Go to Post Gerardo?!!?! Auugghh! Dave says "that's NOT pimp!!" - dlavery [more]
Unread 01-01-2012, 14:17
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Re: Casters vs. Unpowered Omni wheels
If it was a line following bot you could get away with autonomous. But no guarantees.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 01-01-2012, 14:25
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
For what it's worth, back in college, I took an Autonomous Robotics class - essentially, we played with MIT's HandyBoard and a bunch of Lego's all semester, with a game/competition at the end of the semester. I ended up designing a caster wheel (out of the provided Lego's) to use on the robot (2 drive wheels in front, 1 centered caster wheel in back) The biggest problem we had with the wheel, before we got it designed right, was it pulling apart or pulling out of the joint where it attached to the robot - there was simply too much force on it when the wheel was trying to turn (and we designed for 90% of the weight to be over the drive wheels)!
Now, given the situation, the caster wheel provided us with a great advantage - Unlike all the other robots (which had 4 traditional drive wheels - no one tried doing a 6-wheel drop center... hadn't even heard of it at that point), ours didn't have to overcome scrub on the wheels when it was turning, and we could turn around the center point between our drive wheels. This simplified other aspects of the design, as the robot could rapidly spin in place to identify the polarized guide lights, while other teams had rotating sensors and then had to line the robot up with the sensor.
Based on that experience, I say casters do have their purpose... but it's going to be a very rare game/robot design where it provides a benefit to a FIRST robot, given all the other options we have (dop center, omnis, etc).
Unread 01-01-2012, 14:43
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We once built a 2wd occra robot with rear straight casters and front skids. It was very back heavy, so the skids rarely hit the ground.
We quickly replaced the rear wheels with lunacy wheels, driven.
Don't use casters. Use driven omni or lunacy wheels.
Kettering Motorsports
Unread 03-01-2012, 13:02
Superllama12's Avatar
Superllama12 Superllama12 is offline
Wombaticus
AKA: Brandon Buncher
FRC #0540 (Talon 540)
Team Role: Electrical
Superllama12 is an unknown quantity at this point
Originally Posted by Andrew Schreiber View Post
Because casters tend to change the direction randomly depending on how they start. Ask any FLL team.
Ha ha, I remember we had so much trouble with that, until we switched to treads, but then we had even more problems with that! But I would definitely rather use unpowered omnis if we had the budget, cuz they don't change directions as easily from bumps. Also, casters cannot deal with uneven terrain, which is a little easier on omnis. My favorite type is mech, because it actually tank drives when you need it, and is much simpler.
I would put a signature here, but that's too mainstream
Wait a moment...
Unread 03-01-2012, 14:19
P. Fuller's Avatar
P. Fuller P. Fuller is offline
FRC #2199 (Robo-Lions)
P. Fuller has a spectacular aura aboutP. Fuller has a spectacular aura about
Casters are a pain in the rear to work with (in my opinion). They swivel around, which can mess up autonomous for the robot. Also, if there are bumps in the field again (like 2010), casters are much more likely to break than a slick wheel from 2009 (which has the same effect as an unpowered omni). Overall, slick wheels are an easier and much more reliable solution.
Unread 03-01-2012, 14:35
The 2009 slick wheels, though, have a much higher CoF in the sideways direction than an omni wheel (which is near zero, due to the sideways rollers). So, they will drag, which makes turning that much harder. While it won't be as bad as a 4WD all-traction setup (which could be really bouncy, depending on traction), it still won't quite perform as well as an omni wheel, powered or not.
Unread 03-01-2012, 20:47
pfreivald's Avatar
AKA: Patrick Freivald
Originally Posted by IndySam View Post
We used casters early on until 2005. We now have a hard and fast rule, no casters allowed on the robot, ever.
We used them in Rack and Roll. It remains to this day the most disastrous engineering decision we've ever made. (And we've made some doozies!)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 07-01-2012, 21:46
tlivingd's Avatar
tlivingd tlivingd is offline
FRC #4095
tlivingd will become famous soon enough
We used them in 1997 and I was a driver. They work fairly well if the rest of the machine was designed to work that way and the use a more sweeping style of driving than sudden direction changes. We even had mixed control with single joystick instead of dual joystick tank drive.
Our machine was a front wheel drive tail dragger. It had a forward heavy CG and would scoop tubes and reach forward.
The event was Toroid Terror and the event was in a hexagon with a center mounted goal.
The year prior we used a 2wd center mounted with solid pads instead of casters in the 4 corners. it was tank driven and was fine, just rocked a little.
However in this years event there is no way they would work with the ramps/tables.
Nate
Mentor Team #4095 Team RoXI
Student Team #13 BioBeast
