Go to Post I think we can all remember, no matter our age, that we are always responsible for our own actions and reactions. - JaneYoung [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 13 votes, 4.69 average. Display Modes
  #421   Spotlight this post!
Unread 30-12-2011, 19:24
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: 2012 Game?
Originally Posted by SuperNerd256 View Post
I spit out my milk onto the screen reading that! Good one.
Now off to get a new monitor... /sarcasm/
My work is done.
  #422   Spotlight this post!
Unread 02-01-2012, 10:05
RedLeader342's Avatar
RedLeader342 RedLeader342 is offline
Fabrication/Drive Coach
AKA: Justin White
FRC #0342 (Burning Magnetos)
RedLeader342 is a jewel in the roughRedLeader342 is a jewel in the roughRedLeader342 is a jewel in the rough
Re: 2012 Game?
AMERICAN FOOTBALL
  #423   Spotlight this post!
Unread 02-01-2012, 18:36
AKA: Justin White
Re: 2012 Game?
Originally Posted by Greg Young View Post
My 2012 game prediction. This includes some ideas I've been kicking around for several years. The minibots are a recent addition.
I started working on this again when thi thread began back in May. The life thing intervened in June and I shelved it until Bill's comments about pallets of field elements and the high speed counters caught my interest again.
I've tried to attach some jpegs with views of the field. The field is incomplete but if I wait until I have time to finish it May will be here again. Some of the field elements are hanging in midair, mostly because I couldn't figure out a good way to model polycarbonate as transparent.
All the polycarbonate is missing. The high goals are supported by the end walls. The low goal guard rails that are hanging in the air are supported by the end wall and side wall. The walls beside the stairs and platform are polycarbonate that extend three above the platform to avoid falling robots.
Sorry about the length of the post. I sometimes get a tad verbose.
Game Design
Philosophy:
1. Flat is boring
2. Penalties are bad.
3. Aim High was fun. The sight of a string of balls flying over the alliance station or into the stands was a thrill.
4. Minibots are a good idea. The minibot race was a little dull. It needs some twist. And even a minibot needs a (mini)brain.
5. Life may be iterative, but the universe is random.
The field:
1. Four low goals, two for each alliance. Two high goals, one for each alliance.
2. Six poles for minibots.
3. Bumps to make life interesting.
4. Steps and a platform for the end game.
5. Shooters to introduce balls into play.
Dimensions:
Since the robots will frequently not be sitting on a flat floor, the robot dimensions are defined by the bumpers. The plane formed by the top of the four bumpers is the horizontal dimension. The vertical dimension is perpendicular to the horizontal plane. The maximum robot starting configuration is 28W X 38L X 48H inches without bumpers. The bumpers are as in 2011. The bumper zone is 9 to 16 inches above the floor. The maximum minibot size is a twelve inch cube.
The bumps are one foot high. The platform is two feet high by four feet by nine feet. The steps are four inch rise and six inch run. The horizontal segments of the minibot poles are seven feet above the floor. The minibot scoring ring is 7.5 feet from the center of the field. The high point of the low goals is one foot above the floor. The center of the low goal guard ring is two feet above the floor. The center of the high goal is eight feet, nine inches above the floor. The high goal is 18 inches in diameter.
The game balls are the 7 inch poof balls from Aim High.
General rules:
Knocking an opposing alliance minibot off a pole in teleop while exceeding starting dimensions is fatal.
Your robot can go anywhere on the field that it can reach without damaging field elements.
Red robots start in the red rings, blue robots start in the blue rings.
Autonomous (15 seconds):
During the autonomous period the robots attempt to place their minibot onto one of the six minibot poles. During autonomous the robot may extend to a maximum horizontal dimension of 84 inches. There is no limit on the vertical dimension. The minibot poles are not assigned to a particular alliance and multiple minibots may be placed on a given pole. Minibots may be placed anywhere between the finish line and the shooter guard rail at the edge of the field. Any minibot placed after the end of autonomous will not be counted. The minibot game which begins during autonomous continues until the end of the match. The minibot game is worth 60 points divided as follows:
Number of minibots finishing Minibot finish place
1 2 3 4 5 6
0 0 0 0 0 0 0
1 60
2 22 38
3 10 30 20
4 8 18 22 12
5 6 10 20 14 10
6 5 10 15 15 10 5
Each minibot carries a RFID tag which is scanned before the match and assigned to the team whose robot carries the minibot onto the field. When a minibot triggers the finish gate on the minibot pole the field reads the RFID to assign a finish place to the team. Each minibot carries a wireless receiver. Once per second the FMS broadcasts the number of minibots that have finished and the seconds remaining in the match to the minibots.
Teleop (120 seconds):
During teleop the robots attempt to score balls in the goals at either end of the field. Balls in the low goals score one point. Balls in the high goals score two points. Balls scored into the goals are not returned to the field.
During teleop no part of the robot may extend beyond the frame perimeter except as noted in end game. Maximum robot height during teleop is 48 inches. Teams have 10 seconds after the start of teleop to return their robot to this configuration. Any robot extending beyond the frame perimeter or exceeding 48 inch height after the 10 seconds will be disabled. If a robot knocks an opposing alliance minibot off a pole while exceeding the teleop dimensions that robot will be disabled, disqualified and their alliance will receive a 60 point penalty. Don’t do it!
Balls are entered into play by the six ball shooters on the long sides of the field. Each shooter contains twenty balls at the beginning of the match for a total of 120 balls. Each ball shooter will shoot one ball onto the field during each five second interval after the start of teleop. All balls will have entered the field twenty seconds before the end of teleop. The time when the ball is introduced during a five second interval will be determined by a random number generator. The shooter mechanism sweeps through a 150 degree arc horizontally at a rate not correlated with the five second period. Both the time and angle at which the balls are introduced will be random. The initial speed of the ball will be 10 to 15 feet per second.
Any balls that leave the field during the match will be returned, if possible, to the shooter nearest the point where the ball left the field. The shooter will increase its shot rate to introduce all the balls into the field before 100 seconds into the match.
The maximum total score possible from the balls in the shooters is 240 points.
Human players:
Each team will have one human player in a designated HP zone during the match. The HP zones are the red or blue pads just outside the field. Each human player will have 5 poof balls in their alliance color. During teleop the human players may introduce the balls into the field as they wish. The balls can be thrown onto the field, into the high or low goals, or into a robot. Colored balls score double in a goal of the same color as the ball. Colored balls in a goal that is a different color do not score. Colored balls that leave the field will not be returned to the field. The maximum total score from the colored balls is 120 points.
End game:
It’s not really an end game since there is no time restriction but the scoring only comes at the end of the game. At the end of the match any robot that is only in contact with the blue (red) steps and platform counts 5 points for the blue (red) alliance. Any robot that is only in contact with the blue (red) platform counts 10 points for the blue (red) alliance. Any robot that is only in contact with a robot that is only in contact with the blue (red) platform scores 20 points for the blue (red) alliance. Any robot that is only in contact with a robot that is only in contact with a robot that is only in contact with the blue (red) platform scores 40 points for the blue (red) alliance. If an alliance can figure out how to stack three robots on the platform it is worth 70 points. The polycarbonate walls at the side of the steps and platform and the driver station wall are considered part of the platform. Note that a red robot on the blue platform scores for the blue alliance. While only in contact with the steps or platform a robot may extend to a maximum horizontal dimension of 84 inches. The maximum vertical dimension remains at 48 inches. Note that it is legal to stack two robots on the opposing platform to block the opposing high goal. I can’t think of a situation where this would be desirable, but the rules allow it.
Maximum total scores:
Minibot game: 60
Robots during teleop: 240
Human Players: 120
End game: 140
Total: 560
Maximum alliance score: 500
little detailed dont you think?
2009-Mechanical and Scouting student,342
2010~12-Mechanical, Fabrication, Operator,342
2012~13- Fabrication Mentor,3196
2013~Present- Fabrication/Drive Coach, 342
  #424   Spotlight this post!
Unread 02-01-2012, 22:15
takiko1996's Avatar
takiko1996 takiko1996 is offline
FRC #2443 (Blue Thunder)
takiko1996 is an unknown quantity at this point
Re: 2012 Game?
The answer is pool challenge :3 that just has to be the challenge. Game objects shall be floaties and minibots will be gone
  #425   Spotlight this post!
Unread 02-01-2012, 22:47
AKA: Justin White
Re: 2012 Game?
I think it would be to costly to do. Trying to get 4 above ground pools into the rams stadium? Come on now.. Theyre not gonna do something in water guys. They wouldnt do ice either. To hard to keep frozen unless youre in a hockey arena like palmetto regional is.
  #426   Spotlight this post!
Unread 03-01-2012, 01:23
279 EMPIE's Avatar
279 EMPIE 279 EMPIE is offline
Head Progammer
AKA: Matthew Empie
FRC #0279 (Tech Fusion)
279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice
Send a message via AIM to 279 EMPIE
Lightbulb Re: 2012 Game?
I keep hearing about the kinect being used possible as a controller, any ideas on how this could work. Would there be a new programming language used on the robots this year.
2011- Programmer, Electrical, and Web
Cleveland Regional
2012- Head Programmer, Web, Driver
Pittsburg Regional, Saint Louis International
2013- Head Programmer
Cinnicinatti Regional, Taraho Regional
  #427   Spotlight this post!
Unread 03-01-2012, 01:38
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: 2012 Game?
No new languages, but they are extending the WPILib to include wrappers for the Kinect, so you won't need to know the nitty gritty stuff. I believe that those wrappers give you the position of each appendage and the positions of each "joint".
  #428   Spotlight this post!
Unread 03-01-2012, 10:17
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Re: 2012 Game?
It's a joke, bro... always has been, always will be.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
  #429   Spotlight this post!
Unread 03-01-2012, 10:32
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: 2012 Game?
No... It is... a DREAM! A dream which makes us who we are, a dream which keeps us desperately grasping at straws, a dream which keeps us all hoping for the day when we can use all the robot boat designs lurking at the backs of our brains...
You can't fix something that isn't broken... but you can always break things that aren't fixed!
  #430   Spotlight this post!
Unread 03-01-2012, 13:28
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: 2012 Game?
Now that you mention it, there really are a LOT of robot boat designs at the back of my brain. Time to bust out the isometric graphing paper.
  #431   Spotlight this post!
Unread 03-01-2012, 13:38
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Re: 2012 Game?
As our team keeps saying, think MINIboats!
  #432   Spotlight this post!
Unread 03-01-2012, 13:39
AKA: Justin White
Re: 2012 Game?
i didnt know it was a joke
  #433   Spotlight this post!
Unread 03-01-2012, 20:02
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
Re: 2012 Game?
Think of the other kind of pool, with 15 balls and a couple of sticks. And a triangular rack.
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
  #434   Spotlight this post!
Unread 03-01-2012, 20:17
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
Re: 2012 Game?
Just as a note, in past years FIRST has trolled us with clues throughout the kickoff. Since this years kickoff is prerecorded we should probably expect to see different types of trolling than in past years.
  #435   Spotlight this post!
Unread 03-01-2012, 20:22
Andrew Lawrence
Posts: n/a
Re: 2012 Game?
Though I do agree FIRST is known for their trollery, I know that during the kickoff presentation usually has major hints on the game. Like during kickoff of 2011 (I still can't believe that's now "last year"), they brought out the game pieces, and if I've hear correctly, they had some major hints about Lunacy in the 2009 kickoff, so not everything they say is tom-foolery. The hard part is picking out what's useful information, and the things Dave Lavery puts into the conversation.
