Go to Post In most cases on FIRST robots, we have more material than in we need in some places and less than we need in others. That single phenomenon is the leading cause of robot failures. - Paul Copioli [more]
  #31   Spotlight this post!
Unread 30-12-2011, 02:48
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Disadvantages of swerve/crab
Isn't it generally accepted that a more complex system fails even harder? More moving parts allow for more chances of something going wrong? I believe that is a serious flaw in performance.
  #32   Spotlight this post!
Unread 30-12-2011, 03:09
evoluti1's Avatar
evoluti1 evoluti1 is offline
AKA: Joe
FRC #1197 (TorBots)
evoluti1 has a spectacular aura aboutevoluti1 has a spectacular aura about
NASA even has a phrase for this: "The higher the tech, the bigger the wreck." It might be a little late in the game to be thinking about a crab drive at this point. My team wanted to do crab drive this summer, but earlier this month we realized we simply didn't have time to finish and refocused our efforts towards a WCD.
Your team may be different, of course. If you have the financial/technical/mentor resources to make a crab drive happen during season, go for it. But from what I've seen, only very elite teams have those kinds of resources, and even most of them prefer to stick with something simpler.
You have to remember, this is real life. Of course, a "perfect" crab drive beats any other drive on the field. But the level of quality/perfection that makes a crab drive competitive is very difficult to achieve in the real world.
  #33   Spotlight this post!
Unread 30-12-2011, 08:46
Jared Russell's Avatar
Taking a year (mostly) off
* Often less intuitive to drive than skid steer robots
* There is latency to all changes of direction because module steering is never instantaneous
* Geometry of swerve (assuming normal bumper zone rules) means that wheels cannot be put as far out to the edges of the chassis as in a skid steer case (may make being tipped easier)
* On uneven terrain, one or more motors may be unable to deliver power to the ground
* Unless you build an all-wheels-driven-and-steered-independently ("unicorn") swerve, there will always be certain combinations of manuevers that you cannot make.
  #34   Spotlight this post!
Unread 30-12-2011, 09:55
Originally Posted by Akash Rastogi View Post
Even with a full practice swerve to play with and program, we had only just started to figure out the best controls for the swerve WHILE in Atlanta that year.
In the above context, "the best controls" sounds like you are referring to the driver interface. What driver interface did you finally decide was the best for your team?
It is a HUGE learning curve for even the best programmers. (we had students and programming mentors working on it)... even with the mechanics pretty much figured out for us through COTS parts, the programming and sensory involved took a long long time to figure out.
Could you elaborate just a bit and list the top three (or whatever) things that made the learning curve huge and which took a long time to figure out? It might be helpful for other teams on the verge of making a similar decision.
  #35   Spotlight this post!
Unread 30-12-2011, 10:21
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
That's actually pretty quick as far as I'm concerned. 2079 built a prototype swerve before the 2008 season, we build a swerve drive for the 2008 season. We made our third iteration for the 2009 season. We just started to get it where we wanted it at the end our second regional in 2009. They have since ditched the idea of swerve do to complexity and lack of a fully intuitive algorithm for controls.
The real thing is that swerve is just harder to make well. It's not better or worse than any other drive train.
  #36   Spotlight this post!
Unread 30-12-2011, 12:52
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Theoretically, if you had unlimited resources, unlimited manufacturing time, unlimited programming time, and unlimited driver practice time, to build a "perfect" swerve drive, it would be clearly better than any other drive train. I would consider a "perfect swerve drive to be: all wheels independently powered, steered, shifting, never breaks , low weight, very low delays in turning the wheels, driver can intuitively control all functions, no repercussions on other systems.
Its pushing strength would be as good as a low speed skid steer,
its speed would be as good as a high speed skid steer,
its acceleration would be as good as any robot of similar weight,
its omnidirectional ability would be as good as mecanum/omniwheel drive
However, any real team does not have unlimited resources and time. As a result, most swerve drives do not achieve that performance. Some teams have gotten close, and these teams have generally been very successful, (148 in 2008, 111 in 2009). The problems with a swerve have to do with the real challenges of making one work like it is supposed to without massive tradeoffs, and not with any inherent disadvantage to swerve.
  #37   Spotlight this post!
Unread 30-12-2011, 13:19
You didn't mention anything about waiving FRC rules, so I assume you are still limited to the legal type and number of motors.
I think the jury is still out on whether it is possible to steer the wheels on a swerve fast enough to make swerve "omnidirectional ability" as good as a well-built omni or mec.
  #38   Spotlight this post!
Unread 30-12-2011, 13:32
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
What Jared said.
Also, FIRST has literal strategies that jack-of-all-trades swerve just isn't the best for. Of course, if you want to master a single "trade", swerve isn't necessary. But even if you want more, swerve gives you two things--reasonable holonomic-ness and reasonable traction--all the time. If you want, say, better holonomic drive sometimes and unmovable traction other times, something like switchable wheels/Octocanum could be better. Etcetera.
What is impractical about making a multi-speed swerve?
Depends. If you're doing a limited swerve/non-coaxial, adding a shifter isn't so hard. Maybe heavy, but at least you're not rotating it and probably don't need so many. In a co-axial, you're driving each wheel independently and rotating the drive motor/gearbox with the module. Adding a shifting mechanism gets really big and heavy (and expensive and complicated) really quickly. We do all our gear ratio adjustment via belt pulleys and planetary gearboxes. After two years of working on the drive, "impractical" still seems like a pretty good word for trying to mount an AM Supershifter on this, but maybe there are more streamlined shifters?
That said, we tend to win our pushing contests.
Originally Posted by AlexH View Post
Only effective if you have a good driver who can capitalize on the directional freedom that a swerve offers.
Moreover, only if you have enough good drive time with your chassis to get this capitalization experience. We've done poorly in this area for the first two years, but now that we have essentially optimized hardware, getting-close programming and excited drivers, this is huge.
Originally Posted by Aren_Hill View Post
I've got a few concepts that could hit < 35lbs for complete chassis with completely independent module power and steering, so weights only really an issue if you aren't trying hard enough
Wow, that's great! Our modules are at 9.1lb each with a 14.1lb chassis weldment. How'd you get it to 35lb total?
  #39   Spotlight this post!
Unread 30-12-2011, 14:17
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
One obvious disadvantage is the endless debate they engender.
One clear advantage is the endless debate they engender.
Blake
  #40   Spotlight this post!
Unread 30-12-2011, 14:52
Sure thing! Best is the wrong word too, "better" is the correct choice. We started off with a single 3D Pro joystick to control the drive system, but did not get a chance to figure something else out until later in the season which was using a joystick for throttle and then used the 3d joystick for rotation. It isn't best, but it was as far as we got before we decided to put off swerve until future offseason projects. But even then, we ended up using the override button on the joysticks which turned it into a 4 wheel tank drive most of the time.
I'd say some of the biggest issues we had were 1. being dumb and not using a 1:1 reduction for the rotation, 2. getting the modules perfectly synched, and 3. realizing too late that we should have used higher quality sensors than we did.
Big problem was that our drivers expected a perfect response time from the modules everytime they wanted to move somewhere, but our gearing and sensors significantly delayed response time.
  #41   Spotlight this post!
Unread 30-12-2011, 14:57
Andrew Lawrence
Posts: n/a
How significant? Was it like major lag between controller input and movement, or more like a small yet noticeable change between input and movement?
Also, what gearing did you use, and which sensors? Which would you recommend of both?
  #42   Spotlight this post!
Unread 30-12-2011, 15:09
It did what seemed liked a small change between input and movement sometimes, but later on that was fixed. The delay later on was, to me, significant because I did not know what to expect. It was just not instant as we all wanted, and I think this also happens to a lot of people when they first try swerve. The team might be under the impression that they'll get prefect turning and response from the get-go. However, with optimized systems such as 973, 111, 16, I suspect they see the kinds of results we expected: instant response (or close to).
As for the gearing, I'd have to go back to the CAD as I don't recall. The CAD should be somewhere on the Autodesk website from 2010 if they still archive that stuff.
  #43   Spotlight this post!
Unread 01-01-2012, 18:33
Aren_Hill's Avatar
Build Nifty Things
Well over thanksgiving I rebuilt 1625's 2010 practice chassis (was 6wd swerve) into an 8 motor independent swerve, that came in a 41lbs,
Mainly its just sitting there staring at a concept going "how do i get rid of that....and why is that even there?" when looking at parts
current one i have almost ready to go is 6lbs flat per module (including CIM and steering motor)
A guy who likes robots.
  #44   Spotlight this post!
Unread 01-01-2012, 19:37
Siri's Avatar
Dare greatly
That's awesome! Great job. Do you have CAD or photos?
  #45   Spotlight this post!
Unread 01-01-2012, 19:38
Aren_Hill's Avatar
Build Nifty Things
That ones sitting nice and quiet in the back pocket till it gets used
