Go to Post Is it weird that I was hoping we wouldn't have too many snow days so that graduation wouldn't run into Battlecry? - ScoutingNerd175 [more]
Unread 30-12-2011, 18:21
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
Run Jaguar's through PC
Hello, I got 2 Black Jags for Christmas for my personal robot project, is there any code out there to run the Jags via CAN Bust hat will run on the PC?
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 30-12-2011, 18:24
Re: Run Jaguar's through PC
There's a BDC-COMM program that you can download from TI and run on the PC to talk via CAN to the Jags.
Unread 30-12-2011, 18:29
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Are you using the factory default firmware for the FIRST firmware? I guess the former otherwise you might already know about bdc-comm.
The CD with software for the Jaguar (*non* FIRST) can be downloaded here:
http://www.ti.com/tool/rdk-bdc24-cd
On it should be the stock version of bdc-comm which is a Windows application that lets you communicate over a serial connector to the Net/Serial connector of a Black Jaguar via adaptor. See the Getting Started Guide for more info.
Unread 30-12-2011, 21:37
Doc543's Avatar
AKA: Eric
is there a way to import these libraries into LabVIEW? What I'm going for is to make my laptop into a robot controller.
Unread 30-12-2011, 21:49
Can the WPIlib MotorControl functions in the FRC LabVIEW support the PC as a target?
Unread 30-12-2011, 22:33
Doc543's Avatar
AKA: Eric
I tried it but the C library it needs to run is missing, I don't think my labview is installed correctly on this computer anyway
Unread 30-12-2011, 23:13
I highly doubt it. Those will very likely interact with libraries on the cRIO and/or the FPGA, making them impossible to run on a PC.
Worst case, the serial protocol and CAN protocol should be documented, so with some work you should be able to make your own library for it or find someone else's.
Unread 31-12-2011, 06:57
As mentioned, the WPILib CAN VIs are customized for FRC and so is the Jag firmware. These customizations are largely for a safety heartbeat mechanism, but also take care of bridging the CAN traffic over either enet or serial.
Perhaps http://www.ti.com/lit/ug/spmu065b/spmu065b.pdf or www.luminarymicro.com/jaguar will be useful.
Greg McKaskle
Unread 02-01-2012, 13:02
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
Greg McKaskle
While that is true, most of the code is reusable. If you use the non-first specific firmware, then all you need to do is change the "token" enable and set commands into the non-token ones, and then at the lowest level of the Jaguar API (which calls into FRC_NetworkCommunication_JaguarCANDriver_sendMessa ge and FRC_NetworkCommunication_JaguarCANDriver_receiveMe ssage), reimplement those with VISA serial VIs instead of calling into the library. The Black Jag serial bridge plugin will show you how to turn CAN frames into serial traffic that the black jag can understand.
It's not exactly trivial, but it shouldn't take much effort. All the needed info is available.
Good luck!
-Joe
Unread 04-01-2012, 01:08
Doc543's Avatar
AKA: Eric
I was wondering if I could just swap the can just swap that code with the VISA serial, I was afraid there was more to that C-RIO code then just sending serial data. I will go try this. I will let you know of any breakthroughs.
Unread 04-01-2012, 19:16
DonRotolo's Avatar
Back to humble
FRC #0832
Also keep in mind that the PHYSICAL layer of a CAN Bus cannot be produced by a PC without some additional hardware. USB, Serial, Parallel, FireWire, etc all use different voltages from the Jaguar's CAN implementation.
Unread 04-01-2012, 19:23
While that is true, the Black Jaguar also implements a standard RS-232 interface on the left RJ port. It can then be used to bridge to any other Jaguar on the CAN interface. This means with nothing more than a serial adapter cable (described in the Getting Started Guide), your PC can control Jaguars (from an electrical stand-point).
-Joe
Unread 04-01-2012, 19:24
There is more to it, but the differences are either described in my post above or are specific to the FIRST version of the firmware, which you should not use if controlling the Jags from your PC.
Unread 04-01-2012, 19:28
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
If you are using the 2CAN the Jaguars may be run using the Cross-link Control Software for Windows or uCANdrive for Android. Both are available as a free download, the RCS is open source. uCANDrive is also available on the Android Market.
The RCS installer is located under Downloads:
http://www.crosstheroadelectronics.com/Cross_link.html
http://www.crosstheroadelectronics.com/uCANDrive.html
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 04-01-2012, 19:29
... and CAN requires dominant logical 0 for collision detection and arbitration.
