Go to Post To anyone who is discouraged about their team, don't let yourself get down. I've seen my team go from having a robot that barely moved (and I'm not kidding, we had keys falling out of gearboxes) to this year with a robot that is ACTUALLY GOING TO WORK. Don't lose hope, stick with FIRST! - ZipTie3182 [more]
Unread 03-01-2012, 22:26
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
pic: Unobtainium 6wd - Cantilevered, Dead-Axle, Slot-Tensioned Drivetrain
Unread 03-01-2012, 22:27
Andrew Lawrence
Posts: n/a
Re: pic: Unobtainium 6wd - Cantilevered, Dead-Axle, Slot-Tensioned Drivetrain
Great! What are the drive's advantages, in your opinion?
Unread 03-01-2012, 22:30
Chris is me's Avatar
AKA: Pinecone
I do have to ask: Wouldn't an 1/8 wall square extrusion weigh just as much as a quarter inch L, with a much stronger profile?
Unread 03-01-2012, 23:45
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Is the idea here that the bolts are threaded into the frame member or are they through-bolted with a nut on each side?
My gut reaction is one of concern that the bolts will unscrew themselves, but maybe that's unwarranted.
Edit: Nevermind; missed that this is a shoulder bolt.
--Madison--
...down at the Ozdust!
Unread 04-01-2012, 02:19
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
This is very nice and simple but I'd be worried about the forces that cantilevered load is putting on a very small amount of aluminum. Id guess that over time either the hole in the aluminum would oval out or the angle itself would want to bend below 90 degrees. You may want to run some CAD analysis, but with me this doesn't pass the sniff test.
Unread 04-01-2012, 02:47
Aren Siekmeier's Avatar
on walkabout
The shoulder joint will definitely hold, but it has to be supported by the frame. With a single support point in just 1/4" of aluminum, it will likely just bend the angle aluminum and not stay horizontal. A box extrusion will solve this problem by providing two support points for the bolt and not deforming under the loads we're talking about.
Unread 04-01-2012, 09:55
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I'm pretty sure this would hold, over time you would probably see the slots warp a bit after repeated use. My main concern would be the flex in the main angle bar. The middle wheel would likely flex a decent amount when it had weight on it, if there wasn't any extra cross support in the middle of that system. I could see it flex enough in this configuration that it could almost negate a 1/8" center drop. But that flexibility could be interesting for a mecanum drive...
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 04-01-2012, 10:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Interesting design, it might work for some games, but not for others.
We built a cantilevered dead axle drivetrain on our 2008 robot, using 1/2" threaded rod for the axles, and 1/8" thick 1x4" pultruded fiberglass for the frame members. We had an adjustable chain tensioner instead of slotted holes. It worked fine for the Overdrive game, since the playing field was flat and most of the action was driving laps.
http://www.chiefdelphi.com/media/photos/29697
Unread 04-01-2012, 11:38
AKA: Mr. Lim
  • Simple base components (80/20, L-angle, shoulder bolts)
  • Reduced machining operations (no custom shafts, non-CNC milling)
  • Simple chain tensioning method
  • Quick assembly time
  • Easy servicing (one bolt wheel removal)
  • Lightweight
  • Large baseboard area for electronics
  • Less gear reduction required for 4" wheels (more efficient)
  • I could see teams with some basic machining capabilities knock two of these out within the first few days a build season, then move on to bigger and better things
Yes, but the shoulder bolt shaft needs to be bolted to a plate with sufficient thickness, or else the plate will bend under load. Anecdotally, 1/8" wall seems too thin and will flex. Also, the L-angle leaves more space for the electronics board, and provides nice mounting flange. The L-angle looks to be plenty strong(?), and the bottom flange could be milled down to 1" or less to save weight - but that's another machining operation.
It is a shoulder bolt (through-bolted) with a single nylock nut, and two washers sandwiching the plate. The above image best shows the setup. When the shoulder bolt and nut are tightened, it causes the washers to squeeze the plate tightly. The idea is that this is enough squeeze force to a) keep the cantilevered shaft perpendicular, and b) keep the shaft from sliding in the slot (the plate is actually SLOTTED for the front and back wheels to allow you to slide the wheels back and forth to tension the chain)
This is where my lack of mechanical experience shows through. I am concerned about this too, but I don't know the limitations of Nylock nuts, and threadlocker.
The concept is that the washers that sandwich the plate distribute the load over a larger area of the plate. If this happens, there should be very little load inside the slot itself. CAD analysis is a good suggestion to see whether this works.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 04-01-2012, 12:12
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
You might want to try heavy-duty all-metal locknuts (the ones with the elastically-deformable bore), or high-strength steel nuts and threadlocker. Torque them to the limit specified by the manufacturer. Given the shoulder bolts, you'll probably need an unusually-strong Allen wrench to make this happen. That's the only way I could see this holding tightly enough in a slotted hole.
Consider http://www.mcmaster.com/#92501A030 or http://www.mcmaster.com/#93591A200, for example.
Unread 04-01-2012, 12:32
MrForbes's Avatar
AKA: Jim
Stover lock nuts, you mean?
I suggest you might want to find or figure out how to make a more substantial washer. Our design used large hex flanged nuts. You might be able to do this too, and use 1/2" fine thread threaded rod for the axle as we did. We used two jam nuts to retain the wheels, but this required that whoever was working on the robot needed to know not to tighten the nut too much!
Unread 04-01-2012, 13:01
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
Actually, my original concept called for 1/2" shoulder bolts in a slightly different configuration. I intended to have the shoulder portion of the bolt pass through the frame, and tighten the entire wheel assembly against the frame with very thick washers.
The thread of a 3/8" shoulder bolt is 5/16"-18, which in my opinion is too small to be supporting this kind of cantilevered load. Thicker washers would help some, but the thread length is only 1/2", so you don't have much to work with, probably not even enough for a heavy lock nut.
I think what you have shown could work with a larger shoulder bolt, but it looks like squirrel's method with 1/2" threaded rod would be simpler and stronger. And fine thread really helps to get things tight.
Another issue is bending of the frame itself. Putting a cross bar at the top of the angle next to each wheel would help a lot. It could be a thin wall tube with a small threaded rod running all the way through.
Unread 04-01-2012, 13:52
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
There is a lot there to love.
A lot that is cringe worthy as well, but overall, a nice effort.
Got me thinking... ...How can I use this? Maybe there is something there...
Thanks!
Joe J.
Team #88, TJ2
Unread 04-01-2012, 14:07
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Cantilevered shoulder bolts can take a lot of load. I used them in an FSAE car suspension rocker that saw around 5,000lbf. The trick is to get the shoulder supported and eliminate bending stresses from any threaded portions. The only serious issue I can see in your design is how the shoulder bolts are connected to the rail.
In this picture near the left-hand edge about 1/3 of the way down you can see where we used a 5/8" (1/2"?) shoulder bolt on the suspension rocker. About half of its length passed through a steel mounting point, then went through a needle bearing in the rocker, and was captured with a nut on the inside of the car. We sandwiched thrust bearings on either side of the rocker so we could clamp everything down very tightly yet still spin it by hand.
I hope you find this useful *cough* needle bearings in wheels *cough*
Unread 04-01-2012, 16:26
Now that I think a little more about this, watch out for the stress distribution in the preloaded part of the bolt (i.e. the part from the threads to the shoulder that is under tension when tightened). Normally you preload a bolt to a signficant fraction of its tensile strength. The large bending moment from the cantilever will also add stress right around that area—meaning that you might end up overstressing a bolt tightened according to the manufacturer's directions.
