Originally posted by Dr.Bot
Due to a rare leak of information, I have it on absolute 100% certainity that there will be goal(s) involved in this year's game. Since these goals must be built, I can safely assume they will be made from matter, elements found in this universes periodic table of elements.
You must have seen a different rare leak of information than I did. I heard that there would be goals, but no construction would be required. Instead, each kit would include seven "Carter's Little Goal Pills" and one
Alludium Q36 Explosive Space Modulator. Turning the Alludium Q36 Explosive Space Modulator on the pills would cause them to phase shift through a minute wormhole from the X dimension (where all the Alludium Phosdex is kept) to automatically deploy the entire play field, goals, scoring objects, and the necessary artificial snow-making equipment.
But, of course, I could be wrong.
-dave
Y = AX^2 + BX + C
