mechanical Engineer
Wow, very impressive. I didn't think that was practical, but they went and proved me wrong.
Unread 30-12-2011, 02:07
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
As has been said earlier, driver practice is the main bump in the road (so to speak). If you plan on building a swerve drive, prototype it in the offseason. We didn't, so even though our swerve worked perfectly, we modified it to drive like a tank.
As with everything, practice makes perfect.
I wish you luck if you decide to go for it. It's one of the coolest drive systems out there.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
