Re: A Physics Quiz of a different type
Wouldn't it be slightly slower than c because of the air and lens of the flash light.
Still has a flash light with a lens, although I suppose he could remove it.
Of course you still have the glass of the bulb...
The speed of the light is slower only while it is in the glass. Once it leaves passes through the glass it resumes its normal speed. |
That makes sense.
#7
I'll take a stab at your problem, Ether.
System 1 (XY): The relative speed of the two particles is c/2-(-c/2) [speed of A - speed of B], which results in 2*c/2 or c, relative to each other, as viewed from a neutral position. System 2 (X'Y'): In this case, the system is fixed onto Particle B in the above problem, which is assumed to be moving at -c/2 (from the reference point in System 1's point of view). The relative speed remains the same, as the motion did not change (if viewed from System 1's reference point), so observers on Particle B see Particle A leaving at speed c. Which brings up the question: Do observers on Particle B really see Particle A, or does it just vanish as it moves? There are some related thought experiments, such as the speed of a bullet fired going forwards versus the speed of a bullet fired going backwards (to an outside observer); in Al's particular case, the real question is does an observer in another reference frame witness light traveling at 2*c? (And if so, does that redefine the speed of light in that observing reference frame? ) |
#8
An observer sitting on Particle B (i.e., in reference frame X'Y') will observe Particle A's speed to be (c/2+c/2)/(1+(c/2)(c/2)/c^2) = 0.8*c Last edited by Ether : 02-01-2012 at 00:08. Reason: fixed typo in equation |
#9
And yeah that. That's the velocity transform: u' = (u+v)/(1+uv/c^2), u is the particle's velocity, v is the velocity of the prime frame relative to the non-prime frame. Last edited by Aren Siekmeier : 02-01-2012 at 00:17. Reason: fixed |
#10
The relativistic addition of velocities is (u+v)/(1+u*v/c^2). |
#11
Heh, yeah, a little dimensional analysis would tell you that much.... I'm tired.
