Go to Post And your other point, "why a debate over a nonexistent rule?". Its summer, we're not building robots, and we're geeks. What else are we supposed to do? - EHaskins [more]
Unread 02-01-2012, 00:21
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
Pneumatic Tubing Specs
Does anybody know the size/pressure specs of the standard FRC pneumatic tubing? Trying to find it on www.freelin-wade.com
Thanks,
Nathan
Unread 02-01-2012, 00:28
BlacksmithWoods's Avatar
BlacksmithWoods BlacksmithWoods is offline
Mechanics / CAD
AKA: Brendan Woods
FRC #0806 (The Brooklyn Blacksmiths)
BlacksmithWoods is on a distinguished road
Re: Pneumatic Tubing Specs
Yes, they have all the psi ratings on both Andymark.com aand Bimba.com.
I found the standard Pneumatic tubing on AndyMark.
http://www.andymark.com/product-p/am-2028.htm
If you are leaning more towards pistons and that sort of thing then Bimba is more your way.
-- Hope This Helps,
Brendan
2002 - Present FRC (806)
Keeping It Stupidly Simple since 2002
"You are done with designing something, not when there's nothing more to add, but when there's nothing left to remove." - EricH
NYC FRC STLA (2011- 2014) Practice Field / Alumni Relations
Unread 02-01-2012, 00:40
John Wanninger's Avatar
John Wanninger John Wanninger is offline
FRC #1732 (Hilltoppers)
John Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond repute
Thanks,
Nathan
<R66> of the 2011 FRC Manual specified 0.160" I.D and 125 PSI working pressure, 250 PSI burst. The 0.160" ID/0.250" O.D. "Fre-Thane 95A" appears to meet those requirements.
"A hundred times every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving..."
--Albert Einstein
2001: FLL852 |2002: FLL20/FLL21 |2003: FLL23/FLL25 |2004: FLL14/FLL16 |2005: FVC22/FLL124 |2006: FLL3/FLL2986/FVC22/FRC1732 |2007:FLL3/FLL34/FLL56/FRC1732
2008: FLL3/FLL18/FRC1732 |2009: FLL101/FLL8963/FRC1732 ...(etc.!)
Unread 02-01-2012, 01:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Does anyone have a McMaster part number equivalent for the pneumatic tubing we get in the kit of parts? I recall getting some tubing from them once and it was very different.
Unread 02-01-2012, 02:16
nnfuller's Avatar
AKA: Alumni
FRC #2733 (Pigmice)
Do you think that using tubing with an inside diameter of .125 instead of .17 would greatly effect performance?
Unread 02-01-2012, 02:39
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Instead of effecting performance, you'd fail inspection (according to the 2011 rules), and thus be unable to perform at all.
It would also positively negatively affect performance, but probably not as much as you'd expect. There's a lot of flow restriction in FRC-legal valves, and that tends to dominate in a lot of systems.
Last edited by Tristan Lall : 02-01-2012 at 14:59. Reason: Smaller tubing has a negative effect. That's what I meant to write....
Unread 02-01-2012, 02:41
Yes, it would. The speed would be affected (if I'm not mistaken, it would be faster). For another, the OD is what governs fit in fittings, and a smaller ID results in a smaller OD (or a thicker wall for the same OD), which affects how it fits in the fittings. I've seen very nearly identical pieces of tubing not fit the same in a fitting, though... but it wasn't the style normally used in FRC.
And, perhaps more importantly, 2011's <R65> and <R66-D>, read in that order, will tell you that anything other than 0.160" ID tubing functionally equivalent to the KOP tubing (or in the KOP) is prohibited for the 2011 season. This is one of those rules that is change-resistant; I would not expect it to go away for 2012.
Unread 02-01-2012, 07:30
While everyone thus far is correct, please read the 2012 rules and note any changes to this part of the rules. 2012 rules will be the only ones that apply to the 2012 season.
Unread 02-01-2012, 09:33
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Last year Freelin-Wade offered a 50% discount for FIRST teams through their online store protubing.com
Here is the link to last years code.
Unread 02-01-2012, 09:50
Gdeaver Gdeaver is online now
FRC #1640
Andy-Mark tubing is .17 ID are they not selling 2011 illegal tubing? There is nylon and polyethylene tubing that have better pressure ratings but, larger ID's so they also would be illegal even though they are tougher.
Unread 02-01-2012, 14:57
Maybe they know something we don't?
Actually, this is precisely the reason FIRST needs to specify tolerances in the rulebook.
Does FIRST actually care about this difference, and how are the teams and inspectors supposed to know? The Q&A, with its delayed responses, blackout period and low readership is insufficient compared to the dead-simple alternative of "Ø0.160 ± 0.015 in" "MAX Ø0.175 in". (Note that Freelin-Wade specifies Ø0.160 ± 0.005 in for the ID of the polyurethane tubing in the kit, and Ø0.170 ± 0.004 in for their low-density polyethylene tubing. If FIRST didn't care which one teams used, they would want to specify a large enough tolerance to cover them both—hence ±+ 0.015 in.)
Edit: Wait—why am I giving a ± tolerance? I should have recommended MAX Ø0.175 in. FIRST can't possibly care enough to intend to prevent a team from competing with undersized tubing. (That has happened; an unfortunate consequence of enforcing the rules.)
Unread 02-01-2012, 15:05
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
As others have said, the 2011 rules may or may not apply to the 2012 rules.
However, based on my experience over the last 7 years, pneumatic tubing has been pretty much the same. 0.16 ID, 0.25 OD, 125PSI.
From Mcmaster-Carr, these part numbers would be the ones to use:
Opaque Black 9149T21
Opaque Blue 9149T24
Opaque Green 9149T22
Opaque White 9149T23
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 03-01-2012, 00:23
kellymc kellymc is offline
FRC #0766 (Bears)
kellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to behold
They are also giving a discount this year, contact them through their website and they will send you the code and also tell you the tubing specs that they supply in the past kit of parts.
Unread 03-01-2012, 10:09
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
No, AndyMark does not "know something we don't". While they provide a lot of FIRST-legal stuff, and are FIRST's partner for FIRST Choice, not everything on their site has to be FIRST-legal. AndyMark is a business just like any other place you'd buy stuff to put on your robot.
All that said, please note that the Pneumatic Tubing available on FIRST Choice does not have specs on AndyMark's website (and even the picture of the black tubing is different from that previously posted). The link to the product website specifies 14 different specs, one of which includes the 1.6" ID tubing we've had in the past.
So... Everyone should just wait 4 more days before purchasing any pneumatic tubing for the season
Unread 03-01-2012, 12:21
AndyMark frequently knows some things we don't. That's a non-rebuttable statement, given that they handle FIRST Choice and have regularly supplied KOP items (including custom ones for which advance knowledge would be unavoidable).
It wouldn't be a stretch to wonder if they might have accidentally suggested something about the 2012 KOP specs by offering non-KOP, but compatible tubing themselves. Another possibility is, as you mentioned, that they offer it independently of their FIRST offerings. (If it's not FRC-legal, the lack of a disclaimer to that effect will be less than ideal after the 2012 kickoff, given that FRC is their principal market.) In this case, you're correct that they list what appears to be the conventional Freelin-Wade KOP tubing under the FIRST Choice 2012 catalogue. (And of course none of this can easily be confirmed or dismissed until the manual is released. I'm prepared to wait.)
