Domo arigato Mrs. Roboto
Unread 04-01-2012, 19:29
DonRotolo's Avatar
OMGweek5whyarentwedoneyet OMGgetgoin
FRC #0832
Re: Run Jaguar's through PC
Originally Posted by jhersh View Post
While that is true, the Black Jaguar also implements a standard RS-232 interface on the left RJ port.
Oh.
Unread 07-01-2012, 01:16
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
do you know where i can get the documentation on how the data is sent to the Jag by RS232, i need to know things like how the data is organized. for example, in the LabVIEW code there is a input into the "FRC_Communication" that is the data size, is that sent over or is is used just for that program. If I can get that information I just might get that old wheelchair running autonomously
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 07-01-2012, 01:34
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
I wish I had much to add, but my guess would be to somehow reverse engineer the serial can structure in the FRC code.
either that, or PWM it. PWM control with boe bots was easy, (driving PWM wheel servos) as all you did was send pulse rates to a digital output (in hz IIRC), ranging from 6500 (full reverse) to 8500 (full forward), with 7500 being neutral (stop).
In fact, IIRC, the original IFI controllers used the same BASIC STAMP controller as boe bots...
for that matter, if you knew C (like I will after the next few months), you could obtain a second hand later generation IFI controller and drive them that way.
Unread 07-01-2012, 09:08
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
From my previous work with networking, the easiest way for me would just be just to use wireshark and reverse engineer the packets being sent. Since CAN is just networking it should be pretty simple. The only thing I could for-see holding you back would be the packets being encrypted.
Unread 07-01-2012, 23:37
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Try looking at the source to the black jag bridge plugin like I originally suggested.
http://firstforge.wpi.edu/integratio...ystem=exsy1002
It implements the serial protocol you need.
Joe
