Go to Post I predict someone has to eat a hat! :D - FiMFanatic [more]
Unread 04-01-2012, 19:23
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Run Jaguar's through PC
Originally Posted by DonRotolo View Post
Also keep in mind that the PHYSICAL layer of a CAN Bus cannot be produced by a PC without some additional hardware. USB, Serial, Parallel, FireWire, etc all use different voltages from the Jaguar's CAN implementation.
While that is true, the Black Jaguar also implements a standard RS-232 interface on the left RJ port. It can then be used to bridge to any other Jaguar on the CAN interface. This means with nothing more than a serial adapter cable (described in the Getting Started Guide), your PC can control Jaguars (from an electrical stand-point).
-Joe
