Go to Post Rule 1. Never take Dave's hint's seriously. Rule 2. Watergame. - AndyB [more]
Unread 01-01-2012, 21:09
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
pic: NanoShifter
Unread 01-01-2012, 21:10
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: pic: NanoShifter
This render is amazing
Unread 01-01-2012, 21:11
Andrew Lawrence
Posts: n/a
AMAZING! That is just (insert word to majorly increase awesomeness)ing awesome!
How much does it weigh?
How stable is it?
When and where will I be able to get one?!
Unread 01-01-2012, 21:12
Chris is me's Avatar
AKA: Pinecone
If you could make the final ratio faster I imagine it'd be a cool / compact way to do a 4" wheel transmission. Gotta get rid of that mecanum wheel first though.
Unread 01-01-2012, 21:18
If you went with 4" wheels, the standard AM shifter gears would work. I'm not sure it would make sense to do it though, if you did a 6 wheel drive you'd need 6 of these. May only make sense with Mecanums.
Unread 01-01-2012, 21:22
Andrew Lawrence
Posts: n/a
The way I see it, depending on the weight of these things, and the do look light, one could use 6 of them, one per wheel, or at least 4 of them, 2 on each side, making a very powerful drivetrain.
Excellent gearboxes for mecanums, however I see a lot more use in these than mecanum wheels.
Unread 01-01-2012, 21:45
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
If you used six, you would have to have six motors in your drivetrain. Also, if you used 2 on each side for a non-omidirectional drivetrain, you would save weight by simply using one transmission. The power would be the same since the motors supplying the power are the same as they would be with two gearboxes.
I agree that there are more uses for them than mecanum, they could be useful in swerve and omni-drives. But they could also be useful in non-drivetrain applications like shooters.
Unread 01-01-2012, 21:48
Andrew Lawrence
Posts: n/a
If 2 of those weigh less than one of the standard transmissions, it'll be less weight no matter what. Plus, you gotta admit: Just by seeing it you wanna use it on a robot.
Unread 01-01-2012, 21:57
A standard Nano weighs 4.8 lbs without motors. I can't imagine shifting ones weigh too much more.
A SuperShifter weighs 4 lbs. without motors and pneumatics.
AM Shifter weighs 3.4 lbs. without motors and Pneumatics.
I would just stick to the standard SuperShifters or AM Shifter.
Unread 01-01-2012, 22:01
Andrew Lawrence
Posts: n/a
Fine, don't use the really cool greatly rendered awesome-sauce gearboxes. :|
Unread 01-01-2012, 22:03
Jared Russell's Avatar
Taking a year (mostly) off
A ToughBox Nano weighs ~1.7 lbs...?
Were you thinking of a NanoTube?
Unread 01-01-2012, 22:04
AdamHeard's Avatar
Lead Mentor
If designed right the additional weight going from a single to two motor gearbox is a little more plate, and an additional pinion gear; far less than a second set of gears.
Unread 01-01-2012, 22:49
Haha. Good catch. I was indeed thinking of the Nano Tube
Unread 02-01-2012, 10:21
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
First, amazing render. I don't think anyone here will ever get tired of these types of ideas, so don't feel the need to 'quit'. They're creative and are a spring board for a final product.
Any way the encoder can be re-incorporated into the gearbox?
It also appears that the inner races of the bearings on the last stage touch the inner races of the bearings in the housing. Would this cause a problem due to the difference in speed of each shifting gear?
GitHub
Unread 02-01-2012, 10:43
You have a good eye for detail. If this was real, I'd put a thin washer between the inner races like the bearings on the other side of the same shaft have.
The easiest place to put the encoder would be on the cluster shaft. This could cause a few problems - getting it to clear the CIM might be an issue, the speed might be too high for the encoder and you need to know for sure which way you were shifted.
That brings up another challenge - if 3 of the positions shifted and the 4th didn't you'd have a mismatch. If the shift position was detectable you could compensate the CIM speeds and get a "limp home" mode.
If the encoder didn't work on the clutster shaft, I'd probably try to change the shift cylinder setup so I had access to the end of the shaft (not sure what that would look like.)
