Go to Post I can't really think of a bad FIRST experience, really, I can't. - Joshua May [more]
Unread 02-01-2012, 23:07
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Team 772 First WCD CAD
I made My First West Coast Drive today.
Specs:
FPS: 13~
Transmissions: Toughbox mini 5:56:1 Gear ratio
Tube size: 2 x 1
Weight: Unknown at this point
Wheels: 4in AndyMark Performance wheels
Live axles using Keystock
Things I now i need to do:
Make Transmissions plates to support them
Make belly pan for electrics
Put CIM's In
https://plus.google.com/photos/10207...21262306?hl=en
Since I have never made a Chassis with live axles i don't know if these bearing blocks would work.
https://plus.google.com/photos/10207...15094658?hl=en
Any thoughts or problems??? THANKS
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 02-01-2012, 23:11
Andrew Lawrence
Posts: n/a
Re: Team 772 First WCD CAD
Great chassis! Love the WCD!
Put CIM's In
As a side note, it'll probably be a good idea to get those CIMs in! I find they're quite helpful for making the robot move!
EDIT: Where'd you get the tread from? Looks nice, especially with that blue frame!
Unread 02-01-2012, 23:20
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
You should add some more support for the gearboxes instead of just two stand offs. Start with the hex shafts to join the top of the gearboxes.
How do you plan to align the bearing plates?
What size/thickness alum box? Welded?
For a belly plan the AM poly carb would work.
And what is keeping the sprockets on the shaft?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 02-01-2012, 23:35
I am going to add Two Aluminum Plates to the transmissions. 1 on top and 1 on the bottom.
Aligning the bearing plates. Never thought about that. (however this chassis may never be built)
The thickness of the Aluminum is 1/8th 1 in by 2in. Yes welded.
We will most likely use lexan for the belly pan. We get it donated.
The inside of each shaft will be threaded for 1/4-20 bolts. It is gonna have a washer and then a bolt holding them on. The spacers will ensure it stays in the right spot.
2013-Present
2010-2013
Unread 02-01-2012, 23:46
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Looks good. You should add in some cross members and corner gussets for some support.
Keep up the good work.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 03-01-2012, 16:02
With the transmission Plates and Belly pan, wont that be enough instead of putting Cross Members in? I'm not sure about putting in corner gussets though.
2013-Present
2010-2013
Unread 03-01-2012, 17:06
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
Both cross-members and corner gusset plates would be redundant in this WCD. The corner gusset plates would be unhelpful as the chassis will be welded (on a side note: some welders like to have corner gussets in before welding for alignment purposes but..it’s all personal preference). Also the cross-members can be replaced by a good belly-pan. Just make sure you support you transmissions and this looks like a great WCD.
Just a few questions...How are you going to tension the chains? and why did you choose the Toughbox Mini's?
Unread 03-01-2012, 18:26
Chain Tensioners: I will have to add that to my list of To Do`s
Toughbox mini`s: Inexpensive and gave the gear ratio i needed for a fast robot with 4in wheels.
2013-Present
2010-2013
Unread 03-01-2012, 22:42
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
By slotting the front and rear bearing block cutouts your can use the axle as a chain tensioner.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 03-01-2012, 22:47
Feroz1325's Avatar
have you considered sliding bearing blocks for tensioning? Of all the systems ive seen that seems to be one of the most elegant and simple.
I just have to say that it looks awesome....team 772 has always been a team to look up to! Hope to see you guys at GTR and...i have too....
7 - 7 who? 772!!!
Its so catchy!! after u guys chant it in the stands its stuck in my head for months!
Unread 03-01-2012, 22:55
7 - 7 who? 772!!!
LOL! This was the best post I have ever read :')
Thanks for this, it made my night (Canada juniors are ruining it).
I will most likely use a sliding bearing block now. I usually would put a slot for a tensioner in the middle of the chain (for sheet metal chassis) but seems like more people are doing a sliding bearing block for WCD.
2013-Present
2010-2013
Unread 04-01-2012, 12:18
Feroz1325's Avatar
A mid-chain tensioner would add weight and inefficiency to the system as a whole. The reason for switching to WCD (mainly) is to remove weight and increase efficiency. Also since you have individual bearing blocks already, its simpler to just pocket out the aluminum box extrusion and allow them to slide.
that russian team! beating us on our own turf ruining all our nights!
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
