Go to Post Have you ever found yourself staring at a physics problem, not understanding it, then connected it to a past FRC game and suddenly felt the light bulb start shining? - StephLee [more]
Unread 31-12-2011, 02:23
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
Attaching AM Super shifters to chassis
I'm curious of different ways that teams have attached the AndyMark Super shifters to their chassis. I am mainly interested in ways that allow for direct driving to the wheels and leave it in the original casings.
Similar to how team 330 mounted theirs last year (see link).
http://www.chiefdelphi.com/media/img...6fce0983_l.jpg
If you could help me by explaining your teams method of mounting them, any problems you encountered, how they performed, and alternative ideas for mounting them it would be greatly appreciated.
*I'm mainly looking for experienced opinions from people who have worked with SS before.*
Thanks in advance!
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 31-12-2011, 02:48
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: Attaching AM Super shifters to chassis
I literally just designed this today
So here it is. It mounts on the outside of the case using the four screws that hold the SS case together. This model is by no means finished (or tested), but we have done something similar in the past. Hope that this sparks someone's imagination.
If you wan't to pursue this I can upload the finished version of this tomorrow (with a SS shown).
Name:	SS mount.png
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 31-12-2011, 07:14
Billfred's Avatar
Billfred Billfred is offline
I'm no fabrication expert, but how exactly do you envision building that? There may be a way for all I know, but I'm not seeing it right now.
Unread 31-12-2011, 07:47
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
We have replaced the standard bolts and bolted through our frame with either 2,3 or 4 bolts, depending on our chassis.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 31-12-2011, 07:53
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
We bolted ours right to the frame using slightly longer bolts than supplied by AM. Never had an issue, though, if I were going to do it again, I wouldn't bolt through the transmission, just through the face plate. Makes some service work a bit easier when one of the plates is still rigidly mounted.
Here's a picture of our 2011 mounting: http://www.chiefdelphi.com/media/photos/36163
-Dustin Benedict
Unread 31-12-2011, 07:57
Rookie Year: 1942
I am not sure how you would do this. The existing bolts are thru bolts. Bolting thru the complete transmission makes sure the case stays "tight" and the gears stay aligned.
Chris Fultz
Unread 31-12-2011, 09:00
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
You could weld it, or there's always the expensive way.
Unread 31-12-2011, 09:54
thefro526's Avatar
Mentor for Hire.
Sorry. I was a little vague here. We discussed ways to make shifter maintenance a little easier by our second competition and one of them was to drill two extra holes in the outer face plate and use those for mounting. The through bolts would then just hold the trans together, meaning we could take the trans apart without removing the shaft to the center wheel. (Having to pull the center wheel was a big PITA on our 2011 robot, good thing we only did it once)
-Dustin Benedict
Unread 31-12-2011, 11:09
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
FRC Designs (http://www.frc-designs.com/) has a few CAD designs of robots that use varying methods. Check out the 2011 CAD Robot Page and Drives page for more information. I hope this helps!
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 31-12-2011, 14:38
Build Lead
Lets just say that the year that we did this, our Boeing mentor got lucky with the scrap pile and found a piece that only had to be slightly modified to make this work. Otherwise, it would be impractical (which is easier to see now then it was at about 1PM).
Long story short, disregard my earlier post. Way to expensive/ impractical to manufacture.
Unread 31-12-2011, 15:01
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
You could weld (or maybe rivet?) a c-channel to a flat plate, but in that case you could just attach the c-channel directly to the existing faceplate of the SS, which might work for something. So it's not a wholly bad idea, you just don't have the best implementation.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
