Go to Post When more STEM teams exist outside schools than in them, that will be one indication that a true cultural change has occurred. - gblake [more]
Unread 04-01-2012, 01:19
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
Broken Jag
We had a Tan Jag that was labeled "Bad", so I tested it with a little Bane Bot motor which was only pulling 2 Amps. At first it would only run Forwards. I checked the limit switches and they where both closed. Then it stopped driving the motor all together. I was saying that it was outputting voltage but all i could here was a very quiet high frequency hum. It started dropping the CAN Bus connection and then it just wouldn't talk to me anymore and the light stayed off. Is there a way we can get if fixed or replaced?
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 04-01-2012, 02:04
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Re: Broken Jag
i know my team invested in fixing our jags (we had $1000 blow up in less than a sec.). so far (from what i know) we are going through components, testing them and replacing the broken ones. black ones can be sent to be fixed for free (if i remember right)
Unread 04-01-2012, 07:50
Re: Broken Jag
Doc,
You can check with the factory but the condition you describe was typical of the gate driver chip taking a hike. Those chips are no longer available for the old Jags so you might not get very far. The manufacturer may have kept enough in stock for repairs so you need to check.
