Go to Post Once you go to your first (FIRST) competition... thats when you fall in love with it. - Jaine Perotti [more]
Unread 05-01-2012, 01:25
eat4fun's Avatar
eat4fun eat4fun is offline
sudoer
AKA: Eric Bryce
FRC #1325 (Inverse Paradox)
eat4fun is an unknown quantity at this point
cRIO is running code, Driver Station reports no robot code
First year working with LabVIEW (normally use Java) and we’ve been having trouble with our cRIO -- a smorgasbord of coding and technical problems.
I wrote a simple VI to blink LEDs on the cRIO depending on the game status (timeout v. autonomous/teleop disabled), and deployed it to the cRIO so that it runs at startup. The LEDs on the CompactRIO are blinking as expected; however, the FRC Driver Station application reports there being no code on the device. Probably a coding issue, but not sure.
Any idea as to what the problem may be?
Exhibit A: http://i.imgur.com/TX27v.png
Exhibit B: http://i.imgur.com/zqiWb.png
Exhibit C: http://www.quickmeme.com/meme/35n7f8/
Unread 05-01-2012, 09:26
NeatNit's Avatar
NeatNit NeatNit is offline
Alumni Programmer
FRC #1577 (Steampunk)
NeatNit is an unknown quantity at this point
Re: cRIO is running code, Driver Station reports no robot code
Is that your entire Robot Main? You seem to have removed parts of it - maybe including the part that makes the driver station show robot code.
Unread 05-01-2012, 10:32
You should not be modifying the Robot Main vi. Everything you write should go in the Team Code heirarchy. To start with, look at Begin, Teleop, and Finish.
