Go to Post Doesn't make sense, Karthik. ...... You don't scare me, other than the way 1114 normally does. - EricH [more]
Unread 02-01-2012, 16:51
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Simple 2-Speed 6WD for teams with few manufacturing resources
In the Fall each year, I often give presentations to Washington state teams about drive design and considerations. In my most recent presentation, I recommended that teams investigate the popular new "Kitbot on Steroids" concept put forward by 1114, but did so with no real experience with the kitbot or modifications of it of my own. I trust 1114 enough to know that the advice is good advice, but I wanted to see what it would take to build an enhanced Kitbot and to do so with as few manufacturing steps as possible.
The design requires the following power tools:
  • Band saw
  • Drill Press
  • Scroll Saw
  • Belt Sander
  • Grinding Wheel
The design was built around the following requirements:
  • High traction 6WD wheel arrangement
  • Shifting 2-speed transmissions
  • 4 CIM motors for drive
  • Active chain tensioning
  • Electrically isolated control systems area
  • No precise machining required
  • As many COTS parts as reasonable
I will continue adding to this thread with more detailed information. I hope to include a complete bill of materials, more detailed views of wheel and tensioner assemblies, and maybe even drawings.
There's a STEP model attached. It isn't perfect; I took some shortcuts and so, if you look closely, you'll find that some of my bolts aren't located quite properly. By and large, though, I think it's accurate enough to work from.
File Type: zip FRC488_KoS_CompleteDrive_010212_rev-.zip (1.58 MB, 48 views)
--Madison--
...down at the Ozdust!
Unread 02-01-2012, 17:16
Madison's Avatar
FRC #0488 (Xbot)
Re: Simple 2-Speed 6WD for teams with few manufacturing resources
I'll start with the bill of materials.
All prices are per item/package
Frame
(1) - C-Base Chassis Kit (AM-0952) - $155.00
(2) - AM Shifter w 2.56:1 Spread (AM-0001) - $350.00
(4) - 16 tooth, 1/2" keyed bore #25 chain sprockets (AM-0277) - $11.00
(1) - 3/8 Screw Size x 2.5" Long Nylon Spacer (94639A621) - $8.62
(1) - 3/8 Screw Size x 1.25" Long Nylon Spacer (94639A863) - $6.80
(1) - 32" x 48" x 1/8" Thk Perforated PVC Sheet (92985T25) - $51.11
(1) - 12" x 24" x 1/4" Thk ABS Sheet (8586K372) - $23.95
Wheels
(6) - 4" x 2" VEX Pro Wheels (IFI-WHEEL-420-38) - $39.95
(6) - 4" x 2" Roughtop Tread (ROUGHTOP-420) - $4.95
(4) - Sprocket Hardware Pack (IFI-SPROCKET-HDWR-X8) - $3.99
(2) - Dual Sprocket Mounting Hardware (IFI-SPROCKET-HDWR-DUAL) - $4.99
(8) - 36 tooth, #25 chain flat sprocket (AM-0099) - $11.00
Tensioner
(1) - 9/16" ID x 1/32" Wall Thkness Nylon Tube (8628K57) - $4.90
(1) - 1/4" Schedule 40 PVC pipe x 48"
(16) - 1/2" Wide Flat Washer
(16) - 1/4" ID Compression Spring
--Madison--
Unread 02-01-2012, 17:52
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Wouldn't 35 chain be better, as it is more tolerant to misalignment
Also http://www.andymark.com/product-p/am-0836.htm might be a better choice for a belly pan since it is already drilled out.
But it sure does look nice; we are debating whatever to do custom or kit frame this year and this definitely is a nice reason to do kit.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 02-01-2012, 18:01
Madison's Avatar
FRC #0488 (Xbot)
#35 chain will be more forgiving of misalignment, though saying that it is better is probably a stretch in my mind.
The stack up of parts for each wheel fits pretty closely into the width available within the C-Base, so located everything should be pretty straightforward. The mounting plate that supports the transmission is the part that can lead to the most trouble and is, honestly, probably the weakest part of the design. I hope to provide an alternative gearbox setup using Super Shifters and eliminating that plate. I went down that route first because I started designing with my team in mind and making that part is trivial for us. Similarly, we have a lot of parts on hand for #25 chain and none for #35 chain.
That being said, the design works just as well with #35 chain. The AM shifters come with #35 sprockets anyhow. Replace the 36 tooth #25 sprockets with 26 tooth #35 sprockets (AM-0142) and the ratio remains pretty much unchanged. The IFI sprocket mounting hardware is all designed to accommodate #35 chain, so spacing everywhere should be fine.
Edit to add:
The AndyMark perforated sheet works just as well. The McMaster-Carr part number I included is what we've used in the past. It's also pre-drilled. It's PVC rather than polycarbonate as well, for what that's worth.
--Madison--
Unread 02-01-2012, 18:12
Mk.32's Avatar
AKA: Mark
What are the differences between the PVC and the polycarbonate for this kind of application?
Unread 02-01-2012, 18:19
Madison's Avatar
FRC #0488 (Xbot)
There's probably little appreciable difference, really. The PVC is a bit lighter, I think, but the polycarbonate is probably a bit more rigid. Six of one and half a dozen of another.
--Madison--
Unread 02-01-2012, 18:26
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Thanks Madison!
Quote from @FRCDesigns
The Simple 2-Speed 6WD from FRC488 has been added to FRC Designs! Check it out! http://www.frc-designs.com/html/drives.html
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 02-01-2012, 18:36
Andrew Lawrence
Posts: n/a
Looks great! Love it!
A few questions:
1) Why 4"x2" wheels? Could 4"x1" work as well?
2) (From a business point of view) Why would you say this chassis is "better" than 1114's KoS?
3) If you were to name 3 distinct features about your chassis, what would they be?
Overall, great design, great features, great everything!
Unread 02-01-2012, 18:49
Madison's Avatar
FRC #0488 (Xbot)
A few questions:
4x1" wheels could work just as well, but I used 4x2" for two reasons:
1. There's been some talk here lately about 4x2" wheels giving a bit more pushing power than 4x1" wheels and I was curious if they could be made to fit easily into a COTS frame
2. The wider wheel actually makes it possible to use COTS spacers for the axles. A narrower wheel would require spacers that are longer than are available from McMaster-Carr. It's trivial to buy longer stock and cut it down, but I like shopping, not machining
I wouldn't say that it's better than 1114's KoS. I've seen only their brief video about the KoS assembly, so I am not even entirely sure of what their recommendation requires. This was just my stab at the idea of an enhance Kitbot.
There are few things about it that are clearly different; it uses a shifting transmission instead of those included in the kit, it uses 4" wheels rather than 6" wheels and the transmission mount and tensioner design suck
--Madison--
Unread 02-01-2012, 18:53
Andrew Lawrence
Posts: n/a
I THINK we may end up using this this year, that is is 1114 doesn't release their KoS soon! (Karthik, that's your cue!)
IMO, just get correctly sized chain and the tensioners won't be needed. Once again, great job! Now let's try and see how you can make this better, since improvement is always fun!
EDIT: Madison, is there any way possible to make the attached file Mac-friendly? I can't seem to open it, and now that I've downloaded it's like waiting for a game hint 4 days before kickoff!
Unread 02-01-2012, 19:18
Madison's Avatar
FRC #0488 (Xbot)
The C-Base makes it impossible to adjust the center-center distance between wheels, so while things are an even number of pitches between wheels, the gearbox isn't an even number of pitches without shimming it upward some. This might be fine, but the tensioners also up to get the chain away from the floor; it isn't always necessary to do that, but I try to do when I can.
What software are you using to to open the STEP file? STEP should be a platform neutral format.
--Madison--
Unread 02-01-2012, 19:21
Andrew Lawrence
Posts: n/a
IDK why, but my Mac says there is no application available to run the file, and I have A LOT of applications.
Unread 02-01-2012, 19:23
Mk.32's Avatar
AKA: Mark
OSX doesn't really have a good program to open STEP with.
You generally need solidworks, inventor, ProE/Cero and none of those are for mac.
Unread 02-01-2012, 19:25
Andrew Lawrence
Posts: n/a
Can it be made into a PDF, or does it not work that way?
Madison's Avatar
FRC #0488 (Xbot)
Well, it's a CAD model -- so you'd need some variety of 3D CAD software. Solidworks, Creo, Inventor, CATIA, etc. should all open it without trouble. AutoCAD probably can't; nor can SketchUp. I am not sure about VectorWorks, but it's not really built for the mechanical design market, so who knows.
I'll see if I can't make a 3D PDF. I haven't tried that in awhile.
--Madison--
