Go to Post Do whatever you must to survive within the rules, but please stay within the rules. - Kevin Sevcik [more]
Unread 02-01-2012, 19:27
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Simple 2-Speed 6WD for teams with few manufacturing resources
Originally Posted by SuperNerd256 View Post
Can it be made into a PDF, or does it not work that way?
It doesn't work like that.
You need a CAD program as Madison said.
Try this thread: http://www.chiefdelphi.com/forums/sh...hlight=CAD+MAC
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 02-01-2012, 20:03
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Try ida-step. Its not fantastic, but it does let you view universal .stp CAD data on a mac.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 02-01-2012, 20:28
Mk.32's Avatar
AKA: Mark
This may be of some interest.
http://www.andymark.com/product-p/am-0273.htm
Unread 02-01-2012, 20:58
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Originally Posted by Madison View Post
I wouldn't say that it's better than 1114's KoS. I've seen only their brief video about the KoS assembly, so I am not even entirely sure of what their recommendation requires. This was just my stab at the idea of an enhance Kitbot.
1114's KoS is essentially 6wd, 6in plactions, with toughboxes or Supershifters from AM. We used it in 2011 and loved the power it had over other robots. I feel like yours takes it to another level of steroids. It reminds me a lot of 2056's 2008 drivebase which I have been looking at a lot this off-season. http://www.2056.ca/photos.php?id=197...7440&offset=25
Are there any major differences in the supershifters over regular shifters?
Is there a reason for the double tensioners on the front chain run?
Any closer pics of the tensioner assembly?
Do you have an estimated speed?
Looks very clean simple! I love the simple mounting for the transmissions as that is my one peeve with COTS transmissions is getting them secured and still remain easy to work on!
1058 PVC Pirates 2016 - xxxx
Unread 02-01-2012, 21:33
Andrew Lawrence
Posts: n/a
I may have done calculations wrong, but this thing looks like it's gonna go REALLY fast, like 22 fps. Is it supposed to be like that, or did I do my calcs wrong? (Most likely got those wrong, but I did it twice and got the same answer)
Unread 02-01-2012, 21:55
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
What are you calculating the ratio with (What reductions in each stage, and what motor free speed, and speed loss constant?)
I get 3.86 and 9.86 ft/sec with no speed loss and 5310 CIM free speed, for reference.
The stages of reduction are:
12:40 CIM->cluster shaft
15:48 OR 28:35 cluster shaft->shift shaft
16:36 chain
It seems like a lot of chain reduction with 4" wheels. The ratio chosen seems to be perfect for 6" wheels (5.79 and 14.83 ft/sec with no speed loss, 4.69 and 12.01 with speed loss, 46 amp wall-push in low gear)
Kettering Motorsports
Unread 02-01-2012, 21:58
Andrew Lawrence
Posts: n/a
16:36 chain
Well that seems kinda low. My 22 fps is definitely wrong, and I've unfortunately lost the paper I used to calculate it (off to clean my room now!).
Madison, is Apalrd right? This looks like one of the best kitbots I've seen, but 10 fps and 3 fps are not my cup of tea. :|
Unread 02-01-2012, 22:00
Madison won't cater to what speed each person prefers. The speed is up to you with your reductions.
I prefer the speeds Madison has this at.
Unread 02-01-2012, 22:03
Andrew Lawrence
Posts: n/a
I am clueless with calculating speed, so can anyone tell me how to calculate speeds from gearbox reductions and the motors and things?
Unread 02-01-2012, 22:08
Chris is me's Avatar
AKA: Pinecone
3 FPS is definitely too slow. It's well below traction limited.
Unread 02-01-2012, 22:30
Joining the 900 Meme Team
FRC #0079
http://ewcp.org/calculators/gearbox/single/ Might help you see what effect different reductions have on your output speed.
Unread 02-01-2012, 22:32
Andrew Lawrence
Posts: n/a
Thanks!
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
Great design! But I have 1 question.....in your bill of materials, why is there only 1 of the 2 kinds of spacers (1.25 and 2.5)? I count 8 1.25 and 4 2.5?
Thanks for posting!
EDIT: NVM silly me thought McMaster would sell 1 spacer for 8 dollars
Unread 02-01-2012, 22:49
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Thanks for pointing that out! I didn't know it existed at all.
The SuperShifters have a third stage of gear reduction inside that makes them better suited for directly driving wheels. They share many common parts.
The double tensioner was mostly to get the chain away from the floor and offer ground clearance. You could probably use just one in many cases.
See below for speed.
He is right.
Alternatively, you could use the AM Shifter with a 4:1 spread between high and low. This puts it into the 11.7 ft/s and 4.6 ft/s range. That might be more in line with current sensibilities about drive speeds.
It might also be possible to use a 22 tooth sprocket on the Shifter output instead of a 16, but I'm not sure if that'd cause any interference issues. You can't go any smaller than 36 tooth on the wheels, really, because the chain will interfere with the spacers. That maybe isn't as much of a concern with the VexPro wheels as it is with the AM Plaction wheels.
Remember, the intent here is to provide a simple, robust platform for teams to use or reference. Frequently, beggars can't be choosers and so, by minimizing manufacturing complexity, you limit available choices for things like drive ratios.
Thanks for posting!
I believe they're sold in packages of ten.
--Madison--
...down at the Ozdust!
Unread 02-01-2012, 23:08
Andrew Lawrence
Posts: n/a
That's more my style. I like where this is going. By using some final staged gearing, from output shaft to wheel sprocket, do you think a speed of maybe 13 to 14 fps is achievable?
I love your simple, robust platform! It made up for not having a game hint released today. 488 never ceases to amaze me with their creations, and I can't wait to see what you come up with this season! Thanks a bunch!
